Old 11-07-2009, 10:08 AM   #286
NiMo's Avatar
Got to run the F109 for the first time today, outdoors on a very cold dirty track.
had problems with the car wandering in a straight line, tried some steering setting on the TX but it made no difference, so I tried a thicker oil in the side damper which made things even worse, so I removed the side damper just to try and it went in a straight line no problem.
Next came a problem with the corners as it appeared that the rear was lifting, so I placed 2x 5g weights on the lower rear pod below the axle line and that kept the rear firmer, so much so that I now have understeer in the corners.
Having now sorted the car with the kit foams (no treatment or additive) I set about running it with some old (about 12yrs) Tamiya Type A Rubbers, and once i got a few laps together to get heat in to them the car was surprisingly stable, if anything with a little too much understeer.
Motor is an unused Kyosho G20 Sealed Can motor as supplied with Kyosho RTR kits running on 31/93 gearing for a 155ft main straight.
Boy was it fun to drive
NiMo is offline   Reply With Quote
Old 11-07-2009, 11:21 AM   #287
wallot's Avatar
get better servo saver - i use kimborough 1/12 scale one and it helped a lot keeping the car going straight
DEX408 - Speed Passion Silver Arrow v2, LRP Dynamic 8
Dex410 V3 - Tekin RS Pro, 7.5t Redline
F1-09 - Tekin RS Pro, 17.5t Redline
Sakura Zero S - LRP Quantum, Saturn 20T
KoPropo Eurus
wallot is offline   Reply With Quote
Old 11-07-2009, 11:38 AM   #288
NiMo's Avatar
already fitted, with futaba 9550
Old 11-07-2009, 12:49 PM   #289
wallot's Avatar
servo saver not servo
KoPropo Eurus
Old 11-07-2009, 01:16 PM   #290
NiMo's Avatar
DOH!!! I am thick
Kimborough make servo's
Futaba make servo savers
Should I use paper instead?
I think after over 17 years of racing, and 6 Kyosho World Cup British Championship wins behind me I should know what I am on about
Old 11-07-2009, 05:33 PM   #291
rack's Avatar
Trader Rating: 64 (100%+)
I am running a futaba 9550 with a kimborough mid size servo saver and that seem to work a lot better than the stock one. I am running on carpet silver can.
rack is offline   Reply With Quote
Old 11-07-2009, 10:19 PM   #292
mac853's Avatar
Lightbulb
Why don't use Tamiya high torque with F104 HT servo saver?
I guess they are the best kind for F1.
mac853 is offline   Reply With Quote
Old 11-08-2009, 03:57 AM   #293
Had a first race with my F1-09 on foam tires. No traction compound allowed. Was not bad but others were faster. Did try ZEN 30shore rear tires with F1-09 fronts and wow -2.5s per lap (15.5 second laps)
Great race with almost 60 minutes of race time. Finished 2nd.
great result!!!... you were using the stock setup or you made some changes apart from the tires?
katze is offline   Reply With Quote
Old 11-08-2009, 04:06 AM   #294
SuperEk4's Avatar
Trader Rating: 32 (100%+)
So u were using rubbers or foam? I m trying foam. Putting 55 oil in my side damper.
Hv not tested the car yet
Hobbywing-Acorn Racing-ManiaRC-UpgradeRC-Hong nor-Rc monster-Blackbeard-Rc-MoosDesign-SweepRacing-Boca bearings-Tresrey USA-Velociti raceware-Tekno Rc-Team J-JPL Models-SNR Graphite (RETIRED)
SuperEk4 is offline   Reply With Quote
Old 11-10-2009, 06:17 AM   #295
SuperEk4's Avatar
tried the f109 with 55 wt side damper, rear still sliding. Tried 20gram weight on the rear was better.
will try 30 grams, on thur. Does anyone put weight on f109?
Old 11-10-2009, 06:41 AM   #296
NiMo's Avatar
i only got in a short test before trying to race it (on a greasy track)
I got as far as 10g below the axle, and was thinking of more.
I am wondering if the rear wing has something to do with the rear end problems on F1 cars, cos most F1 cars have a similar problem, yet 200mm pan cars do not suffer from the problem.
Still looking at ways to put Pro10 wheels on the rear, as then I can run the Corally Silverstars which seemed to work on the pan cars that ran.
(pan cars that did not run them also had rear grip issues)
Old 11-10-2009, 07:00 AM   #297
mac853's Avatar
Questions??
Then how about in rolling damper, if optional springs didn't come yet, will not able to using another oil?
Old 11-10-2009, 07:18 AM   #298
NiMo's Avatar
not had time to test with rolling damper.
All I know is that with kit oil the rear walked, with heavier oil it was a nightmare, so i removed it and it was almost ok.
I also trid 2mm spacers on the side springs, but this made it swap ends to easily coming in to corners.
Someone suggested braking for the corners, but I never brake for corners with the GT car so want to get this F1 car to be the same.
Old 11-10-2009, 07:33 AM   #299
SuperEk4's Avatar
I dunno how u guys drive it, I still spun out
Old 11-10-2009, 08:02 AM   #300
mac853's Avatar
Questions??
In fact i am just worried what else of shock oil could replace the kit 1 if it finished, in fact it is so few and little.
How about 10W shock oil?
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13473 Today 07:34 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
