Old 01-22-2010, 01:02 PM   #571
Originally Posted by skyline1015 View Post
IAlso, it seems that no one has spur gears in stock. What else can be used?
Hi!
I wait for my own F109
But about spur gear, you can use any one from E12 chassis, at last
event, I give to my friend 94T/64p from HPI/HB (violet one) and it was OK.
Regards!
m.
ps: I think that 64p from Kimbrough will fit (I use them in my asso 12R5.1).
Michal Abramowicz
http://abram.eu.org/gear_tc6.php
My setups there -> http://www.rc-setups.com
TC6!, TC5R, 12L4, 12R5.1, 10L2, 10R5, RC8T_CE_EL custom F1 chassis
http://www.wgtshop.com/
M.Abramowicz is offline   Reply With Quote
Old 01-22-2010, 02:43 PM   #572
malcnz's Avatar
I just finished putting the car together last night and I have a couple of questions. Will the mesh wheels for Rubber (F104) fit in the F1-09 without any mods? Also, it seems that no one has spur gears in stock. What else can be used? just looking to have spares.
thanks again
I have the F104 rubber rims/tyres on my F109 and they fit fine..you will need bigger bearings for the front compared to the supplied 3racing foam rims/tyres and lucky I had some as typical Tamiya size ...looking at the car the front is wider but as mentioned this could be a good thing.
Does make the ride height a lot taller as the rubbers are a bit bigger than the foam tyres and this is at its lowest setting so dont know how this will affect the handling as still waiting on my lowpro servo to arrive.
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 01-22-2010, 03:07 PM   #573
Trader Rating: 126 (100%+)
You are correct sir. I just tried the rubber from my F104 and they fit with no issues. Now i checked the manual to see what size the bearings are but it doesnt give me the info. Do you know what size they are?
Also, I was looking into getting this spur gear.
http://store03.prostores.com/servlet...h%2C-96/Detail
will it fit?
skyline1015 is offline   Reply With Quote
Old 01-22-2010, 03:26 PM   #574
Anders Myrberg's Avatar
Does the wheels from HPIs F1 fit into the 3Racing?
Anders Myrberg is offline   Reply With Quote
Old 01-22-2010, 04:10 PM   #575
veecee's Avatar
Trader Rating: 34 (100%+)
I think HPI F10 front and rear wheels run hexes. So rears will probably fit but not the fronts.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 01-22-2010, 04:31 PM   #576
malcnz's Avatar
[QUOTE=skyline1015;6892753]You are correct sir. I just tried the rubber from my F104 and they fit with no issues. Now i checked the manual to see what size the bearings are but it doesnt give me the info. Do you know what size they are?
Bearings are 5x10 according to my verniahs...
Old 01-23-2010, 04:42 AM   #577
AGNO's Avatar
Excuse me, what are the toughest springs kit?
Team GMV / RC electric AS Laurenziana
Hot Bodies TCXX - HW Xerun - IP - Spec-R
AGNO is offline   Reply With Quote
Old 01-23-2010, 05:16 AM   #578
NiMo's Avatar
No
HPI wheels run 12mm hex's, same as the older F201 and most 1/10th Touring Cars
F109 runs 14mm Hex's on rear, bearings on front
NiMo is offline   Reply With Quote
Old 01-23-2010, 05:17 AM   #579
NiMo's Avatar
[QUOTE=malcnz;6893065]
Correct, F104 uses 1050 bearings, so 5x10
Old 01-25-2010, 12:50 AM   #580
Hello from France,
just ran 2 packs for a try!!!
It was on a very long permanent track.
I put some Paragon only on the rear tyres (3Racing box tyres, 56mm diameter front and rear).
The front has too much grip. I decrease steering travel from 100% to 40%, and put front hard team Asso springs. It was a little better.
But not so good, the car was very difficult to drive. I reduce the front diameter to 53mm, and then, it was a big improvment.
But sometimes, on little bumps with steering, the rear end wants to overtake the front one.
I feel like rear dampers doesn't drive anything!!!
I ran the main damper with stock spring/stock oil/3 holes.
I switch to stock spring/500 Xray oil(little thicker)/2holes.
It was a little better, but difficult...
The rolling damper was stock. I switch to 1 hole piston.
But I think, rolling springs are much too soft and rolling damper too.
I will order some CRC parts (thanks InZane), and for now, switch to 1.000 oil.
The car isn't good for the moment. It's not a real pleasure the drive yet, but it's on the good way!!!
With my 8.5t, I ran 20/80 with 56mm diameter. It was too short for my big track. I change to 24/78. Very good with low temps on speedo/motor (11C in the air). With my 4.200mAh/35C, I ran around 12mn.
My next test will rear damping tests and learning how to put Paragon, because For the first tests I wait only 15mn before driving, and after, some guys tell me it's minimum 30mn!!
Au revoir.
Romuald
romuald31 is offline   Reply With Quote
Old 01-25-2010, 04:51 AM   #581
seanikaido's Avatar
Send a message via MSN to seanikaido
Originally Posted by romuald31 View Post
Hello from France,
Au revoir.
Romuald
Hey Romuald,
What kind of surface have your track? Asphalt?
International Racing Team Member #196
== Tamiya TRF-415MSX / TA-02 ==
== Team Losi Mini-T HOPped! ==
== 540-J! ==
== ESC Novak Tempest Pro / LRP IPC V7.1 ==
== Integy 3300 / Pro-Match 4200 ==
== Spintec Battery Manager/Novak Smart tray ==
seanikaido is offline   Reply With Quote
Old 01-25-2010, 08:45 AM   #582
Anyone know the part numbers for the front alloy suspension parts and where to get them ? cannot find them listed on the uk importers website.
Xray X1 "16" driven by an idiot, me
weekendracer_uk is offline   Reply With Quote
Old 01-25-2010, 09:35 AM   #583
Si.Fennell's Avatar
If you cant find the parts your looking for from Much-more give Abe-racing a try
Si.Fennell is offline   Reply With Quote
Old 01-25-2010, 10:51 AM   #584
gsxr0311's Avatar
Trader Rating: 18 (100%+)
does anyone know what other bodies fit on this car ? thanks.
gsxr0311 is offline   Reply With Quote
Old 01-25-2010, 11:22 AM   #585
gsxr0311's Avatar
also, can someone confirm that there is no way to adjust the front ride height of this car ?
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13160 Today 11:58 AM
Tamiya F104 Pro! NT Electric On-Road 9356 Yesterday 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
