Old 09-08-2014, 01:39 AM   #1921
ShadowAu's Avatar
Originally Posted by coderzone77 View Post
Thanks !
Can you tell me where i can buy those f103 preglued rubber tyres please?
To be honest I've never seen pre-glued rubber tyres for f103... TRG supply theirs mounted ready to glue but not actually glued
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 09-11-2014, 01:28 AM   #1922
Ok, now my car is almost ready.
I bought "Enneti" foam tyres.
now ESC and motor.
for the moment I think i start with a brushed 17t motor and 24tooth pinion.
The idea is to go brushless, with 17.5t turnigy trackstar motor, sensored. Would a 45/60A Esc be enough ? (24T pinion with 99T gear)
coderzone77 is offline   Reply With Quote
Old 09-11-2014, 01:54 AM   #1923
ShadowAu's Avatar
60A should be ample for a 17.5T. ESC's like the HW Extreme Stock etc are rated at 60A.
Gearing wise I am assuming you are using 64P but either way I think you'll be under-geared with 24/99. Personally I'd aim for something like 24/78 but you'd need to use 48P. If you are set on using a 99T Spur you'll need something like a 31T pinion, but this is all depending on the layout of your track
Old 09-11-2014, 02:29 AM   #1924
Yes, I am on 64P
I have a 99T- so yes, I'll go with that 31t pinion.
Will let you all know how it will go, thanks
Old 11-04-2014, 04:21 PM   #1925
Hi all, I am thinking about selling my F109 and buy A tamiya F104 (#58475) plastic base (not Pro).
is the F104 base plastic (not pro) a better handling car than the 3racing F109 ?
Old 11-05-2014, 12:14 PM   #1926
ShadowAu's Avatar
This is only my opinion, based on others I've raced against, but I doubt the standard f104 will be any better than the f109 out of the box... the main advantage to buying a 104 is parts availability - as I am discovering having destroyed the bottom pod plate on mine
Old 11-05-2014, 05:35 PM   #1927
Ph3nyx's Avatar
it's 180mm for the f104 vs 200mm for the f109, cannot be comparable. 200mm will always have a great advantage
but the 104 is handling well with a good preparation
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 11-06-2014, 08:50 AM   #1928
Acid_CZ's Avatar
Send a message via ICQ to Acid_CZ
Even F109 with narrow F104 Front end and tires handles excelent.
"If you no longer go for a gap that exists, you're no longer a racing driver"
Ayrton Senna
Acid_CZ is offline   Reply With Quote
Old 11-07-2014, 09:15 AM   #1929
So you suggest me to modify my F109 with F104 narrow front and use rubber tyres (eg. Ride R1) ?
Old 11-07-2014, 01:56 PM   #1930
Acid_CZ's Avatar
I run schimizu, but - yes. This summer I race my F109 with 21,5T Zero against F104v2 with 17,5 zero and the other guy admited that he had no chance to overtake me anywhere else than main straight. When he was in front of me, I can easily stay on his six till the straight.
We run on this track
https://www.youtube.com/watch?v=I3BbYsLHUGQ
Ayrton Senna
Old 11-08-2014, 02:21 PM   #1931
ShadowAu's Avatar
Ride R1's are a good starting point, but some say they get too much push from them... Shizimu's have been the most popular F1 tyre brand for a fair while and there are lots of options to try.
Personally I am going to try some of the V2 Sweeps next meeting, just to see if they are better than the V1s and to see if I can find a combo that works on the particular surface we have
Old 11-10-2014, 07:43 AM   #1932
My 109 has a broken Body shell.. now I need to buy it but no one selling it around my place.
So, can I use an FGX body shell ? or better to look for a F103 body ? Don't know which one can be a direct fit
Old 11-11-2014, 01:56 AM   #1933
ShadowAu's Avatar
Any F103 body will fit... the F113 body will fit if placed right and because the battery goes down the middle most F014 bodies will prob fit as well
Old 11-30-2014, 03:35 PM   #1934
hi all
I just put in a 13.5T LRP Motor, I have the 64dp original gear (mabye 99Teeth?)
What pinion I could use now ? about 24 teeth ?
Old 12-06-2014, 11:13 AM   #1935
Sorted my F109, finally !
I got the original F109 rear spoiler.
I put a Savox SC1251Mg in the steering.
Put a combo LRP 13.5T (22 pinion) with SPX Zero LRP ESc.
Now it's really great, perfect in the steering, fast and powerful.
I can finally say that I am very very happy
Still a bit of side play in the front wheels, have to study it to know why, but I can say I am really happy.
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12847 Today 08:48 PM
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
