Old 08-02-2012, 01:54 PM   #1846
MarkBurgess's Avatar
Originally Posted by ShadowAu View Post
As an after thought which grease are most using on the diffs?... I am just not happy with the ones I am using at the moment (Tamiya and 3racing)
Yes - I also run as many diff balls as the spur can take. Think the Kimborough spur means 4 more although it might be another 6.
As for grease I'll use Joel Johnson's Slippage if I've got any left. My supplies are running low. So if not that than Schumacher silicone grease does the trick.
MarkBurgess is offline   Reply With Quote
Old 08-02-2012, 04:33 PM   #1847
texastc's Avatar
Associated black, or red if its in stock. Recently went to ceramic balls and can say that they are in fact worth it.
Exotek F1Ultra Tamiya TRF101 Speed Passion SP1 and another Exotek F1Ultra on the way. And whatever is next
"TexasTC, the single Greatest RCF1 racer I have ever known" - My mom "you are a disgrace to RC" - everyone else. TCdoesRC
texastc is offline   Reply With Quote
Old 08-02-2012, 05:23 PM   #1848
FNG RIDER's Avatar
I retract the post.
RC10B5, Tekno 410 sct, TA05 v2 Reedy 17.5, Revolt 30, Seaport Tug, Axial SCX10 Rubicon ess sound system.
FNG RIDER is offline   Reply With Quote
Old 08-02-2012, 05:33 PM   #1849
Red? I've never seen that.
Stregone is offline   Reply With Quote
Old 08-02-2012, 07:13 PM   #1850
texastc's Avatar
The labeling is red, the goop is still clear.
Old 08-02-2012, 07:27 PM   #1851
Ahh, gotcha. I believe that stuff is the 'Stealth diff grease'. I dunno why but they say not to use it on pan car diffs Unless I mixed them up; there is the regular 'silicone diff grease' and then there is the 'stealth diff grease' (plus black grease, and green slime).
Old 08-02-2012, 07:55 PM   #1852
texastc's Avatar
was told red is best for pan car diffs, but all I have is the black. Bot ceramic balls and now diff is s m o o t h
Old 08-02-2012, 09:05 PM   #1853
CypressMidWest's Avatar
The red is the standard for pancar style diffs, but the black(stealth) also works well, you just use a bit more of the black label.
Team CRC, PowerPush, Access Race Place, US Indoor Champs, CD SUPERPRO, RK Designs, TxDSkingraphix, Cypress, Founder and lead instructor of the Ian Ruggles Negative Reinforcement Driver Training Program, enroll now.....
CypressMidWest is offline   Reply With Quote
Old 08-02-2012, 11:10 PM   #1854
It used to be that the stealth grease was for ball diffs (transparent grease), the black grease was for thrust bearings (actually black in color). It may very well be that this has changed, I've had my small tubes of both close to 15 years or so.
Tamiya TRF101, Corally F1 SL, 3Racing F1-09, Kyosho Mini-Z MR03, Corally SP12M, Tamiya SuperShot, Kyosho Optima Pro, Duratrax Vendetta.
Home track: http://www.amcaracing.nl
ijdod is offline   Reply With Quote
Old 08-05-2012, 12:55 PM   #1855
seanikaido's Avatar
Send a message via MSN to seanikaido
Does anyone here had problems with the stock FRP lower deck?
I broke mine between the servo mount and the front end and the hit was not that strong, too strange.
After 1 week, again. (with another lower deck, of course)
I just modified the stock servo mount to the aluminium exotek one,can this be the reason?
International Racing Team Member #196
== Tamiya TRF-415MSX / TA-02 ==
== Team Losi Mini-T HOPped! ==
== 540-J! ==
== ESC Novak Tempest Pro / LRP IPC V7.1 ==
== Integy 3300 / Pro-Match 4200 ==
== Spintec Battery Manager/Novak Smart tray ==
seanikaido is offline   Reply With Quote
Old 08-06-2012, 01:00 AM   #1856
Tracy B's Avatar
I haven't run my F109 enough to tell. I know that 3 racing sells a graphite lower deck as well as an entire chassis conversion; might be worthwhile investing in.
TRex chassis with McAllister Xfinity Ford Mustang
Member of WRCRC
Authorized HobbyWing, Gens Ace batteries, McAllister Racing Bodies, and Precision Racing Systems dealer: BroeckerRacing@Gmail.com
www.facebook.com/BroeckerRacing
Tracy B is offline   Reply With Quote
Old 08-06-2012, 02:35 AM   #1857
Not had any problem with the FRP parts - also run the aluminium Exotek servo mount. I actually think the F109 works better on tarmac because of the FRP parts, and so haven't considered any of the carbon parts.
I find the thumb screws fiddly, so use counter sunk screws and washers instead of the four thumb screws. Prefer those to button head screws that can introduce chassis tweak.
Old 08-12-2012, 11:07 AM   #1858
Send a message via ICQ to Cartman
What seem to be the best steering set up, servo svaer horizontal or vertical, and if you have tried both, what worked best and what did you find??
aslo anyone know what the kit side damper oil is in weight?
Cartman is offline   Reply With Quote
Old 08-13-2012, 03:41 AM   #1859
ShadowAu's Avatar
I can't say I've felt any significant difference between the 2 servo positions but that could be that I've also had different servo's in each position... though each will have different bump steer characteristics due to the different arm angles but I've not experienced anything negative in that area
I am not sure about the damper oil... my simple answer is too thin as I am running 60Wt currently and seems to suit me
I am quite content with doing what I do
Don't mistake not being happy for unhappiness - its not the same thing
ShadowAu is online now   Reply With Quote
Old 09-05-2012, 02:14 AM   #1860
cocojam's Avatar
Trader Rating: 47 (100%+)
Will the rear shaft and diff housing of a Tamiya F103 fit on the 3Racing F109? Im thinking of building a 109 from scratch thru parts available with the HK hobby shops since there are no kits available locally. I have an extra F103RM where I can get some donor parts. TIA
SJF01 - F103RM - F104Pro - 3rF109 - TB EvoV
Wild Willy 1 - Road Wizard - Can-Am Lola
Dynamic 1500 - Wilga 2000 - Zephyr V70 - FMS FW190 - TWM Skylink
TWM Katana - Zeta Horten BV38 - Freewing Pandora
cocojam is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13468 Today 11:52 PM
Tamiya F104 Pro! NT Electric On-Road 9373 07-14-2017 08:58 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
