Old 10-12-2009, 03:41 AM   #181
thanks, i just joined this forum to talk bout this car . Overall im surprised on how easy it is to drive. Considering its my first 2wd car
ADHUI is offline   Reply With Quote
Old 10-12-2009, 07:22 AM   #182
VTR
VTR's Avatar
Trader Rating: 21 (100%+)
Originally Posted by mac853 View Post
I guess those bodies which fits F104, could be try as well on F109, as we can see with the photo took from above.
nope, look closely @ e front suspension area, different between 104 n 109, unless u trim off alot.
http://www.tamiyaclub.com/member.asp?id=31105
VTR is offline   Reply With Quote
Old 10-12-2009, 07:46 AM   #183
NiMo's Avatar
you don't need to trim a lot off, just don't cut it out to the F104 line, cut it so it fits the F109 front
NiMo is offline   Reply With Quote
Old 10-13-2009, 10:42 AM   #184
mac853's Avatar
Questions??
Could anybody tell me if i try using F104 diff. housing and shaft in my F109, which left hub should i use.
In fact i found 2 from different aftermarket makes and want someone to tell me if both of them are usable or not:
http://www.rcmart.com/catalog/rc-f10...h=595_744_1390
http://www.rcmart.com/catalog/rc-f10...1-p-27709.html
I think the TRG 1 is better, in fact i think that 1 of 3racing could be possibly loosing, isn't it?
Best regards
mac853 is offline   Reply With Quote
Old 10-13-2009, 12:28 PM   #185
antonio_cadiz's Avatar
hello!
the foam rear tires f109 are good or bad??
what foam rear is good?
thanks
antonio_cadiz is offline   Reply With Quote
Old 10-14-2009, 09:41 AM   #186
NiMo's Avatar
Best regards
You can still use original F109 left hun on F104 axle, it is only the right side that is different, and the F104 axle shorter on the right side.
Old 10-14-2009, 08:25 PM   #187
GucciPiggy's Avatar
Hi guys, A friend of mine has started putting this kit together and is having trouble getting the diff tight enough. It's all put together as per the instructions but no matter what we try the spur gear still free spins inside the diff halves. Has anyone else come across this?
GucciPiggy is offline   Reply With Quote
Old 10-14-2009, 09:14 PM   #188
robk's Avatar
Trader Rating: 22 (100%+)
Make sure the adaptor ring for the spur is not too wide. It might be preventing the diff halves from coming together.
Old 10-14-2009, 10:13 PM   #189
InZane's Avatar
You should check that the axial bearing washers drops freely down the axle.
it's a very tight fit and you might need to sand the axle slightly with a wet/dry sand paper (I had to)
When you mount the wheel on the diff side, make sure the washers goes straight onto the axle and don't bind - this could be the cause of your problem.
InZane is offline   Reply With Quote
Old 10-15-2009, 08:22 AM   #190
hello!
thanks
Old 10-15-2009, 02:27 PM   #191
SMG
Can somone tell me if this car is supposed to have positive caster or neg caster on the front suspension? I cant tell which way the caster block is supposed to mount. I have the alum. caster block. thanks
SMG is offline   Reply With Quote
Old 10-15-2009, 03:11 PM   #192
veecee's Avatar
Trader Rating: 34 (100%+)
Positive. Pretty rare to see negative caster.
SMOKEM --- XPRESS --- HIRO SEIKO
veecee is offline   Reply With Quote
Old 10-15-2009, 04:01 PM   #193
rc-zombies's Avatar
I think it's Negative Caster.
isn't Positive Caster the top angle is forward and
negative is back.
Old 10-15-2009, 04:03 PM   #194
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
negative is back.
You coming out to swr this weekend?
R1 Wurks/Awesomatix USA/Roche USA/Protoform/Solaris/Mo Speed/Speedworld Raceway
BlackedOutREVO is offline   Reply With Quote
Old 10-15-2009, 04:06 PM   #195
rc-zombies's Avatar
maybe sunday... but not sure yet..
Tamiya F104 Pro! NT Electric On-Road 9378 Today 01:20 AM
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13639 09-22-2017 07:07 PM
Tamiya F103 Forum TFR Electric On-Road 2242 09-14-2017 12:57 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
