Old 12-06-2014, 11:33 AM   #1936
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
I use 0,1, 0,2 or 0,3 tamiya shims on front axles so I can tighten the nut fully and have just micro side play. I use tamiya carbon reinforced uprights right now.
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 12-06-2014, 11:54 AM   #1937
longuylander's Avatar
The front wheels definitely need a little shimming to get rid of some of that play.
I think I ruined my rear grip by putting stiffer side pod springs. The differential is set as loose as can be without severely slipping, yet I still get instant on-power oversteer. It's too cold to test different setups now though.
longuylander is offline   Reply With Quote
Old 12-06-2014, 08:05 PM   #1938
ShadowAu's Avatar
Originally Posted by coderzone77 View Post
Sorted my F109, finally !
I got the original F109 rear spoiler.
I put a Savox SC1251Mg in the steering.
Put a combo LRP 13.5T (22 pinion) with SPX Zero LRP ESc.
Now it's really great, perfect in the steering, fast and powerful.
I can finally say that I am very very happy
Still a bit of side play in the front wheels, have to study it to know why, but I can say I am really happy.
As others have already said if you are using the original 3Racing front axles you'll need some shims to take the play out
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is offline   Reply With Quote
Old 12-09-2014, 01:23 AM   #1939
Perfect, i already put couple of shims but not enough... will put more.. Thanks to all
And what if I change the front axles ?
coderzone77 is offline   Reply With Quote
Old 12-09-2014, 03:30 AM   #1940
corally's Avatar
Coderzone...have use rubber tyre?
corally is offline   Reply With Quote
Old 01-05-2015, 07:04 PM   #1941
Looks like this is an old thread, but I will give it a shot anyway. Anybody have any experience with the 3racing out tuned ball diff for the f104? I built one exactly as instructed. Even if I crank the diff down tight, by the second lap the diff has loosened to the point that the motor can no longer spin the axle. What am I doing wrong?
mhopper is offline   Reply With Quote
Old 01-06-2015, 01:46 PM   #1942
ShadowAu's Avatar
Have you got the rubber O-ring in the right place? Its the main thing that keeps everything set. You also need to set the diff as tight as you want before putting the axle cap on and only use the adjuster to make small changes but other than that there isn't any trick to the OT diff. I've used them down to 8.5T and never had any issues.
Old 01-08-2015, 05:26 PM   #1943
Anyone know where I can get the alloy caster mount? I've been buying entire front ends just to get the replacement mount. Thanks.
timwat is offline   Reply With Quote
Old 01-08-2015, 06:19 PM   #1944
ShadowAu's Avatar
Unfortunately, everywhere I know that had them is out of stock, including 3Racing themselves... given how old the F109 is I don't have much hope for any more
Old 01-08-2015, 06:26 PM   #1945
evochick's Avatar
http://www.walterrchobby.com.au/inde...unt-ver-2.html
here you go
I am sure I saw some left last time I got one.
UnRetired
evochick is offline   Reply With Quote
Old 01-08-2015, 07:37 PM   #1946
Send a message via ICQ to zattan
you can use the tamiya 103 caster.. they are the same
zattan is offline   Reply With Quote
Old 01-09-2015, 03:18 PM   #1947
Thumbs up
here you go
Thanks Evochick! I've got one on the way now!
Old 01-09-2015, 08:31 PM   #1948
ShadowAu's Avatar
here you go
Might have to pick up a spare if they still have a few
Old 02-18-2015, 09:29 AM   #1949
oh so sorry for my soooo late answer...
no, I use still foam.
I want to change the F109 for rubber tyre, but apart the F104 front mount (and wheels), what else do I need to buy ?
Old 02-19-2015, 01:08 AM   #1950
If you want to use F104 style wheels, the big problem is the rear ride heigth, because the 109 is designed around the smaller 103 stule wheels.
You need to shim the motor Mount, and the side damper link.
You can see more in my web (spanish): http://f1rc.es/2014/06/3racing-f109-n/
prorace is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13488 Today 12:42 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
