Old 02-11-2010, 07:42 PM   #676
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by robk View Post
As far as the front end lower arms shifting, I think I have a solution that might work. The problem looks like the 2 slots that run parallel to the 2 front end 4mm screws. I drilled the ends of the slots for a 3mm grub screw, and then tapped and installed like a 5mm long grub screw. This should lock down the front end by pinning the ends of the slots. It seems much more solid now, but I will have to track test it. Will post pics later.
Old 02-12-2010, 02:24 PM   #677
GasGod's Avatar
Is it me or is putting a silvercan/w stock wires(outta the box) into the rear pod a PITA.
Had to take the top plate offand bend the tabs a little.
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is online now   Reply With Quote
Old 02-12-2010, 11:15 PM   #678
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Yeah, when we assembled Papo's car in that mad rush to make the main, disassembling the pod put us back a couple minutes.
Why don't we endurance race more often?
Greg Sharpe is offline   Reply With Quote
Old 02-13-2010, 03:27 AM   #679
Dan415ms's Avatar
Guys,
I have 6 F1-09's here, myself and a colleague are building them for an event we're doing in April in a shopping centre.
We are using 540 type motors and wonder if anyone can advise what size pinion (64DP as using kit spur gear) to use? I know we're probably limited by the space available when the motor is furthest away on the mount from the spur.
Any advice welcome.
Thanks,
Dan
Dan415ms is offline   Reply With Quote
Old 02-13-2010, 08:11 AM   #680
Andy p's Avatar
Hi Dan
I use silver can motors what the club limits us too ! i run 48 dp i use a 75 spur and around a 18 pinion give or take a few teeth depending on the track this gives me a final ratio of 4.17 . if you look on the back of the instrctions it tells you 98 spur (kit) and 23 pinion witch works out at 4.26 final ratio ! I wouldnt say you will be far out with what it tells you
Andy p is offline   Reply With Quote
Old 02-13-2010, 09:51 PM   #681
GasGod's Avatar
Is there a known issue with the stock uprights ?
I broke 2 one with a slight brush of a pipe and another with a light hit.It seems they are made of plastic rather than a nylon composit like the t-brand.
Another racer also broke one with a light hit,the kits were both from the same batch so it may just be a random thing but all 3 broke exactly in the same place and in the same pattern of shearing-- weird.Another small PITA is the rear pod motor acsess and the spur hitting the rear link when trying to pull out the axle.
Other than that I love the performance/price point.Very smooth and predictable;we race silvercan.
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
Old 02-14-2010, 09:37 AM   #682
robk's Avatar
I just use tamiyas
Old 02-14-2010, 09:50 PM   #683
PAPOSWING's Avatar
Trader Rating: 18 (100%+)
Default front rideheight
Does anyone have any idea what can be done to the f109 to adjust the front rideheight?
PAPOSWING is offline   Reply With Quote
Old 02-14-2010, 10:35 PM   #684
spacers between the arm and the spring
it makes the front springs arder though
or cut your tyres down
sidecarphil1 is offline   Reply With Quote
Old 02-15-2010, 04:57 AM   #685
HaraR40's Avatar
Trader Rating: 33 (100%+)
TRG front end
Is this an option you can buy. looks cool
Full alloy Micro-t, orion 10,300kv brushless
Corally RDX PHi Drifter - 8.5T Lipo
Axial AX10 Crawler, Vanquish chassis/knuckles, tekin FXR/35t, lipo, DNA dig, HB rovers...
HI Blitz ESE, 10.5T, Lipo
HaraR40 is offline   Reply With Quote
Old 02-15-2010, 05:02 AM   #686
How much (why so expensive) and where ?
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-15-2010, 01:30 PM   #687
robk's Avatar
http://www.rc-trg.com/
Old 02-15-2010, 01:32 PM   #688
robk's Avatar
You can remove about 2mm of material from the bottoms of the steering knuckles, and use a spacer on top of the knuckle to run smaller tires. That's about it, short of custom milling.
Old 02-15-2010, 08:28 PM   #689
PAPOSWING's Avatar
THANKS!!
Old 02-16-2010, 01:44 PM   #690
malcnz's Avatar
For anyone interested I have managed to fit the F60 body onto my F109 and will take pics once completed..hopefully later today..10.30am here in NewZealand...front and rear wing lined up perfectly and lucky they give you the extra pods if you need extra electronic room as F104 much narrower at the back and you need to place rear body posts in more ontop of the battery top plate but easy stuff really and then you cut off the old post holders as they get in the way of the body on the sides and I even managed to squeeze in my Havoc speed controller which isnt small so smaller electronics will be even easier..well worth it as way cooler than the factory body
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13719 10-18-2017 11:54 PM
Tamiya F104 Pro! NT Electric On-Road 9387 10-18-2017 02:12 PM
Tamiya F103 Forum TFR Electric On-Road 2241 09-14-2017 12:57 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
