Old 10-15-2009, 04:10 PM   #196
veecee's Avatar
Trader Rating: 34 (100%+)
Originally Posted by rc-zombies View Post
I think it's Negative Caster.
isn't Positive Caster the top angle is forward and
negative is back.
I know it sounds odd but I'm pretty sure it's the other way around - ie positive caster = top of kingpin pointing towards the rear.
SMOKEM --- HIRO SEIKO --- YOKOMO
veecee is offline   Reply With Quote
Old 10-15-2009, 04:10 PM   #197
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
maybe sunday... but not sure yet..
You gotta do sat. No one goes sunday lol
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-15-2009, 08:19 PM   #198
ChadRacing's Avatar
Hey all....I know its not a good paint job likes BP's but here is my F1-09
3racing F109-001.jpg   3racing F109-002.jpg   3racing F109-003.jpg   3racing F109-004.jpg
ReVtech / Trinity / EAMotorsports
HotShot RC / Nexus Racing
Xray T2 '009 w/Exotek Chassis, BMI DB12rr, Tamiya F104X1
Team Durango DEX210
ChadRacing is offline   Reply With Quote
Old 10-16-2009, 07:22 AM   #199
rack's Avatar
Trader Rating: 64 (100%+)
have anybody race there F109 against a f103 or f104 . I would like to know how it did. I would also like to know if any one try the car on carpet.
rack is offline   Reply With Quote
Old 10-16-2009, 07:25 AM   #200
rack's Avatar
No it is neg is going to the rear of the car and pos is going toward the front of the car.
Old 10-16-2009, 07:55 AM   #201
antonio_cadiz's Avatar
nothing buy tire foam for f1- 09??????????
antonio_cadiz is offline   Reply With Quote
Old 10-16-2009, 09:20 AM   #202
InZane's Avatar
As soon as I can get to a track I will compare the kit tires with Tamiya foam tires (both A and B compound).
As for the caster discussion - the king pin should never lean forward. If you call this pos. or neg. isn't that important. Always run the king pin straight up or leaning slightly to the rear (at the top) - I'd call this positive caster.
"Caster is the angle to which the steering pivot axis is tilted forward or rearward from vertical, as viewed from the side. If the pivot axis is tilted backward (that is, the top pivot is positioned farther rearward than the bottom pivot), then the caster is positive; if it's tilted forward, then the caster is negative." - read more>>
InZane is offline   Reply With Quote
Old 10-16-2009, 09:53 AM   #203
bsmooth's Avatar
Trader Rating: 17 (100%+)
Ok, I'm in! I've got a kit coming to me that should be over the Pacific as we speak.
As far as servos, can anyone tell if the kit will only accept a standard size servo? I've got a Futaba S9650 that I use in my World GT car. Its got enough torque, just hope its not too small. I want to be ready to build when this thing hits my doorstep. Hopefully ill see a few of you at SWR this next Wednesday night.
...Scotty B, your up next!!
-Steve
bsmooth is offline   Reply With Quote
Old 10-16-2009, 09:56 AM   #204
Scott B's Avatar
Trader Rating: 43 (100%+)
-Steve
I'll just drive your's till I get one!!!
Mugen Racing USA, Sweep Racing Tires, R1 Wurks, Protoform, Speedworld Raceway...
"On-road is racing.. off-road is 50% competitive jumping and 50% crash avoidance"...
Scott B is offline   Reply With Quote
Old 10-16-2009, 10:04 AM   #205
NiMo's Avatar
-Steve
Servo sits in a mount and held with double sided tape, so if too small use extra layers of tape
NiMo is offline   Reply With Quote
Old 10-16-2009, 10:12 AM   #206
bsmooth's Avatar
Anytime!
Fyi, Todd H and I will be out there Sunday. I'm bringing my wgt and gas sedan.
Old 10-16-2009, 09:55 PM   #207
robk's Avatar
Trader Rating: 22 (100%+)
I should be able to get my car on the carpet track this weekend.
robk is online now   Reply With Quote
Old 10-16-2009, 10:04 PM   #208
bsmooth's Avatar
I'll try that. Thank you!
Old 10-16-2009, 10:13 PM   #209
robk's Avatar
In putting this car together, I noticed that the rear link setup is pretty close to the SpeedMerchant Rev style 1/12 cars. It also requires you to go through the same setup for the links to create a smooth suspension action.
The instructions tell you to set the links at the same length. This probably won't be correct however. Most of the time, if you do this, you will feel a "clicking" or a "catch" in the side to side action. To really feel what the car is doing, you need to have the links attached to the lower pod plate with no other parts on the pod plate, and the rear bulkhead with the center pivot attached to the chassis and lower pod plate.
It's fairly easy to take 4 screws out of the lower pod plate, and remove the motor mount and axle, upper plate, etc, all in one piece. With the lower pod clean, you can cycle the plate side to side and feel if the suspension is hanging up. If it is, and it probably is, you need to start adjusting one of the links. The idea is to go shorter or longer on this one link until the suspension feels very smooth and free and does not click or hang up at all. You will know which way to go by the fact that one way will make the car start to smooth out, and the other way will make everything much worse. It may take a bit of adjustment, but it will get there.
Once the car is feeling good, you just need to reattach everything and run. If you get into a good wreck, you may have to do this again, as the car may have shifted around. I know after I built my car per the instructions, it was pretty bound up feeling. It took a little cranking, but now it feels great.
Old 10-17-2009, 05:44 PM   #210
ChadRacing's Avatar
I ran my f109 on carpet today with no setup and was using a 540 johnson motor.
Bone stock out the box setup and the car was awesome. Hooked up very well. I was out driving the 12th scales running 13.5.
Great car, cant wait to actually put it in a race next week
Team Durango DEX210
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13488 Today 12:42 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
