Old 05-10-2010, 12:41 PM   #901
Originally Posted by InZane View Post
The first Race in the Swedish F1 Cup was held this weekend at West-8 track outside of Gothenburg.
Nice job!!!
Where I can find your SE rules for F1 racing?
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 05-10-2010, 04:12 PM   #902
GasGod's Avatar
Originally Posted by j.d.roost View Post
Good job !
Sounds like you had a fun weekend.
Car looks great.
Want to share your winning setup with us?
+1--I am having a real chore on asphalt--no rear bite.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 05-10-2010, 04:57 PM   #903
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
...The Ride medium rubber tires (control tire) worked really well with track/tarmac temperatures over 20C.
I see that the control tire uses the narrow (F10/F104) rear tires. Was that an issue for any of the "wide" cars like your F109 or the older F103s?
FS: Awesomatix A800A $325 shipped
Greg Sharpe is offline   Reply With Quote
Old 05-10-2010, 05:25 PM   #904
j.d.roost's Avatar
Trader Rating: 28 (100%+)
Greg,page back a few.
The ride rims are wider than the f104 rims. Sort of
a in-between of the 104 and 103 wheel.
I am keeping an eye on this thread too
Wish there was a U.S. importer of all of these parts..
j.d.roost is offline   Reply With Quote
Old 05-10-2010, 08:56 PM   #905
bjholz's Avatar
Would the futaba 9551 (low profile) servo work well in this car? or cant you use low profile servos
www.trackside.com
FT SC10, FT B4, FT T4, b44.1
Tekin, Ace, Airtronics, Savöx, Novak, Murfdogg, LRP
bjholz is offline   Reply With Quote
Old 05-11-2010, 12:41 AM   #906
tudor_47's Avatar
Originally Posted by M.Abramowicz View Post
Nice job!!!
Regards!
m.
Rules are here, in swedish..
http://pancarz.com/f1/index.php?opti...=12&id=740#741
"Tekniskt reglemente.
Samtliga på marknaden förekommande F1-chassien med dessa begränsningar;
Vikt: Min.1100 gram.
Motor: 17.5 BL eller 27 kolmotor
Elektronik: Fritt, reglage med dynamisk timinginställning är inte tillåten.
Battrier: 2s Lipo eller 6 cell NiMH.
Utväxling: Högst 60mm roll out."
comes to approx:
tecnical rules
All of the available F1 chassis with these limitations:
weight minimum: 1100gram
motor 17,5T brushless or 27turn brushed
electronics free, No dynamic timing allowed
batteries: 2 cell lipo or 6 cell nimh
maximum 60mmm rollout
further down one can see that the pancar style wheels are NOT allowed.
I'm sure inzane will present more details later...
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 05-11-2010, 08:11 PM   #907
bjholz's Avatar
do the aluminum front knuckles from 3racing for the F103gt work on the f103?
http://cgi.ebay.com/3-Racing-TAMIYA-...item3ef53f86c2
www.trackside.com
Old 05-11-2010, 08:41 PM   #908
bjholz's Avatar
Can someone please do a little more informative write up on how to do that CRC side spring mod?
www.trackside.com
Old 05-12-2010, 06:11 PM   #909
F1fletch's Avatar
And where to get the best rubber, wheels combo i;e Ride. etc?
F1fletch is offline   Reply With Quote
Old 05-13-2010, 05:50 AM   #910
InZane's Avatar
It's hard to give any guidance when it comes to rubber setups. Temperature and surface conditions affects the grip level a lot more compared to running foams.
My final setup this race was very similar to what i use indoors - much because the grip was decent in the afternoon when the tarmac got warmer (almost 30C). In the morning you had to run much softer springs in the rear - like 3Racing gold or Associated black 3.75Lb side springs if you had the CRC mod. I changed the centre spring from Tamiya yellow to red (same as the kit spring). i used 20wt oil in both shocks (side 1 hole, center 3 holes).
I put 40 grams of 3Racing's nice carbonlook lead weights in the rear to calm things down a bit.
Front end;
Associated .20 springs and Tamiya 3.5 offset knuckles. I've changed the king pin to a longer one (Zen) in order to use ride height shims (3.5mm).
0 caster (caster plate full forward, 0 camber and 0 toe in.
The black thing with the Inzane eyes is just a foam stop for the lipos. The chassis needs to be able to flex - check that the Lipo is mounted with some play up&down and side&side.
In order to make the upper plate moving/flexing more freely I've put O-rings on the thumb screws as well.
InZane is offline   Reply With Quote
Old 05-13-2010, 06:05 AM   #911
InZane's Avatar
We've had some problems with Ride wheel breakage.
You can use sanding bands from Dremel to make sleeves for the front wheels - I haven't had any problems after this.
Old 05-13-2010, 08:09 AM   #912
robk's Avatar
Trader Rating: 22 (100%+)
Good stuff Inzane!!
Old 05-13-2010, 11:48 AM   #913
j.d.roost's Avatar
If you notice all of the fast folks cars are works of art.
Good stuff Zane.
Old 05-13-2010, 08:05 PM   #914
bjholz's Avatar
Would 1/12 or 1/10 pan car wheels fit these cars?
www.trackside.com
Old 05-14-2010, 02:49 AM   #915
Nope.
I think you need some guy with lathe machine and do some allu option parts if you need pan car tires.
Or made custom rear pod for asso 10R5 axle from ae parts and some magics with front axle for pan car tire (another dimm of bearings).
Front king pin is 3mm and pan car (like ae or crc or whatever) is ~3.13mm so maybe with some work you can put there ae steering block with ae axle for tire.
Regards!
m.
Michal Abramowicz
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12846 Yesterday 08:07 PM
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
