Old 05-14-2010, 05:03 AM   #916
InZane's Avatar
I've made a simple Word setup sheet for the F1-09 - please feel free to use it if you like to share your setups.
Empty setup sheet >>
My winning setup from Gothenburg >>
InZane is offline   Reply With Quote
Old 05-14-2010, 04:31 PM   #917
bjholz's Avatar
Inzane, could you go into a little more detail how you did the CRC rear side spring mod? Maybe more pics?
www.trackside.com
FT SC10, FT B4, FT T4, b44.1
Tekin, Ace, Airtronics, Savx, Novak, Murfdogg, LRP
bjholz is offline   Reply With Quote
Old 05-15-2010, 06:53 AM   #918
InZane's Avatar
Read these posts;
3racing F109
3racing F109
3racing F109
The CRC mod is kinda self explanatory - as long as you don't attempt anything similar to this
Old 05-16-2010, 02:03 AM   #919
AGNO's Avatar
Default Spring preload
If you are interested I use this system to adjust the preload spring.
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 05-16-2010, 04:01 AM   #920
InZane's Avatar
So simple - why didn't I come to think of that
You're a genius
Old 05-16-2010, 08:15 AM   #921
AGNO's Avatar
You're a genius
I am happy that you liked my solution
I'm waiting Shimizu racing rubber tire, the try with your setup, you did you try? Or would you prefer to ride?
Old 05-16-2010, 10:12 AM   #922
bjholz's Avatar
So why you you think they went with an FRP chassis instead of carbon fiber? Will someone make a carbon fiber chassis for this car?
www.trackside.com
Old 05-16-2010, 10:58 AM   #923
mac853's Avatar
Talking
Not really necessary!
mac853 is offline   Reply With Quote
Old 05-16-2010, 12:08 PM   #924
InZane's Avatar
I've never tried Shimizu rubber, only Ride Medium (Swedish F1-Cup control tire) and Tamiya soft. Ride has OK grip and very good wear rate as Tamiyas has excellent grip but melts away even in low temperatures.
I guess they tried both carbon and FRP and found - not to my surprise - FRP the better choice. Price was probably also an issue of course.
Carbon could be beneficial if the track surface is flat and traction is extremely high.
Old 05-16-2010, 12:36 PM   #925
j.d.roost's Avatar
Trader Rating: 28 (100%+)
We tested a set of trg hard-f superion-r rubbers yesterday back to back with my f103(with 104 decks) and my buds 109 and the cars were dialed (asphalt).
Could use a bit more steering so I ordered a set of med.fronts.
Tire wear was good and the soft rears held up better than I thought they would. After about 50 laps you can still see the seam.
j.d.roost is offline   Reply With Quote
Old 05-16-2010, 07:29 PM   #926
bjholz's Avatar
I don't know how the car comes stock. My car is coming in the mail tomarrow. Does the kit come stock with rear side springs? Like the set up in this picture here, it looks almost stock.
www.trackside.com
Old 05-16-2010, 08:46 PM   #927
robk's Avatar
Trader Rating: 22 (100%+)
Inzane's post has most of the relevant information unless somebody wants to do a step by step photo tutorial. The picture you quoted probably works fine as well, but may be inconvenient to tweak with.
The car has no tweak control stock, you just put the springs in the cups and go for it
Old 05-17-2010, 01:00 AM   #928
AGNO's Avatar
Is a simple modification that allows you to quickly adjust the spring preload side.
You add two screws and conical washers, to speed up the adjustment you can remove the spring holder screw and paste it on the engine frame.
Old 05-17-2010, 01:07 AM   #929
The Ride and Tamiya should be identical as Ride made the Tamiya tires for the F103. They were the same as the Tamiya only the side markings were rebadged.
Old 05-17-2010, 02:14 AM   #930
InZane's Avatar
Identical? - Not mine anyway!
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13719 10-18-2017 11:54 PM
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 02:12 PM
Tamiya F103 Forum TFR Electric On-Road 2241 09-14-2017 12:57 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
