Old 11-21-2009, 08:45 AM   #331
RC MARKET's Avatar
Originally Posted by InZane View Post
First track tests today with my F1-09, I'm impressed - Very Impressed!
This car has great potential. Definitely equivalent with my Tamiya F104Pro - and that's BOX STOCK!
Good show !
3 racing F109 was back in stock !
RC MARKET is offline   Reply With Quote
Old 11-21-2009, 05:41 PM   #332
cheehtae's Avatar
Trader Rating: 15 (100%+)
the only thing thats making me don't want to buy this is the parts support. Are the parts easy to come by now or is it interchangeable to the other f1 cars?
every impulse that we strive to strangle broods in the mind, and poison us...action is a mode of purification... the only way to get rid of temptation is to yield to it.
cheehtae is offline   Reply With Quote
Old 11-22-2009, 04:13 AM   #333
old-man's Avatar
Practically all F103 parts can be used with exception to chassis and top deck.
old-man is offline   Reply With Quote
Old 11-22-2009, 04:26 AM   #334
NiMo's Avatar
I am running mine with the F104 rear axle and diff unit (same having to rebuild and reste diff when changing a wheel) and have also fitten the whole front arm section from the F103 (someone broke their front end and didn't want to fit 103 front end, so I sold them mine as I have plenty 103 fronts)
Chassis plates and rear motor pod are the only things that are truly F109
All axle and shaft parts can be swapped with F103.
Am looking to milling out spare 103 axle height parts to fit Pro10 bearings so a pro10 rear axle can be fitted (allows for wider damp tyre choice)
NiMo is offline   Reply With Quote
Old 11-22-2009, 10:57 AM   #335
hairy's Avatar
Originally Posted by GSM Storm View Post
Hi all
Well I gave the car a run on the weekend, very hot day on a outdoor track, the track had good grip, the car had too much steering, very easy to get oversteer and the back would slide out.
I tried some weight at the back and it did help, but still need more rear grip.
The setup was out of the box, has anybody run the car on a outdoor track ?
I am making rear hubs to take jaco tires, the same as the other drivers are using on there cars, this may help.
In the last run I lost one of the rear side springs, does anyone know a replacement I can use.
Regards
Gary
These cars are made to steer by design. If you are loose put stiffer springs in the front, and consider softening the side to side movenment.
although you will only want to make one change at a time. good luck
MERLIN RACING
"He once ran a marathon because it was on his way"
Logic is a lost art!
You are defined in life by how you respond to defeat!
hairy is offline   Reply With Quote
Old 11-22-2009, 12:44 PM   #336
NiMo's Avatar
I went the other way to make the car more stable:
CRC red springs for side springs, and put them under tension to reduce side to side slop, this makes it feel more like the rear end of my GenX10.
Also I put on some older F103 offset front hubs, again like my GenX10.
And reducing that front castor makes a huge difference, it stops pulling the rear end round.
Also notice play in the rear arms where the cups sit on the balls, so am looking to convert this to the GenX10 style, cos I had to tension them today to get the car to go straight and not wander between on and off power.
Old 11-22-2009, 08:38 PM   #337
robk's Avatar
Trader Rating: 22 (100%+)
You can also cut small squares out of a plastic bag and snap the ball cup over the ballstud covered by the plastic
Old 11-22-2009, 09:35 PM   #338
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default Works great
Hi all
Well I made the hubs to suit the Jaco tires, purple front and pink rear, it still had too much steering and the back was sliding out, I changed the shock spring to a yellow Tamiya one I had a it was great, that made all the difference.
Using the yellow spring with the kit tires mite work also, will have to try that.
Does anyone know the shock and side damper oil weight that comes with the kit and Lbs of the shock spring that's comes with the car, would like to try one a bit harder than the original and a bit softer than the yellow.
I will post some pics of the hub tonight.
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 11-23-2009, 01:27 AM   #339
GSM Storm's Avatar
Default Jaco Tires rear hubs
Hi all
Here are the pics of the wheels on the car and the hubs I made, the rear pod has been lifted up 2mm and the front end has been lifted 4mm to give the car a 5mm ride height.
Regards
Gary
3racing F109-f109-pics-001.jpg   3racing F109-f109-pics-002.jpg   3racing F109-f109-pics-003.jpg
Driver Gazza
Old 11-23-2009, 04:04 AM   #340
HaraR40's Avatar
Trader Rating: 33 (100%+)
Default setup
hey guys. My kit should be here any day.
Can someone who runs theres on a medium grip slightly bumpy asphalt track please post there setup? i know how different pan style cars are on road compared to carpet.
i also bought a tamiya spring set and the front spring set for the F109
thanks
Alex
Full alloy Micro-t, orion 10,300kv brushless
Corally RDX PHi Drifter - 8.5T Lipo
Axial AX10 Crawler, Vanquish chassis/knuckles, tekin FXR/35t, lipo, DNA dig, HB rovers...
HI Blitz ESE, 10.5T, Lipo
HaraR40 is offline   Reply With Quote
Old 11-23-2009, 02:13 PM   #341
mac853's Avatar
Cool
My car had done in few hours before, take a look, please!
3racing F109-dsc05085.jpg   3racing F109-dsc05089.jpg   3racing F109-dsc05090.jpg
mac853 is offline   Reply With Quote
Old 11-23-2009, 04:22 PM   #342
SMG
What kiit do Tamiya yellow springs come from and where can I find some of those rear hubs? Thanks
SMG is offline   Reply With Quote
Old 11-23-2009, 04:40 PM   #343
GSM Storm's Avatar
Default Spring and hubs
The yellow tamiya spring is there standard TC spring, the hubs are a one off, I designed them and turned them up on a lathe, if a few people want them I may make a few sets, there is a lot of work in them.
Regards
Gary
Driver Gazza
Old 11-24-2009, 04:02 AM   #344
cheehtae's Avatar
Regards
Gary
how much? and will they also wok with an f103? interested, please LMK o PM me.
Old 11-24-2009, 06:16 AM   #345
InZane's Avatar
What can I say? - absolutely beautiful! You're setting the standard for the rest of us. I really like the small details like the blue front arm turnbuckles.
InZane is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12855 Today 02:27 PM
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
