3racing F109
#1187
i have the 3R f104 wingkit on my f109???? drove it all day today, what is not supposed to fit?
#1188
Several of the parts do fit. I know for a fact the F109 front suspension and front/rear aero pieces bolt onto the F103 without modification because I am running them. I am not sure if the rear pod is interchangeable, but the axle and diff are probably interchangeable between the F109 and F103.
#1192
In terms of tyres. I haven't got an outtuned diff, but im pretty sure the F103 tyres will also fit the F104 with the outtuned diff. The hex sizes should all be the same i believe.
#1193
Ran the F109 on track the first time today...the car was BALLISTIC out-of-box!!
One question tho, has anyone tried to fit a cooling fan to the motor? I'm running the Tamiya Sport Tuned black can motor, gearing was at 4.67 FDR and the motor temperature was too high to my liking...
Or anyone knows if the 3Racing motor mount+cooling fan for the F104 fits the F109?
#1194
F103 rear tyres can be used on the F104 out-tuned diff, they are of the same hex sizes. You'll need a different size bearing to use F103 FRONT tyres on the F104 tho.
#1196
In terms of camber mount, i don't think the f104 camber mount will fit the stock f109 front end. This is because the F109 has the arms suspended via hinge pins, where the F104 has arms suspended by pivot balls. In saying this i haven't tried it.
#1198
Is there any place in the US to purchase this car & some up grades ?.
#1199
http://www.rcmart.com/catalog/rc-bes...o-p-31066.html
not in the US but you cant beat this deal! got mine last week and it is EXCELLENT! ESC even coems with a programmer!
#1200
