Old 12-26-2009, 11:44 AM   #436
SMG
Dumb question, Can someone tell me what roll out means when it comes to gearing. I am currently running 28/98 gears thanks
SMG is offline   Reply With Quote
Old 12-26-2009, 03:38 PM   #437
JSeay's Avatar
Send a message via Yahoo to JSeay
Rollout is most commonly used with foam tires. For the sake of this conversation if your tires were 26mm your rollout with you current gearing is 23.34mm which mean for every revolution of the motor your will have traveled 23.34mm.
Because foam tires have appreciable wear compared to rubber tires you will find that users of foam tires:
1. Have to change gearing more often to compansate for changing tire diameters.
2. Often times refer to their gearing in terms of rollout rather than FDR, which will allow you to calculate a similar gearing based on your tire size.
To calculate your rollout you can go to www.gearchart.com and enter in your specific information and get your actual rollout information. You can then use that information to compare with other foam tire users for the motor type you are using to get to the desired gear ratio.
If your area use rubber tires and still refer to their gearing using rollout all is not lost you only need to know the tire diameter they are calculating with and plug that data into the website and you will get the information that you are looking for.
†Tracks: SDAR San Diego Asphalt Racing/Discount Hobby Warehouse†
†Team HOLY Rollers† †www.socal-rc.com - Southern California R/C Forums†
†My Blog: http://majicmanracing.wordpress.com/†
JSeay is offline   Reply With Quote
Old 12-26-2009, 06:36 PM   #438
SMG
Default Thanks
Jseay, thanks alot for your help!
Old 12-26-2009, 06:38 PM   #439
old-man's Avatar
Originally Posted by racer x 1 View Post
hey does anyone know the diameter of the trg rubber tires?
56mm diameter for rears and fronts.
OM
old-man is offline   Reply With Quote
Old 12-26-2009, 10:48 PM   #440
Blueman Austria's Avatar
Hy there !
Does the F109 body and wingset fit the F103 without any issues ?
Pics would be nice !
Greetz Blueman
_______________________________________________________________________
TT01, F104, TRF415MSXXMRE07, TB Evo5 Exoten, TB Evo6, TRF417v7, TRF 418........
Blueman Austria is offline   Reply With Quote
Old 12-27-2009, 12:26 PM   #441
Here is a build thread and Review of the F109
http://thercracer.blogspot.com/2009/...nd-review.html
Hope its useful
http://www.theRcRacer.com/
TRF419, TBEvo6, TT02, VDF, TRF501x, TRF201, TRF101, Mi5, X-Ray T4-13, BD7 2014, A700 Evo, WR-02G
Qatmix is offline   Reply With Quote
Old 12-28-2009, 07:00 AM   #442
I'm trying to find a Servo for the F1-09.
Should I try to find a Low Profile like the S9951 or a Std Size?
Has anyone tried the Hitec HS-77B, its a low profile decent spec, analog servo that only cost $26. Would that work well?
What do you guys suggest. I'm new to on-road carpet racing.
Matt Chester is offline   Reply With Quote
Old 12-28-2009, 07:46 AM   #443
Dan the Man's Avatar
Trader Rating: 40 (100%+)
Anyone recommend what size 48dp spur gear to replace the kit one with?
|-●-|Hot Bodies Pro 5 |-●-|Hot Bodies D8 GT-E|-●-|The "F109X"|-●-|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 12-28-2009, 08:35 AM   #444
InZane's Avatar
The lower the better! - I can recommend the BlueBird BMS-761DD for the F1-09 (it's like 0.10 on 6V).
Kimbrough 48DP, 72T-78T - that's what I use ..
InZane is offline   Reply With Quote
Old 12-28-2009, 08:48 AM   #445
Is that a pretty tough servo? Or should I buy a couple of gear sets too?
Its out of stock everywhere I have looked.
Any other options?
edit: found the metal gear version at bphobbies.com for only $22. Thats a steal.
Old 12-28-2009, 09:02 AM   #446
InZane's Avatar
Any other options?
I don't think the gears will be a problem - my guess is that electronics will be the weak point in a lower budget servo like this.
Instead of buying spare gear sets i have a new servo (metal gear version) in my pit box.
Low profile servo is the best choice for the F1-09 IMHO - but beware, not all low profile servos are equally low!
Old 12-28-2009, 09:14 AM   #447
InZane's Avatar
Originally Posted by romuald31 View Post
Hello from France,
Joyeux Noël to everybody...
The old man bring me the fabulous F109 kit!!
But because of you Inzane, I receive a lot of things...
- 3R F109
- Combo EC Power 60A + 8.5 t brushless motor
- 2 LiPo 7.4V/4200mAh/35C
- Ko 2413 low profile servo
- 3R blue caster alu mount
- 3R blue front knuckle arms
- 3R blue alu servo saver
- 3R full Ti turn-buckles
- 3R rear shaft (2 spare parts)
- Kawada 48dp 20/22/24/26t pignons
- Kawada 48dp 74/76/78/80t spur gears
- ceramic dif balls
- 3R F and R tyres
- tyre truer F1 adaptater
- Paragon
- Team Asso front hard springs
and soon:
- another LiPo pack
- CRC springs mod
It will be my first electric kit!!!
I enjoy to see this kit. I will begin the construction soon.
Au revoir
Looks like a killer car - Happy New Racing!
Originally Posted by Qatmix View Post
I'm enjoying racing my f109, the car seems to be hooked up really well out of the box. Here is a pic of the car
My blog will have set-ups and reports from the racing series I will be in. The build thread will be ready in a day or so as well
Cheers
Excellent step by step building guide - everyone buying a F1-09 should pay your blog a visit..... hmm ... you "stole" my next paint scheme ...
Old 12-28-2009, 09:19 AM   #448
Yeah, probably right. How long have you been using yours and what is your experience with it? Does it center well?
I went ahead and ordered a Metal Gear version, total cost including Shipping was $29.XX, pretty good deal if the servo turns out to be a good one.
Old 12-28-2009, 09:26 AM   #449
InZane's Avatar
Good luck with the new car/servo. After +5 hours and a lot of very tough "product tests" my BlueBird servo still centers perfectly (I'm using the kit saver)
Oh .. I forgot to link to Qatmix's blog
Old 12-29-2009, 11:27 AM   #450
Nice Jaguar Qatmix! and good step by step
romuald31, where do you find the ceramic dif ball for kawada 48DP?
For the servo's center problem, i had it on begining. i resolved the issue by adding some few glue on mount and between chassis and servo. it works well.
kryss is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13183 Today 06:00 AM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
