Old 08-10-2010, 02:54 AM   #1111
InZane's Avatar
Default F1-09 Carbonated ... a first glance
Very nice looking chassis!
30 grams lighter and stiffer lengthwise, side to side flex about the same as the kit chassis (maybe a tad softer) ... PERFECT!
InZane is offline   Reply With Quote
Old 08-10-2010, 03:13 AM   #1112
Nice! I'll be ordering mine when I get back from IIC most likely.
Old 08-10-2010, 11:57 AM   #1113
kmichael's Avatar
kmichael is offline   Reply With Quote
Old 08-10-2010, 12:58 PM   #1114
njt
njt's Avatar
picked my chassis up new today, looks the buisness , first run will be at stafford rcmcc on thurday at 18.50
njt is offline   Reply With Quote
Old 08-11-2010, 03:18 PM   #1115
Did you get your chassis from the UK of Hong Kong bud?
4_cell_racer is offline   Reply With Quote
Old 08-11-2010, 04:14 PM   #1116
Please post pics of graphite car when completed
Enforcerman is offline   Reply With Quote
Old 08-11-2010, 06:54 PM   #1117
mxrich's Avatar
Originally Posted by colmo View Post
Ah good, so Corally just cheated then. Their car is absurdly expensive anyway...
On the subject of tyres, I'm looking for some rubber for my F109 for general outdoor use - any suggestions? Pit Shimizu seem to be substantially cheaper than HPI Bridgestones and a few other brands. I'll likely get them from HK.
Check with rcmart.com. Lot's 'o rubber tires to pick from. OOPS! never mind, you already have.
I park faster than most people drive.
mxrich is offline   Reply With Quote
Old 08-11-2010, 06:55 PM   #1118
bjholz's Avatar
Guys, I never got a chance to run my F109, but I decided to trade it for a FT RC10 T4 because my local track switched to offroad
www.trackside.com
FT SC10, FT B4, FT T4, b44.1
Tekin, Ace, Airtronics, Savx, Novak, Murfdogg, LRP
bjholz is offline   Reply With Quote
Old 08-13-2010, 07:32 PM   #1119
spring71's Avatar
Smile
RC RIDE F1 Wheels and Tires are restocked.
Also, Ride 1/10 touring 24mm spoked wheels, Sweep 36 tires, EXP inserts are in stock now.
You can buy at the track or order online.
Click here for more information.
Special online order discounts are available for online order, enter the coupon code below in the shopping cart.
1461 Order Online $100 and More, get $10 off
1462 Order Online $200 and More, get $20 off
Address: 13871 Oaks Ave Chino, CA 91710
Web: www.tqrcracing.com
Email: tq@tqrcracing.com
Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is online now   Reply With Quote
Old 08-14-2010, 04:55 AM   #1120
kmichael's Avatar
Nice,wish they came in 1/8 for my Serpent F180
Old 08-14-2010, 01:58 PM   #1121
I'm a newb to direct drive cars, so presume absolute ignorance...
I just started building my F109, with out-tuned diff and alloy caster mount from the start. The out-tuned diff has me confused - the axles appears to be nowhere near long enough to fit the thrust bearing assembly, spacers, disk spring etc.
On inspection of the F104 manual, it appears to have no thrust bearing at all. What's going on?
P.S. on reflection, the whole point of the out-tuned diff is to avoid messing with the diff when changing wheels. I presume I just bolt on the wheel with a locknut and job's a good 'un?
colmo is offline   Reply With Quote
Old 08-14-2010, 02:27 PM   #1122
skullbocks's Avatar
Trader Rating: 20 (100%+)
Quick checkpoint for you. F109 use F103 rear axle, but in order to use the out-tuned diff on the f109, you need to get the f104 axle which is shorter.
TRG09 F1 - Tekin RS Pro - Tekin 21.5T
CRC F1 -Tekin RS Pro - Tekin 21.5T
Team Associated RC10R5 - Novak 1S - Tekin 10.5T
Team Associated B44 - Mamba Pro - Mamba 7700k
1/12 Speedmarchant v3. - Tekin RS Pro - Tekin 17.5T
skullbocks is offline   Reply With Quote
Old 08-14-2010, 03:24 PM   #1123
Not a problem - just means I have to wait for more parts! Not an expensive part, but available in fibreglass, aluminium and carbon - I presume carbon is best? What are the dimensions of the F104 axle, it doesn't look hard to make one?
Old 08-14-2010, 03:26 PM   #1124
+1
If your running the out-tuned diff you will need the F104 axle as well
I run/ran on my F109 and for me was a lot better than resetting the diff tension every time I changed the rear wheels.....
For some unknown reason the centre shaft that fits inside the alloy housing is now not running true and I've some how managed to split the rear axle I must have taken a knock and not noticed
Old 08-14-2010, 03:29 PM   #1125
The one I bought was a fibreglass one which has now split (see my prev reply)
I've heard people cutting the F109 axle down to the same length as the F104 axle....if I remember and get a lil spare time I'll measure the F104 axle I have for you
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12848 Today 05:24 AM
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
