Old 08-22-2010, 03:11 PM   #1141
Originally Posted by bew79 View Post
speaking of setup, do most people here just use gauges to set toe and camber or can you use 1/10 setup stations for F1, in particular F109?
Also how tight should you do up the ball diff, there doesn't appear to be any recommendation in the manual?
When i had the std front axles on the front, i used a HUDY setup station for 1/10 TC with no problems. Haven't tried with with the CRC axles
HTH
HandS is offline   Reply With Quote
Old 08-22-2010, 05:32 PM   #1142
good to know, any recommendations on ball diff setup?
HTH
bew79 is offline   Reply With Quote
Old 08-22-2010, 07:54 PM   #1143
robk's Avatar
Trader Rating: 22 (100%+)
Hey all
Tried to post some pic's of my chassis, but it wouldn't let me until i have made a certain amount of posts.
Mods so far, crc side spring mod, 104 diff/shaft also trying a crc front hub mod i have been working on.
Best result so far, was Q2nd and finished 2nd at the racing lines international(behind a F109), January 2010 only 4 days after purchasing the car.
It has done me well at club racing but recently our club has changed venues from outdoor ashfelt, to indoor dusty concrete.The guys with rubber tires are blitzing us guys with foams. If anyone has any setup advice for low traction surface, im all ears (caster, camber, pod droop, side springs etc...) Cant afford to go to rubbers just yet.
Thanks in advance
Coat the foams in silicone caulk.
Old 08-22-2010, 08:56 PM   #1144
Unfortunately no tire additives of any kind are allowed in New Zealand.
As for diff setup, i think i have just fluked it. I have it so there is just a tiny amount of slip from a standing start. Also highly recommend ceramic balls, totally changed the feel of the diff
Old 08-22-2010, 08:59 PM   #1145
robk's Avatar
It's not an additive, it's actually adding a layer of clear silicone caulk (like you would use in construction) that will be dry before you ever run the car. This was a common practice in USA dirt oval and at one point 1/12 many years ago.
If they can run rubber, you should be able to coat your foams.
Old 08-23-2010, 12:10 AM   #1146
Thanks man, ill give it a crack on some old tires, and see if it passes tech lol
does it still matter what compound the foams are with the layer of silicon on them?
Old 08-23-2010, 03:57 AM   #1147
cherry2blost's Avatar
Hi Guys, has anybody attemted to convert one of these to World GT as I have an F109 and want to run GT, if anybody has done it can you post pictures maybe so I can follow them to convert my one, looks like it just needs longer rear body mounts and a bumper/bodymount holder fitting to the front.
Help would really be appreciated.
TIA
Tamiya TA05 Ver II, Hobbywing 13.5T, KO PROPO PDS-2501 ICS, Eagle Racing 6000 65C LiPo, Hobbywing XTREME STOCK 518/213) Sanwa/Airtronics MT4 2.4G Radio.
www.racersinexile.org.uk | 'Official Certified' UK/Euro Importer for the Hobbywing XERUN Series Equipment We ship the world !!!| Quote code 'cherry' for 10% discount on our Web Store.
cherry2blost is offline   Reply With Quote
Old 08-23-2010, 02:05 PM   #1148
robk's Avatar
I would use whatever tires you usually use. When you put the silicone on, spin the wheels on a drill and use a finger dipped in dish soap to even out the coat.
Old 08-24-2010, 11:21 AM   #1149
Dan the Man's Avatar
Trader Rating: 40 (100%+)
If you're using the 3Racing Out Tuned Ball Differential For F104, I'm assuming you can only tun F104 wheels on it, yes?
<==H
|-●-|Hot Bodies Pro 5 |-●-|Hot Bodies D8 GT-E|-●-|The "F109X"|-●-|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 08-24-2010, 11:38 AM   #1150
<==H
Well I run the F109 wheels with my Out Tuned Diff
4_cell_racer is offline   Reply With Quote
Old 08-24-2010, 01:55 PM   #1151
robk's Avatar
<==H
F103, F104, F109 wheels all fit
Old 08-24-2010, 07:11 PM   #1152
MantisWorx's Avatar
Trader Rating: 28 (97%+)
is there anywhere in the US that has this car in stock? im looking to buy on ASAP!!
MantisWorx is offline   Reply With Quote
Old 08-24-2010, 09:38 PM   #1153
Marcus
HKSHobby in LA has it.
http://store.hkshobby.com/product_in...oducts_id=6740
How's the Mini Z F1 stuff coming along?
Sydewynder is offline   Reply With Quote
Old 08-24-2010, 10:23 PM   #1154
MantisWorx's Avatar
Originally Posted by Sydewynder View Post
Marcus
its goin great! check out the website! got the PNWC worlds coming up late october and team Mantis has won every qualifier this year we have entered!
Old 08-25-2010, 07:50 AM   #1155
tudor_47's Avatar
Marcus,
are you going to make lots of nice parts for the F109?
, I am sure you can think of something we all need!
The car is also available from rcmart in HK, usually around the 100 dollar price tag.
It is right now at 90 dollar.
good luck!
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13160 Yesterday 11:58 AM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
