Old 07-21-2012, 02:52 AM   #1831
MarkBurgess's Avatar
Originally Posted by ShadowAu View Post
Is anyone interested in using a side spring mod using Associated springs etc...
I couldn't get CRC stuff so did what I could with what I could get... seems to work
Done just that. Used Associated plastic spring mount and currently Associated Blue side springs. Works just fine indoors and out.
Doris International Racing Team
MarkBurgess is offline   Reply With Quote
Old 07-23-2012, 08:54 AM   #1832
GasGod's Avatar
where is the f113?
dug the 109 out of the corner and won --the b main
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is online now   Reply With Quote
Old 07-23-2012, 10:07 PM   #1833
ShadowAu's Avatar
How are you finding it with the blue springs? how does it feel on the track?
My car may look like it goes bad to you, but its actually far worse that you think it is...
I have only one more RC thing on my bucket list and I will keep racing (and probably coming last) till its done.
ShadowAu is offline   Reply With Quote
Old 07-23-2012, 11:14 PM   #1834
We have one F109 racer among a field of 20 - 26 cars. It is holding its own.
From our last Saturday race.
Finished 5th overall.
Source: F1 RC Cars
www.rccartips.com
www.f1rccars.com
www.f1rcclub.com
http://www.youtube.com/user/rccartips/
http://www.facebook.com/RCCarTipsFan
rccartips is offline   Reply With Quote
Old 07-25-2012, 02:21 PM   #1835
Really good...both on carpet and tarmac. When the rear does slide on tarmac, it is pretty progressive.
Old 07-26-2012, 02:04 AM   #1836
ShadowAu's Avatar
I am still trying to understand how side springs affect the handling... I went straight to the AE Gold because I was trying to stop the pod collapsing to each side as it went around corners but now I am trying to change how the car transitions from corner entry to corner exit
Old 07-31-2012, 06:07 PM   #1837
Trader Rating: 57 (100%+)
Anyone know if xray gears/diff rings will work on this car? I mean like the basic diff setup from their 1/12 car bolted on the F109.
PROMODVETTE is offline   Reply With Quote
Old 07-31-2012, 09:56 PM   #1838
ShadowAu's Avatar
Simple answer is no...
Old 07-31-2012, 09:59 PM   #1839
simple answers are the best! thanks
on that note, are there an diff setups to switch to better than the one it comes with?
Old 07-31-2012, 10:41 PM   #1840
Tracy B's Avatar
You could try the 3racing out tuned ball diff OR the tamiya stock f104 diff, both for the f104, but you would need the f104 rear axle for it to work. The tamiya and 3 racing diffs allow you to change the rear tires without having to reset the diff every time like you do on the stock f109.
TRex chassis with McAllister Xfinity Ford Mustang
Member of WRCRC
Authorized HobbyWing, Gens Ace batteries, McAllister Racing Bodies, and Precision Racing Systems dealer: BroeckerRacing@Gmail.com
www.facebook.com/BroeckerRacing
Tracy B is offline   Reply With Quote
Old 08-01-2012, 12:37 AM   #1841
malcnz's Avatar
I wouldnt get the 3racing out tuned diff as it just doesnt feel as smooth as the Tamiya what ever you do and it just didnt tune right either and once I went Tamiya diff it was a different car..well F1
SCHUMACHER MI5 EVO/TEAM POWERS/SANWA/DX4R PRO.
SERPENT F110/TEAMPOWERS 21.5.
LOSI 22 2.0/TEAM POWERS 8.5
malcnz is offline   Reply With Quote
Old 08-01-2012, 07:58 AM   #1842
ShadowAu's Avatar
Well that's one of those weird things as I've had the exact opposite experience ... the 3racing out tuned diff works brilliantly for me while the F104 Pro diff has been so problematic it finally went into the bin at my last race meeting
The only mod I would suggest for the out tuned is switching the alloy spacer for thrust washers... seems to work HEAPS better
Old 08-01-2012, 02:16 PM   #1843
The 3 Racing spur gear adaptor (actually just a delrin ring) means I can run 12th scale spur gears. Kimborough mostly, and I've made a 64dp spur last a summer season of outdoor racing on my F109.
I have also stuck with the F109 kit diff. Years of pan car racing means I can set it up quicky when I change wheels. And had not problem with diff feel or durability.
Mind you not tried some of the other options listed.
Old 08-01-2012, 09:32 PM   #1844
ShadowAu's Avatar
Actually I forgot about the little adapter ring when I was thinking about Xray spurs as I've switched to using the Kawada spurs so I can use the extra diff balls....
... but the xray diff rings still wouldn't fit as that is totally different to the 3racing/Tamiya rings
As an after thought which grease are most using on the diffs?... I am just not happy with the ones I am using at the moment (Tamiya and 3racing)
Old 08-02-2012, 12:50 AM   #1845
Still using the small tube of Associated Stealth grease I bought ages ago.
Tamiya TRF101, Corally F1 SL, 3Racing F1-09, Kyosho Mini-Z MR03, Corally SP12M, Tamiya SuperShot, Kyosho Optima Pro, Duratrax Vendetta.
Home track: http://www.amcaracing.nl
ijdod is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12642 01-15-2017 02:18 PM
Tamiya F104 Pro! NT Electric On-Road 9327 01-11-2017 01:04 PM
Tamiya F103 Forum TFR Electric On-Road 2199 08-27-2016 04:27 AM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 04:37 PM
SEO by vBSEO 3.5.0
