Old 04-06-2010, 12:57 PM   #811
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
i have converted the front end of my f109 to the front end of the f104 pro. this makes it 180mm front and rear while using the f104 rubber rims and tires. easy mod as everything bolts right on.
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 04-06-2010, 01:07 PM   #812
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
I want to do the same thing because I like the look of the modern F1 cars. Please post up when you race against the full width 109s. I want to hear how well it handles compared to them.
If only endurance racing was a thing.
Greg Sharpe is offline   Reply With Quote
Old 04-06-2010, 01:15 PM   #813
GasGod's Avatar
Greg-- You are already running a f104
Guess I'll have to beg Kitchen -and borrow his 104 kit rubbers for a test spin--He has no inserts in them tho---Will this matter?
Anyone in the US carry TRG or Pit's?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is online now   Reply With Quote
Old 04-06-2010, 01:15 PM   #814
RC MARKET's Avatar
yes HK many peoples same !
RC MARKET is offline   Reply With Quote
Old 04-06-2010, 01:19 PM   #815
GasGod's Avatar
^^^ Huh????
Same what---peoples???--
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
Old 04-06-2010, 02:21 PM   #816
j.d.roost's Avatar
Trader Rating: 27 (100%+)
I spent most of the day looking for f103 (f109) rear rubber aside from the super soft trg tires I have now.
No luck.....
I could not find a trusted overseas store that could get me anything aside from the trg "s" by the 24th (Jackson race). Looks like we might have to rethink the rubber tire idea if we can't get them. There is no way a 103 will handle good with a shorter AND narrow wheel base. I think the 109 is a bit longer ..no? BTW the trg's were $50.00 a set(4) + shipping ( Do you know how many foam tires I could buy with that ).From what I was told on the 103 thread they are so soft they are only good for a few runs..Sort of defeats the purpose of switching to rubber.
j.d.roost is offline   Reply With Quote
Old 04-06-2010, 02:51 PM   #817
well the f104 seems to do just fine with the narrower width 180mm . also with the f104 front end on the f109 the wheelbase stays the same. but this way you can easily get ahold of some rubber rims and tires.
Serpent project 4x
Old 04-07-2010, 04:59 PM   #818
GasGod's Avatar
JD-- We may be sticking w/ foams @ T&L-once the sealer is down-Monday hopefully-I think foams will be the way to go--.The oval guys have no problem w/tire wear on lilacs(spec for them)and good traction now and last year.
Rubbers are turning out to be a real PITA (supply)And Tamiya rubbers (104)only are avail in stock compound.We will see-running this week without sealer and next wk with sealer.
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
Old 04-08-2010, 02:51 AM   #819
InZane's Avatar
Default 3Racing Out Tuned Ball Differential
The new 3Racing diff makes changing tires and diff adjustments a breeze. No more disassembling - just turn the inside alu ring for tightening/loosening the diff.
You will need to shorten the original diff axle or use a F104 shaft - the diff fits both F1-09 and F104.
InZane is offline   Reply With Quote
Old 04-08-2010, 11:48 AM   #820
j.d.roost's Avatar
OOOOAAAAA, I am getting that for sure.
Old 04-08-2010, 11:50 AM   #821
j.d.roost's Avatar
I agree.
Sounds good.
Old 04-08-2010, 07:10 PM   #822
J.Dy's Avatar
Originally Posted by InZane View Post
That's a large mini-z diff!
R1wurks Competition Products
ABC Hobby USA
J.Dy is offline   Reply With Quote
Old 04-08-2010, 07:14 PM   #823
DRAG_ON's Avatar
can that differential fit into tamiya f103 directly?
Freq:29.945, car no:29, W.A.R.C.M.C.C, http://projectm-design.blogspot.com/
DRAG_ON is offline   Reply With Quote
Old 04-09-2010, 07:53 AM   #824
NiMo's Avatar
Directly no, but if you cut a short portion off the rear axle on the diff side then yes.
NiMo is offline   Reply With Quote
Old 04-09-2010, 06:40 PM   #825
hey guys.
after racing my f109 for first time, i'm looking to install rubber tyres. what would be the best way, without having to change arms, etc. originally i was going to put f104 rubbers on, but i hear the offset is too small. so now thinking about trg rims/tyres, will they be a good fit? im assuming f103 rims/tyres will be better/easier fit than f104? (also what are some good tyre brands?)
reconrc is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12644 01-20-2017 08:56 AM
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 04:37 PM
SEO by vBSEO 3.5.0
