Old 04-09-2010, 10:23 PM   #826
Maxxican's Avatar
Trader Rating: 65 (100%+)
i just finished building mine last thing to do is paint the body. Has anyone painted or dyed the white plastic parts (part c). i saw on the 3racing web site in the gallery they have one painted red. Will regular lexan paint stick to this material? It seems a little rubbery...
thx
-C
Carlos F.
RoadRunnersRC.com
RC AMERICA || XRAY || HUDY|| ACTIVRC || HOBBYWING NA || PROTOFORM
Maxxican is offline   Reply With Quote
Old 04-09-2010, 10:45 PM   #827
timmig's Avatar
Trader Rating: 25 (100%+)
Originally Posted by reconrc View Post
hey guys.
after racing my f109 for first time, i'm looking to install rubber tyres. what would be the best way, without having to change arms, etc. originally i was going to put f104 rubbers on, but i hear the offset is too small. so now thinking about trg rims/tyres, will they be a good fit? im assuming f103 rims/tyres will be better/easier fit than f104? (also what are some good tyre brands?)
You might try the HPI F10 rubber tires on F104 wheels--they may fit on this car!! And the compounds are VERY sticky. They have Soft and Medium available. Fronts and rears.
FYI
Tim
timmig is offline   Reply With Quote
Old 04-09-2010, 11:41 PM   #828
Originally Posted by InZane View Post
The new 3Racing diff makes changing tires and diff adjustments a breeze. No more disassembling - just turn the inside alu ring for tightening/loosening the diff.
You will need to shorten the original diff axle or use a F104 shaft - the diff fits both F1-09 and F104.
That is sweet. Why didn't I see that when I was ordering up mine? I didn't realize how ummm, "less than ideal" the F109 diff design was until I started checking it out during assembly. I see this diff upgrade as essential IMO.
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 04-10-2010, 01:31 AM   #829
Will it fit the F103 ???
sidecarphil1 is offline   Reply With Quote
Old 04-10-2010, 06:15 PM   #830
hey all i have been driving this kit for weeks now and i keep having problems with a fast sweeping corner. a f103 owner recommended me to get a rear diffuser. does it work that effectively and will it fit in a 109?
or any other solutions?
thanks
ADHUI is offline   Reply With Quote
Old 04-10-2010, 07:42 PM   #831
Foxxrocket's Avatar
thanks
What is the car doing? And is it tight or loose?
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 04-10-2010, 07:50 PM   #832
my car keeps oversteering, ive setup my diff to a configuration that does not spin out as much now that i am confortable with but its still a little twitchy at the rear at high speeds. (loose corner)
Old 04-11-2010, 12:57 AM   #833
treemagnet's Avatar
Trader Rating: 17 (100%+)
Default stuff
just wondering where everyone buy their spare parts from?? and also does F103 rims and tyres fit on a F109? cause F104 tyres are bit taller hey??
sorry for the newbie questions
cheers
treemagnet is offline   Reply With Quote
Old 04-11-2010, 03:44 AM   #834
cheers
f103 tires fit just fine. I buy from RCMART, most f103 parts are interchange with f109.
Old 04-11-2010, 05:28 PM   #835
robk's Avatar
Trader Rating: 22 (100%+)
thanks
Rear diffusers work. I made one out of sheet lexan, and back to back tests with and without proved it works.
Old 04-11-2010, 08:19 PM   #836
FYI
Tim
no, can not, HPI F10 rubber tires can not fit on F104 wheels.
because F104 wheel have large diameter.
if you want to use HPI F10 rubber tire on F109, need to buy ride wheel.
please see it.
also, would you conside to pit tire? it is better than HPI F10 rubber.
sIUcHuN is offline   Reply With Quote
Old 04-11-2010, 09:32 PM   #837
superspeed's Avatar
superspeed is offline   Reply With Quote
Old 04-13-2010, 07:10 AM   #838
InZane's Avatar
Default Ride tire test
The winter has been longer and colder than usual here in Sweden but finally most of the snow has melted away and with temperatures above 10 Celsius (50 Fahrenheit) you don't have to wear gloves anymore when outside.
This weekend I had the opportunity to test medium Ride rubber tires - these will be the control tires for the Swedish F1-Cup. My expectations wasn't to high because of the cold weather but I was pleasantly surprised by the amount of grip the Ride tires provided. I don't think lap times will be more than a sec. slower compared to foam tires. Set up was identical to what I use indoor/carpet which felt OK as a starting point but can probably be improved with some more testing..
InZane is offline   Reply With Quote
Old 04-13-2010, 07:27 AM   #839
j.d.roost's Avatar
Trader Rating: 28 (100%+)
InZane,are you running the 104 ride tires?
If so how does it handle on the 109 with the incorrect rear offset?
j.d.roost is offline   Reply With Quote
Old 04-13-2010, 08:08 AM   #840
InZane's Avatar
It handles great! The F1-09 outperforms my F104 with Ride medium rubber . The rear offset isn't way off as the Ride wheels are a bit wider than the original Tamiya F104 wheels. You can put shims between the hub and the rim and get very close to original width if you like.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13184 05-26-2017 10:50 PM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
