Old 01-06-2010, 11:39 AM   #496
abe-racing's Avatar
yes mate same fitting....
ABE-Racing,Team Orion, Blakey Designs, Xray RcDisco,T-Shox
abe-racing is offline   Reply With Quote
Old 01-06-2010, 11:50 AM   #497
jeff jenkins's Avatar
Trader Rating: 74 (100%+)
thanks for the quick response. this is good to know. sorry for all the questions but this is my first f1.
Serpent project 4x
jeff jenkins is offline   Reply With Quote
Old 01-06-2010, 11:53 AM   #498
I fancy one of these, any in the UK?
DA_cookie_monst is offline   Reply With Quote
Old 01-06-2010, 11:54 AM   #499
looks like abe-racing.com is in the uk so yeah easy for you to pick one up.
Serpent project 4x
Old 01-06-2010, 12:09 PM   #500
abe-racing's Avatar
yes we are in the midlands,
if you need anything let me know.. via email or support chat on our site
you will find our prices comparable with ebay/hk
Old 01-06-2010, 12:10 PM   #501
I seen, do you have any in at the moment though?
Old 01-06-2010, 12:11 PM   #502
abe-racing's Avatar
we got a shipment of kits due this week its just sitting in customs and will also replace all our spares that are out of stock
Old 01-07-2010, 08:05 AM   #503
Pattojnr's Avatar
Trader Rating: 19 (100%+)
what pistons and oils is everyone using ?
got mine today, just about done. (minus electronics)
i used the kit oils, i used the 2 hole piston for the damper, and 2 hole piston for the mono shock. i got springs, but used kit stuff. i feel a harder torsional spring is needed, and softer front ? Cheers for any advice , thanks guys.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-07-2010, 09:53 AM   #504
racer x 1's Avatar
Trader Rating: 27 (100%+)
im running on high bite asphalt and i have 50weight in both shocks three hole piston in the center and one hole in the side damper.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 01-07-2010, 11:52 AM   #505
this is my setup for a big and fast track, cold, outdoor
front:
Caster: maximum
toe: a little IN
camber: -0.5 / -1
add washer to decrease gap in wheel axle
spring: box
tyre: box
steering: exp -20%, dual rate 65%
wing: box
rear:
steel axle (for weight and reliability). increase rear stability
main damper: 30wt 2holes, yellow yeah racing spring (softer than box)
side damper: 30wt 3holes
side spring: box
height: -1
tyre: box
wing: max downforce, and add a rear wing
body:
front lateral wing: none
rear lateral wing: use
hole for ESC
electronic:
10T ezrun, without fan, 3.6 ratio (tamiya 0.6 gear)
standard servo
DX3.0
it works well.
kryss is offline   Reply With Quote
Old 01-07-2010, 04:24 PM   #506
I've got an excellent condition low mileage F109 for sale if anybody is interested. just send PM and I'll be glad to provide the specifics.
vafactor is offline   Reply With Quote
Old 01-09-2010, 12:09 AM   #507
Pattojnr's Avatar
i just gave the car a small test run out the front , with out the body on.
i got the EC 60amp brushless ESC and 11.5 motor. and using a 25C 3800 lipo.
used a 23t pinion with the stock spur. havent played with any of the speedo setting card as yet. but at first i thaught it has good acceleration, but it peaked to early. a heap of steering (way too much) so i turned down my end points on my radio, and i saw throttle set at 42% so i put it too 100%
the thing lights up the tires if you pull too hard on the throttle, with decent speed about 1/4 throttle, you hit the throttle and man it just lights up the tires again already going at about 40km/h. dont have a long enough bit of road, but its still winding up with abuot 40 meters of road. may have to go to the 21 pinion i have . but the car feels very responsive. its hard to get the sensor wire to the motor at the rear, but that should smooth it out some more.
its all about throttle control
and ill have a play with the speedy settings with the card.
Serpent - Walter RC
Old 01-09-2010, 01:00 PM   #508
pinggoy's Avatar
Trader Rating: 24 (96%+)
Send a message via Yahoo to pinggoy
wow.. must be a very fast F1
TAMIYA TRF415 MRE l NOSRAM SPX l BALLISTIC 17.5
TAMIYA TRF416X
www.noicewatches.bigcartel.com
pinggoy is offline   Reply With Quote
Old 01-10-2010, 06:09 AM   #509
Pattojnr's Avatar
it is it is.................
Serpent - Walter RC
Old 01-10-2010, 09:40 AM   #510
NiMo's Avatar
I see the drivers already lost his head
NiMo is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12642 01-15-2017 02:18 PM
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 04:37 PM
SEO by vBSEO 3.5.0
