Old 10-23-2009, 07:14 AM   #241
Trader Rating: 9 (91%+)
Anyone kow where this is available now? rctech is still out of stock. Also how does this car compare to the hpi?
interplanet is offline   Reply With Quote
Old 10-23-2009, 08:59 PM   #242
bsmooth's Avatar
Trader Rating: 17 (100%+)
rc-toro.com has them listed on the website, not sure if there are any in stock.
speedtechrc.com has some kits coming.
rcmushroom.com if you want to order overseas.
I'm still working the kinks out of mine, but i would compare it more to an f104 or f103 for race worthyness. The HPI car is gorgeous, but i'm not sure how race-worthy it will become. Dont let the price of the F109 fool you, the car is highly adjustable, and a lot of the rear end technology has been proven in pan cars.
-Steve
bsmooth is offline   Reply With Quote
Old 10-26-2009, 02:45 AM   #243
Ordered mine from rc-union.com
Ackord02 is offline   Reply With Quote
Old 10-26-2009, 03:55 AM   #244
rack's Avatar
Trader Rating: 62 (100%+)
today was my first racing day with the f109. I really like the car the only thing is the plastic ball cup as a little soft but I was able to keep up with the f103 & the f104.
rack is offline   Reply With Quote
Old 10-26-2009, 05:09 AM   #245
I received my F109 from Mushroom RC in only a few days. that's pretty amazing that shipping from China to US could be so quick. The back end of the car is super nice. But I do have question about the front end. It too is really nice aside from one troubling issue. The slider that allows caster adjustment moves fore-aft as intended. But it also is possible to twist it sideways without applying too much force at all. When it moves sideways, the caster goes way up on one wheel and way down on the other. Obviously that's going to be a problem on the track if a little bump throws the alignment so far out of whack. Anybody found a solution for this Issue? Does the aluminum slider fit more snug than the plastic one so that it's more resistant to the twisting motion? I'd rather not JB Weld this thing into a fixed position, so I'm looking for suggestions on how to make the slider stay straight so that the car will hold it's front end alignment.
vafactor is offline   Reply With Quote
Old 10-26-2009, 08:57 AM   #246
bsmooth's Avatar
Yep.
I've noticed that too. 3Racing as well as Tamiya make an aluminum one for the F103 that will work.
Old 10-27-2009, 03:09 AM   #247
old-man's Avatar
Anyone knows which other online hobby shops has this in stock?
RCmart, RC-Mushroom, RC-torro, rcunion is out of it.
regards
OM
old-man is offline   Reply With Quote
Old 10-27-2009, 05:27 AM   #248
for anyone looking to buy;
they seem to still have some in stock,
brockmodels.com
Old 10-28-2009, 06:25 AM   #249
antonio_cadiz's Avatar
my on board in 3racing f1.
http://www.youtube.com/user/tiranoAC#p/u/0/X4b0Zv8RKIQ
antonio_cadiz is offline   Reply With Quote
Old 10-28-2009, 06:44 AM   #250
Greg Sharpe's Avatar
Trader Rating: 15 (100%+)
Originally Posted by antonio_cadiz View Post
That's just totally cool!
If only endurance racing was a thing.
Greg Sharpe is offline   Reply With Quote
Old 10-28-2009, 03:56 PM   #251
InZane's Avatar
My F1-09 is sloooowly taking shape ...
InZane is offline   Reply With Quote
Old 10-28-2009, 07:58 PM   #252
ChadRacing's Avatar
Does anyone know what springs i can use to change the roll springs on this car to stiffen it? The option springs are not out yet.
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 10-28-2009, 10:19 PM   #253
robk's Avatar
Trader Rating: 22 (100%+)
Go to nexus and get CRC #1280 side springs and 3387 molded spring retainers. You'll need 2 4-40 screws, decently long to use as tweak screws. The hole for the grub screw which secures the pin for the top deck hinge goes all the way thru, so you can use this for a tweak screw hole. You'll need to cut down the pins for the top deck, and secure them. I JB Welded them in the hole.
You'll need to dremel off part of the spring cup on the bulkhead to clear the spring retainer. Remove the spring retainer on the lower pod plate. Then screw the 4-40 screw into the bulkhead, screw on the CRC spring reatiner and attach the CRC side spring. I used red for carpet, but there is a good selection in the kit. You now have a wide variety of springs and also tweak control for the car.
Last edited by robk; 10-28-2009 at 10:21 PM. Reason: Note: Car needs a visit to the air compressor
Old 10-29-2009, 02:15 AM   #254
old-man's Avatar
Robk,
Thanks for the tips. Though I have not got my kit yet this is something I will probably do.
BTW, the signal wire of the esc looks damaged from rubbing on something.
regards
OM
Old 10-29-2009, 06:21 PM   #255
racer x 1's Avatar
Trader Rating: 27 (100%+)
where are you guys getting tires for this car? and can anyone compare this car to the f104 pro, im looking for the pros and cons of this car because im stuck in between the two cars.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12642 01-15-2017 02:18 PM
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 04:37 PM
SEO by vBSEO 3.5.0
