Old 04-20-2010, 11:33 PM   #856
timmig's Avatar
Trader Rating: 25 (100%+)
Thanks--- a long way to ship springs--but I got em coming!!!
T
timmig is offline   Reply With Quote
Old 04-21-2010, 09:51 AM   #857
InZane's Avatar
Originally Posted by 4_cell_racer View Post
Inzane (or anyone) can you post a copy of the instructions for the Out Tuned Ball Diff for F104 as mine has come with NO instructions
Cheers
Lee
Here's a scanned copy - I made a note about the "adjustment nut". Mount it almost flush with the threads and tighten the diff with the 4mm lock nut until it feels OK (as close as you can). Then use the adjustment ring for fine tuning at the track.
InZane is offline   Reply With Quote
Old 04-21-2010, 09:57 AM   #858
Thanks InZane......much appricated
And thanks for the heads up on the adjustment nut
4_cell_racer is offline   Reply With Quote
Old 04-21-2010, 05:31 PM   #859
I just bought a used one of these and was wondering if anyone has a set up sheet for it or know a web site where I can get one?
I found one for the f104 but it's not quite the same
Also, I have never run a pan car before and was wondering if there is any site that will explain how different oil and springs will affect the handling characteristics without a lot of trial and error.
Any help will be greatly appreciated.
AlGio is offline   Reply With Quote
Old 04-21-2010, 06:21 PM   #860
i have some modify.
use 2 26mm metal post instead of original upper deck post(plastic).
charge a battery like F104.
sIUcHuN is offline   Reply With Quote
Old 04-21-2010, 06:30 PM   #861
robk's Avatar
Trader Rating: 22 (100%+)
http://richardchang.com/hobby.php?topic=112setup
robk is online now   Reply With Quote
Old 04-22-2010, 04:11 AM   #862
Hey thanks Robk that is just the thing I was looking for.
Now for a set up sheet!
Old 04-27-2010, 06:28 AM   #863
Originally Posted by robk View Post
If he's running a 540J motor, the shafts are short to begin with. Moving the gear out will increase this problem. BL motor, regular brush motor = no problem
thanks, i finally decided to upgrade to BL motors, all good now.
ADHUI is offline   Reply With Quote
Old 05-04-2010, 08:32 PM   #864
PDR TOO's Avatar
Trader Rating: 24 (100%+)
Default Rear Links
ROBK,
Are you guys using the standard turnbuckles or replacing them with a longer aftermarket set?
I am new to the F1 and have been reading this thread for insights. I noticed a suggestion to use the forward hole for mounting the rear links. I tried this on the weekend but one side keeps letting go.
I did pull them appart completely to ensure I had an even amount of insertion at both ends of the rods.
I hve run the F109 a few times and have had difficulty keeping the tail under control. I have picked up some stiffer side springs and will try them next run.
I also had the unusual circumstance of the centre rolling damper coming undone during a run. Silicone is NOT good for traction.
SMA .....The Track.
Previously Raced Vehicles keep me on the track - sort of.
PDR TOO is offline   Reply With Quote
Old 05-04-2010, 09:04 PM   #865
robk's Avatar
Originally Posted by PDR TOO View Post
ROBK,
I happened to have a set of longer Associated turnbuckles on hand, so I used them. I wanted to put some titanium links on anyway.
Old 05-04-2010, 09:29 PM   #866
ROBK,
I used to have the same problem. my rear could not keep a straight path out of the corner when i just setup the car. The changes i made that slowly made my car was.
1. Stiffer Side Springs on the Rear
2. Toe Out 1 Degree
3. Switch to 2 Hole Roling Damper and Main Damper, Change oil to 50wt
4. Change to Stiffer Front Springs
and so far its handing a lot better than the beginning
note, if you are running on asphalt track be sure to use rubber tires, you get a lot more grip.
Funny, i also found that my rolling damper just jumped out during a pratice session. might be because of a little bump on the apex.
Old 05-04-2010, 09:31 PM   #867
I upgraded all my links to TI and I dont really see the difference, besides being lighter a couple of grams, what other advantage does it have?
Old 05-04-2010, 10:26 PM   #868
robk's Avatar
Less prone to bend
Old 05-04-2010, 11:12 PM   #869
PDR TOO's Avatar
Default Rear Links
robk/ADHUI,
Thanks for the info guys. I will get some longer links and try again.
My centre damper stayed in place, it's just the darn thing actually came apart and spilled silicone damper fluid all over the place - what a mess!!
I had changed the three hole psiton to 1 hole and put some XRay 40w damper fluid in to try and slow the movement in the rear a little. Hopefully the springs I picked up today will assist.
Thanks again.
SMA .....The Track.
Old 05-05-2010, 12:38 PM   #870
3rd-dan's Avatar
Hi guys,
first of all i did not read the hole thread.
shame over me.
now i have some questions perhaps you can help.
im now an owner of this car.
i have read that the front end of the f-103 will fit. is that correct?
because i want to try out the upper arms of the f-103.
would you recommend that or is it better to stay with the original front end?
i found a gpm upper arm set for the f-103.
see the pic, will this fit?
also i want to install the Adjustable Front Castor Mount Version 2.
is this possible to fit this with the gpm upper arms or do this castor mount would only fit with the f-109 upper arms?
and how can i adjust the front ride hight?
thanks for answers.
Cheers Mike
3rd-dan is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12814 Today 11:01 AM
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
