Old 01-30-2010, 07:21 PM   #616
racer x 1's Avatar
Trader Rating: 27 (100%+)
sumtimes it not how hard the hit is but where the hit was. most cars have weak spots and maybe thats jus one for this car sadly.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 01-30-2010, 10:37 PM   #617
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by sidecarphil1 View Post
The hole in the chassis is too close to the edge of the chassis I think that if I use the front hole and a longer reaction rod then I may not need a new chassis
I cannot believe such a small hit on the wall did so much damage
I will speak with my importer and see what happens
I can tell you the worst damage always comes with "light brushes". The cars are designed to crash head on, but catching an axle or wheel on a barrier is almost always bad news. I have seen a lot of tc cars lose a wheel and arm/knuckle/caster block from brushing a wall.
Old 01-31-2010, 01:16 AM   #618
Send a message via MSN to PMSorber
I expect a new chassis will be there before you know it
Looks like this was a result of too loose links or binding links. On the other side I would always make the links long, its better for the cars stability.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 01-31-2010, 02:20 AM   #619
Are you saying that the length of motor turnbuckle has a important impact?
+ length= car is understeer
- length = car is oversteer
kryss is offline   Reply With Quote
Old 01-31-2010, 03:25 AM   #620
Had a little time on my hands so made a ' How to make a flashing LED set' tutorial for my F1 take a look it only takes 10 mins to build one
http://thercracer.blogspot.com/2010/...-tutorial.html
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 01-31-2010, 04:30 AM   #621
InZane's Avatar
I must say that I really doubt this will work - the pivot points for the middle ball and the side link balls must be in line ... or is it just me that's stupid?..most probably
InZane is offline   Reply With Quote
Old 01-31-2010, 04:59 AM   #622
InZane's Avatar
Originally Posted by gsxr0311 View Post
inzane, can you tell me what crc parts u upgraded to your car ? how many part # is there. i dont have a crc but want to do the upgrade to myf109 so i dont want to miss any parts on the order, thanks
1295 - Side Spring- Blue - Soft
1296 - Side Spring- White - Med
1256 - Chrome Pivot balls (optional, if you use these you will need two short 4-40 flat head screws as well)
1287 - Metal Spring Holders (holders and long 4-40 tweak screws) or the 3387 - molded spring holder - but then you have to buy the tweak screws (1391) separately.
You can find most part here >>
or here >>
Old 01-31-2010, 07:10 AM   #623
robk's Avatar
The longer the link from the chassis to motor pod, the more rear stability.
This is why the 12R5, GenXL and others now feature extended links.
I would run the forward holes on the chassis for lower traction.
Old 01-31-2010, 07:57 AM   #624
InZane's Avatar
To me this sounds hard to understand - possibly because of my limited intelligence
Doesn't the three "hinge points" have to be in line. I can buy the idea to extend the links - but only if you move the link balls at the other end.
For me the three hinge points are similar to a door - the right door should be hard to move ... or am I totally lost?
Bad photoshop job by me ...
edit ...
Of course I'm aware that a linked motor pod and a door differs in that a door only swings in one direction (open- close) while the movement of a linked motorpod is up&down and side to side. But the off line hinge problem is anyway the same - In My Very Humble Opinion.
Old 01-31-2010, 08:16 AM   #625
I am a happy man chassis replaced and I am running the rear motor pod supports in the front holes Tyres taken down 1.5mm and the ride height is 4.5 front 5.0 rear and using a 17.7 motor on my SPX the 3Racing F1-09 is running really well
sidecarphil1 is offline   Reply With Quote
Old 01-31-2010, 10:35 AM   #626
Ok day over , went well with no breakages I put the SPX in with a 17.5 the brushed silvercan was just too slowfor me and Joey , we were struggling with grip roll a lot , so I placed a 1mm spacer under the side springmounts to make the rear a little stiffer and it seem to work , the car iswell planted and drives well , I just need to be sure of not hitting the barriers
Old 01-31-2010, 12:17 PM   #627
gsxr0311's Avatar
Trader Rating: 19 (100%+)
thanks a lot inzane for the parts list.
gsxr0311 is offline   Reply With Quote
Old 02-01-2010, 03:09 PM   #628
Hi!
Can I replace front steering blocks by this part:
http://www.rcmart.com/catalog/rc-f10...9-p-27565.html
Or which one from tamiyas will fit F109?
Regards!
m.
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 02-01-2010, 03:22 PM   #629
Trader Rating: 131 (100%+)
those will work. I ordered mine from 3racing and installed them last week. Fit with no issues.
Originally Posted by M.Abramowicz View Post
Hi!
Regards!
m.
skyline1015 is offline   Reply With Quote
Old 02-01-2010, 03:23 PM   #630
robk's Avatar
edit ...
It's like a camber link, in that there is less migration the longer the link. The effective length of the link changes less when it is longer.
In the end though, the link just locates the rear axle in terms of alignment. The links are free radially and axially, so they are not like a door which only rotates. There may be issues beyond this, but I'm not sure what they are
I do have my car like this right now (long link), and it works fine.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13626 Yesterday 08:04 AM
Tamiya F103 Forum TFR Electric On-Road 2242 09-14-2017 12:57 PM
Tamiya F104 Pro! NT Electric On-Road 9377 09-05-2017 08:04 AM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
