Old 05-30-2010, 07:38 AM   #976
InZane's Avatar
Originally Posted by MonkeyNuts View Post
Hi all,
Just brought myself a F109 and was wondering what hop-ups from Tamiya fit the 3Racing? If someone could give me a list of the hop-ups that fit, that would be very much appreciated.
Cheers,
Liam
Most parts are interchangeable between the F1-09 and Tamiya F103/F104 - except for the chassis and motor pod of course (F1-09 is a link car, Tamiya a T-bar car).
The obvious question is why you'd want to use Tamiya hop up parts
The are pricey without being any better - IMHO.
The only Tamiya parts I use are the 3.5 mm offset knuckles, center shock spring (Touring spring set) and the thrust bearing in the 3Racing Out Tuned diff. I'm thinking about using the F104 rear carbon axel as well - but that's about it.
As for other hop up parts I use the alu caster plate, servo horn, Out tuned diff (nearly a must have for ALL F1 cars) from 3Racing, the CRC mod (CRC spring holder and CRC or AE side springs), Zen king pin (longer than kit pins so I can get height adjustment) and front springs from AE.
InZane is offline   Reply With Quote
Old 05-30-2010, 07:53 AM   #977
bjholz's Avatar
So I have my car all put together and everything. How do you guys keep your battery from moving around? Do you use tape or anything at all? I have my car set up with a 27t motor, Novak Cyclone TC ESC, Specktrum receiver, and Futaba s9551 servo. I believe it will be a pretty good set up. I also have a good collection of silver can motors. The most efficient setup i could figure out was with the ESC an receiver both on the same side. The receiver weighs close to nothing so this shouldn't be a problem, if I balance the other side out with weights right?
www.trackside.com
FT SC10, FT B4, FT T4, b44.1
Tekin, Ace, Airtronics, Savx, Novak, Murfdogg, LRP
bjholz is offline   Reply With Quote
Old 05-30-2010, 08:10 AM   #978
Originally Posted by GasGod View Post
I know I will be ordering some Rides for the 109 and103 when they are in stock
That's good to know, I've been searching for a source states side.
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 05-30-2010, 09:17 AM   #979
orci77's Avatar
Questions??
Hi everybody,
first of all greetings from Germany to all you F1 enthusiastics.
I am following this thread for a while and since my F1-09 arrived, I decided to join this forum.
Till now I raced a F103RX on carpet and on asphalt. Since we change to LiPo with the touring cars I was not happy with the way they fit into the F103. Especially with the ball suspension most LiPos are too wide.
So I decided to change to a new chassis which offers better space for LiPos. As a big Tamiya Fan I thought about the F104. But the space for the LiPo is a little bit tight and I don't like the solution for receiver and ESC. A friend of mine got a F1-09 and it made a good impression. And since I can use most of my Tamiya parts and bought one.
Ok, time for my first question:
Does anybody has experience with the spur gears from Kawada?
With these the diff balls are not on one circle but on two. Also the number of diff balls is higher than with the original Tamiya ones. So it should run more smoothly.
Also the spur gears lack molding to keep the ball bearing in the outer diff part in place (I hope you understand what I mean).
Best regards,
orci77
orci77 is offline   Reply With Quote
Old 05-30-2010, 09:37 AM   #980
MonkeyNuts's Avatar
Cheers InZane, i've ordered the castor block and ill probably just leave it at that for the moment and see how i get on with the car.
Liam
Tamiya FF03 Pro ~ Tamiya M06 Pro ~ Tamiya M05L JCW Coupe
MonkeyNuts is offline   Reply With Quote
Old 05-30-2010, 01:52 PM   #981
Taman's Avatar
Trader Rating: 64 (100%+)
Thanks for the pic Inzane
does anyone know of an EBay seller who is selling the alloy castor block, cant seem to find one?
Taman is offline   Reply With Quote
Old 05-30-2010, 03:19 PM   #982
Barry White's Avatar
Originally Posted by jeff jenkins View Post
Just thought I would post a pic of my f109 . Just got done reconfiguring the layout so this is what I'm going to try this weekend and with the f104 front end on it and the 180mm track width makes it a little twitchy so I think this will makle it more stable with the battery this way.
Nice to see someone making an effort to make a proper 180mm wide car and not a dumbo 2010 200mm livery.
Barry White is offline   Reply With Quote
Old 05-30-2010, 04:04 PM   #983
bjholz's Avatar
So, will a silver can Johnson motor be fine for trying to get this car dialed in? And how will it effect the cars handling if you move up in motor speed? Or I could just throw my modified in there and then set the throttle to only like 50%
www.trackside.com
Old 05-30-2010, 10:29 PM   #984
Originally Posted by InZane View Post
The second Swedish F1Cup-race went pretty much the same as the first in Gothenburg - TQ, overall win and a new lap record in the A-main
Congrats on your win!
Sydewynder is offline   Reply With Quote
Old 05-30-2010, 10:59 PM   #985
Goingfast's Avatar
Trader Rating: 29 (100%+)
what is the stock F109 width wheel base?
Everybody is ignorant, only on different subjects.
AE 12R5.1,Tekin RS PRO
17.5 super stock T.O.P PHOTON , TAMIYA M05 Mini
CEFX.. High Velocity Racing Motor
Goingfast is offline   Reply With Quote
Old 05-30-2010, 11:31 PM   #986
Has anyone tried the F109 with rubber tires for the F103 instead of the conversion to the F104 tires?
Old 05-31-2010, 06:59 AM   #987
MonkeyNuts's Avatar
Also i was wondering what bodyshells fit the F109? do Tamiya ones fit and i see Protoform do a couple, do they fit as well?
Liam
Old 05-31-2010, 09:43 AM   #988
NiMo's Avatar
Yes, I have run the Cross wheels and tyres for the F103, but only in the wet, and I mean wet.
NiMo is offline   Reply With Quote
Old 05-31-2010, 10:19 AM   #989
PDM
Congratulations InZane. You're becoming a master in RC-F1.
Please share your car set-up with us.
PDM is offline   Reply With Quote
Old 05-31-2010, 12:18 PM   #990
bjholz's Avatar
Liam
Where did you find the castor block? Also, I have a low profile servo in my F109. Does the Tamiya F103 aluminum servo holder work on the F109 for the low-pro setup?
www.trackside.com
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12832 Today 08:18 PM
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
