Old 11-10-2009, 10:00 AM   #301
rack's Avatar
Trader Rating: 64 (100%+)
Originally Posted by NiMo View Post
not had time to test with rolling damper.
All I know is that with kit oil the rear walked, with heavier oil it was a nightmare, so i removed it and it was almost ok.
I also trid 2mm spacers on the side springs, but this made it swap ends to easily coming in to corners.
Someone suggested braking for the corners, but I never brake for corners with the GT car so want to get this F1 car to be the same.
I am using the stock center oil and side damper oil but I am using a silver tc3 center spring and up front .20 1/12 speedmerchant spring up front. I am also using the tamiya 84070 body set for the f103 type C. this give you more stable rade . I am using the stock tires on carpet. it really works well.
rack is offline   Reply With Quote
Old 11-10-2009, 10:53 AM   #302
NiMo's Avatar
I did actually wonder in the shell shape was a problem?
The side pods do seem high at the front
NiMo is offline   Reply With Quote
Old 11-10-2009, 01:29 PM   #303
monkeyracing.cz's Avatar
RCMART restocked ... http://www.rcmart.com/catalog/rc-3ra...cPath=420_1417
3 hours back there was 30+ on stock, now 18 kits, so hurry up! :-)
www.monkeyracing.cz | www.rallybrno.cz
monkeyracing.cz is offline   Reply With Quote
Old 11-10-2009, 10:00 PM   #304
SuperEk4's Avatar
Trader Rating: 32 (100%+)
i lost a front hinge pin for F109 front, i tried to use f103's hinge pin but cant as the top part cant fit the e clip. any idea can i use the f103rm?
Seems that theres no spares for this car yet.
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 11-10-2009, 10:14 PM   #305
GSM Storm's Avatar
Trader Rating: 112 (100%+)
Default F1-09
i only got in a short test before trying to race it (on a greasy track)
I got as far as 10g below the axle, and was thinking of more.
I am wondering if the rear wing has something to do with the rear end problems on F1 cars, cos most F1 cars have a similar problem, yet 200mm pan cars do not suffer from the problem.
Still looking at ways to put Pro10 wheels on the rear, as then I can run the Corally Silverstars which seemed to work on the pan cars that ran.
(pan cars that did not run them also had rear grip issues)
Hi all
I got my car yesterday and hope to give it a run on the weekend.
I am looking to make some new rear hubs to use the same tires as the Corally F1 uses, most of the guys here use Jaco tires so I want to do the same, are they the same mounting as the tires you are talking about ?
Regards
Gary
Driver Gazza
Offroad - RC10 B64 (soon)
Vintage - Kyosho Tomahawk
Fantom Racing, JConcepts, Ace Hobbies/Reedy,
WTF, Plaig Bearings.
GSM Storm is offline   Reply With Quote
Old 11-10-2009, 10:31 PM   #306
robk's Avatar
Trader Rating: 22 (100%+)
If you can get 1/12 donuts, those are the correct size as well.
Old 11-11-2009, 04:13 AM   #307
HaraR40's Avatar
Trader Rating: 33 (100%+)
Default spring set.
Going to order our F109's. just wondering.... The centre springs, i've read you can just buy the Tamiya touring spring set. Are they the standard length ones or the short spring set?
will these do:
http://www.rcmart.com/catalog/rc-spr...63-p-4863.html
or these
http://www.rcmart.com/catalog/rc-spr...3-p-23519.html
thanks
Alex
Full alloy Micro-t, orion 10,300kv brushless
Corally RDX PHi Drifter - 8.5T Lipo
Axial AX10 Crawler, Vanquish chassis/knuckles, tekin FXR/35t, lipo, DNA dig, HB rovers...
HI Blitz ESE, 10.5T, Lipo
HaraR40 is offline   Reply With Quote
Old 11-11-2009, 05:24 AM   #308
InZane's Avatar
I'm using this set - the red one is the same as the kit spring
rc-spring-tamiya-onroad-turned-hard-53440-p-17486
I guess these are the same but Milky blue (with a couloured dot) instead of colour coded.
rc-spring-tamiya-onroad-hard-milky-blue-49389-p-19463
InZane is offline   Reply With Quote
Old 11-11-2009, 05:27 AM   #309
HaraR40's Avatar
Default ...
thanks,
also. Is there a pdf manual around somewhere. I need to know what size clips and screws are so i can order spares. cant find manual on 3R's site
If not. can someone tell me what size (in mm) the e-clips are. and also what size the axles are so i can get some shims.
thanks
Alex
Old 11-11-2009, 07:47 AM   #310
NiMo's Avatar
Originally Posted by GSM Storm View Post
Hi all
Regards
Gary
Yes the Jaco tyre/wheel fittings.
I tried to use the ones from my CRC, tape brings the axle up to size on the non-diff side, but I can't get a fitting on the diff side.
I've not given up yet.
One guy in Germany made a batch a year back, but has sold them all.
and MLP have a car coming out shortly http://www.mlpmotorsports.net/page1.aspx and it has fittings for both pro10 and F1 wheels but says nothing about axle size, but being American it will probably be imperial size.
Old 11-11-2009, 08:29 AM   #311
gsxr0311's Avatar
Trader Rating: 18 (100%+)
what up rac ? yeah your car looked good. i put those springs in the front, looked better but not as good as yours. still have a push. ill keep trying.
gsxr0311 is offline   Reply With Quote
Old 11-11-2009, 10:22 AM   #312
rack's Avatar
If you are going to be at the track today I will have the rear springs for you and that should take away the push.
Old 11-11-2009, 01:43 PM   #313
racer x 1's Avatar
Trader Rating: 27 (100%+)
proud new owner of an f109
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 11-11-2009, 03:09 PM   #314
racer x 1's Avatar
does anyone have any building tips they would like to share?
Matt Bell
Old 11-11-2009, 03:48 PM   #315
Default building tips
yea i got one ! wait to you get one first ! lol
isuzuguy is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13497 Yesterday 11:09 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
