Old 01-10-2010, 09:30 AM   #511
Hello Can anyone tell me where to buy the set screw and bearings to complete of the F109?
sergi82 is offline   Reply With Quote
Old 01-10-2010, 04:30 PM   #512
zpmhinojosa's Avatar
Send a message via AIM to zpmhinojosa
3Racing
zpmhinojosa is offline   Reply With Quote
Old 01-11-2010, 07:32 AM   #513
Are there some adaptator to fit GT200mm body ?
Like this prolineracing.com/products/Mulsanne_LMP_Clear_Body-73-47.html
Could you put the F103Gt front bumper on it ?
DarkRedemptor is offline   Reply With Quote
Old 01-11-2010, 07:59 AM   #514
NiMo's Avatar
no to the bumper as it uses a Touring Car fitment.
wheelbase may be too long for the Mulsanne?
NiMo is offline   Reply With Quote
Old 01-11-2010, 10:20 AM   #515
Default Missing Part
Guys, I need some help. My F1-09 kit was missing one of the 4.7mm female threaded ball studs for the "drag links" to the pod from the main chassis. Where can I get one?
Matt Chester is offline   Reply With Quote
Old 01-11-2010, 01:56 PM   #516
abe-racing's Avatar
hi matt,
contact your seller or give me the part number and i will see what i can do about getting 3racing to ok me sending you one foc...
email me at sales at abe-racing dot com
ta
lee
ABE-Racing,Team Orion, Blakey Designs, Xray RcDisco,T-Shox
abe-racing is offline   Reply With Quote
Old 01-11-2010, 02:12 PM   #517
Originally Posted by abe-racing View Post
hi matt,
ta
lee
Thanks abe-racing.
I bought it from RC Station in Hong Kong. I didn't want to have to wait who knows how long to get one little 4.7mm ball. I was hoping there was something that could be substituted from another kit or something.
I will find the part number and post it up.
Old 01-12-2010, 12:15 AM   #518
Default 3 Racing F109 Spur Gear Choice
Hi All,
I am new to this forum and have been reading through this thread about the 3Racing F109. I am considering buying one of these but have a question about changing the spur gear to 48 pitch rather then using the 64 pitch as I will be racing outdoors.
Has anybody used a 48 pitch spur gear that fits into this kit without any modifications such as spacers etc.
Cheers
Nic
nbusetti is offline   Reply With Quote
Old 01-12-2010, 02:53 AM   #519
Trader Rating: 52 (100%+)
you can use 48 pitch...the kit utilizes the 3 racing adapter ring in the center hole of the spur gear...any robinson racing spur should be usable.
rcracer1958 is offline   Reply With Quote
Old 01-12-2010, 02:55 AM   #520
Pattojnr's Avatar
Trader Rating: 19 (100%+)
guys i been playing around out the front with the car. out of the box it wasnt so great. just slid everywhere. there isnt much grip out front, but my gas cars are still drivable out there.
i played last night with a few things. i left the side damper stock. i used the silver springs in the spring kit for the sides, stiffened it up a bit. went to zero droop on the back with shock spring adjustment. car was better.
but the biggest change was to use one of my Gas springs on the shock. Serpent front short orange spring. http://www.serpent.com/product/160302/
this with Zero droop made the car more stable under power around a corner.
a tight diff setting also helps. a loose diff tends to spin the wheel up easier closest to the spur.
i felt the car was pretty good like this. then i added 60 grams of weight on the back near the wing. the car is very good now. this is with std tires on the car.
i have a new set coming for this weekend if they get here in time
but the car shuold be really good with a track with some grip
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-12-2010, 10:23 AM   #521
Originally Posted by zpmhinojosa View Post
3Racing
Hi, i dont see the link in the web 3racing, could you tell me in the private message these link of the screw kit and the bearing kit for the 3racing f109???
Thanks!!
Old 01-12-2010, 11:17 AM   #522
wallot's Avatar
3 races on carpet. 3x 2nd place (out of 15). no mater how I play with the adjustments it is always about the tires. I tired heavier battery, lighter battery, side springs, central spring, weight on the rear pod no real change. the car works with right tires. (38shore front, 30shore rear no traction compound allowed until next race - carpet small tight track with couple high speed sweepers). once I have the right tires I play just a bit with front toe to get more or less steering depending on the track profile
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 01-12-2010, 11:37 AM   #523
InZane's Avatar
Three second places ain't bad - first win will surely come soon.
For me the stiffer side springs/heavier side shock oil made a BIG difference in handling.
@sergi82 - I think you can use this bearing set for the F1-09
InZane is offline   Reply With Quote
Old 01-12-2010, 01:42 PM   #524
then the bearing kit is the same for the f109 and the f103??
and the screw set??
Thanks for help me
Old 01-13-2010, 01:41 AM   #525
Hello from France,
I receive my F109...
- F109
- EC Power 8.5t
- 4200mAh/35C LiPo
- Ko 2413
- Titanium turnbuckles
- 48dp spur gear
- ceramic balls
- Blue alu castor mount
- blue alu servo horn
- Team asso front hard spring
Next mods:
- blue alu front knuckles
- ball and cup without play!!!
- black wiring....
Au revoir.
romuald31 is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12860 Today 02:54 PM
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
