Old 02-17-2010, 09:27 AM   #691
Originally Posted by robk View Post
I just use tamiyas
Which Tamiya uprights? The white F103 version? What about the aluminum ones I saw on mac853's car?
I'm getting ready to purchase a F109 kit and am trying to piece together the necessary upgrades. I'm new to the F1 class so I'm not super familiar with all the Tamiya kit versions.
What parts do I need to build up the stiffer Tamiya front suspension assembly? I was going to use the 3Racing alum adj. caster mount for the F103GT is this the correct one?
Also the alum servo saver arm, should I just use the 3Racing one that fits my servo? Or are their different ones? Is there a better servo saver to use, say a Kimbrough or ??? I will be using a standard sized Airtronics servo.
I've read through almost all of this thread but some of it makes references that I'm not familiar with. I would appreciate any assistance in sorting out the suggested upgrades. Since it looks like the only way to get one of these kits is to order from overseas I'd like to put together a single order of the kit plus upgrade or tuning parts.
Also, I see the steering servo mounted in a variety of positions, which is better?
Thanks in advanced for any advice.
DM1-S Tekin 2650Kv
MTX-3 MR .12
TA05 IFS-R Tekin 17.5
TA03R Cirtix 17.5 club spec
F109 Tekin 21.5
danketchpel is offline   Reply With Quote
Old 02-17-2010, 10:07 AM   #692
Andy p's Avatar
Hi danketchpel
You seem to have it sussed i have the ally caster adjuster its a must i think as i have seen a few broke , also the saver is good idea as the kit is to flexy a Kimbrough one will be a good idea , i think i have a hot boddies one ! i have the ally uprights but i have never fitted them as i have never broke them! spur gears are a good spare as i have also seen a few stripped , i use 48dp as i had a rack of pinions , the spares are pretty cheap so maybe a diff re build kit for later might be handy and ti turnbuckles for the top arms! I got a low profile servo for mine as i found a std size with luggs cut off still was a bit tight and the low profile lines the steering arms up better
Hope this helps
Andy p is offline   Reply With Quote
Old 02-17-2010, 11:34 AM   #693
any one want an almost new one
pm me
i am selling my redbull replica as i have too many cars and not enough time !!
sad really as i like it but cant have everything !!!
sidecarphil1 is offline   Reply With Quote
Old 02-17-2010, 02:21 PM   #694
I'm looking at the various upgrades for the front suspension. Will the parts for the Tamiya F103RM/GT fit onto the F109 Chassis? Specifically I'm considering the following:
1. 3Racing alum caster block set
2. 3Racing front suspension kit (Made from Delrin)
3. 3Racing alum uprights
4. ??? for servo saver, what's best? Use the Tamiya Aluminum horn with the Tamiya high torque assembly?
I was looking at the Zeppin completely aluminum servo saver also.
Any feedback? Particularly for items 2-4.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 02-17-2010, 03:26 PM   #695
robk's Avatar
Trader Rating: 22 (100%+)
The stock upright from tamiya for the f103/f104 fits fine, it's the white one. The black one in graphite for the 15th anniversary also fits.
The caster adjustment block is great. Buy it.
Didn't know they had a delrin front end, but if it's stiffer than the stock pieces, that is good.
Don't know about aluminum uprights. Tamiya parts work just fine.
A Kimbrough medium servo saver should work fine as well as the Tamiya setup.
Old 02-17-2010, 05:27 PM   #696
Thanks for the feedback Robk
It's so hard to figure this stuff out if you don't have it front of you or have lots of experience with those particular models.
I'm still trying to sort out the F103, F103RM, and F103GT.
Here's what I found about the 3Racing Delrin front end. for the F103RM
It also comes with a set of 3 different front spring rates.
Maybe the Tamiya parts would be better as they are easier to find replacements in the US. If I use Tamiya front suspension parts, should I just pick all the stuff from the F103?
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 02-17-2010, 07:04 PM   #697
robk's Avatar
If you can find the link type suspension from the F103GT, that is the same as the 3Racing w/o camber adjustment. The parts will even interchange.
Old 02-17-2010, 08:08 PM   #698
malcnz's Avatar
pics of F60 on F109.
3racing F109-dscf0272.jpg   3racing F109-dscf0277.jpg   3racing F109-dscf0273.jpg   3racing F109-dscf0276.jpg
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 02-17-2010, 08:35 PM   #699
malcnz's Avatar
some better pics
3racing F109-dscf0285.jpg   3racing F109-dscf0286.jpg   3racing F109-dscf0284.jpg   3racing F109-dscf0282.jpg
Old 02-17-2010, 10:58 PM   #700
malcnz,
Nice!
What front suspension setup are you running on your F109? It looks exactly like what I'm planning on putting on mine.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 02-18-2010, 12:22 AM   #701
malcnz's Avatar
Thanks,
std F109 arms but have the alloy caster set up with I think .20 associated springs to firm it up and Ti turnbuckles with the 3Racing alloy knuckles.
Old 02-18-2010, 07:02 PM   #702
malcnz,
What length Ti turnbuckles are req'd for the steering links? I can't find the manual online anyplace or find a suitable parts callout which lists it. It looks like the short ones for the camber link are 3 x 15mm.
I wish I could find a manual or exploded view parts list someplace.
Can anybody say which is a better place to order from? I'm considering RC-Mart and RC-Mushroom right now. I'd like to use one that also has most of the upgrade stuff also so I can get it shipped all together. I'm ready to pull the trigger on this.
DM1-S Tekin 2650Kv
MTX-3 MR .12
F109 Tekin 21.5
Old 02-18-2010, 11:32 PM   #703
tudor_47's Avatar
malcnz,
manual: http://web.comhem.se/~u21703609/F109.pdf
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 02-19-2010, 06:35 AM   #704
Smile
HIHI, this is my new F109.
i using Tamiya F104 Front suspension set, which include upright, steering pins, and steering arm.
3racing F109-p1020854.jpg   3racing F109-p1020853.jpg   3racing F109-p1020835.jpg
sIUcHuN is offline   Reply With Quote
Old 02-19-2010, 07:52 AM   #705
mac853's Avatar
Exclamation
That kind of my car is from 3racing.
mac853 is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13719 10-18-2017 11:54 PM
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 02:12 PM
Tamiya F103 Forum TFR Electric On-Road 2241 09-14-2017 12:57 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
