Old 03-15-2012, 11:05 AM   #1771
JD Skyline's Avatar
Thanx for the reply!!!
I think I gonna keep the F109 diff for now And concentrate on driving the car on our race track!! See how the car handles and if necesarry add some hopups. Gonna start with the original tires and just race for a while and then change to rubber!!
Im lookin at the Shimizu tires for unprepared suface. I believe its the F1 en R1 combination??
JD Skyline
"NO GUTS NO GLORY"
Still lookin.......
http://jdskyline.blogspot.nl
JD Skyline is offline   Reply With Quote
Old 03-17-2012, 09:52 PM   #1772
blade072's Avatar
Trader Rating: 98 (100%+)
tried my f109 for the first time today......could not stop it from doing donuts....
i have kit oil in the dampening tube...and 60wt oil in the shock with 3 hole piston....all the springs on the car are as per kit standard...
anyway i was running the following tires
pit shimizu 0548-R3 rear and 0543 F1-M fronts
we run on high grip asphalt so any help would be appreciated
oh and i find the kit rear wing is too flexy
any other recommendations would be a great help
David Randall
AWESOMATIX A800X ★ MUCHMORE ★ R1 WURKS ★
ROCHE RAPIDE F1-16 ★ SANWA M12 ★ SILVERBACK ★
HOBBYWING ★ RCMAKER ★ VOLANTE RC ★
blade072 is offline   Reply With Quote
Old 03-17-2012, 10:53 PM   #1773
blade072's Avatar
oh one other thing..im used to the tamiyas with their t-bar and fraction damper plates.....so i am a little lost with the f109
David Randall
Old 03-18-2012, 05:37 AM   #1774
warnos's Avatar
Blade072 what motor u running..
I have found on rubber it was a bit hard to get my 109 dialed.. When I did run them I had to take out any pod drop I had so it was zero.. Also lowered the rear to the lowest ride height. Have the crc mod with the softest blue crc springs just touching the bottom.. Then adjust for teak.
Will have to get back to rubber racing soon.. Rules r changing at our club.
TCX Smokem / F104 wgp
Major Sponsor : Visa Card
TEAM SMA - www.smaracing.org
warnos is offline   Reply With Quote
Old 03-18-2012, 11:24 PM   #1775
blade072's Avatar
thanks for the tip......ive been looking at a f104.....but maybe i should try this first...i was running a 17.5 but our class will be running 21.5....the fgx'x go awesome around our track....and from memory i think i need soft rears and hard fronts as i had way too much steering.....and what do you mean by crc mod??? do you have a link
thanks for all the help
oh and should i make the side dampening tube oil the same as the shock????? i did put 60wt in it with the kit springs on both the shock and sides
David Randall
Old 03-19-2012, 10:01 AM   #1776
texastc's Avatar
Here is the link to the side spring mod
Exotek F1 Ultra Tamiya TRF101 Tamiya TT02r SpeedPassion LM1 and SP1 C main mainstay. Unless there is a D
TCdoesRC
texastc is online now   Reply With Quote
Old 03-19-2012, 10:03 AM   #1777
Trader Rating: 70 (100%+)
going to list a sweet f109 for sale in the for sale thread.
Krafcik is offline   Reply With Quote
Old 03-19-2012, 10:30 AM   #1778
texastc's Avatar
about to list a hyper-updated FGX
TCdoesRC
Old 03-19-2012, 11:18 PM   #1779
blade072's Avatar
thanks guys and Krafcik you have a pm....
David Randall
Old 03-21-2012, 01:55 PM   #1780
warnos's Avatar
blade 72 A 21.5 in ur 109 should make u able to control it better until u get the handling sorted.. also get the softest Shimi tires u can on the rear.. also make sure ur diff is nice and smooth.. I don't like mine to slip too much.. i just like it smooth..
Cheers
Old 03-21-2012, 10:17 PM   #1781
lightfoot's Avatar
Default UF1
2012 UF1 season starts this Saturday March 24th at the West Australian Coast Grand Prix...
for more info : http://uf1series.com/index.html
Love and Peace...
lightfoot is offline   Reply With Quote
Old 03-21-2012, 11:02 PM   #1782
blade072's Avatar
Cheers
yep will try that also thanks warnos....
David Randall
Old 03-22-2012, 04:25 AM   #1783
Made the mistake of making room for a TC to overtake me on the inside, which resulted in ending up outside of the gripline, and spinning off. Now 1st hand experience with the weakspot called the caster plate :P. Too bad the aluminium replacement is so hard to get.
Tamiya TRF101, Corally F1 SL, 3Racing F1-09, Kyosho Mini-Z MR03, Corally SP12M, Tamiya SuperShot, Kyosho Optima Pro, Duratrax Vendetta.
Home track: http://www.amcaracing.nl
ijdod is offline   Reply With Quote
Old 03-22-2012, 07:43 AM   #1784
Robudda723's Avatar
Trader Rating: 21 (100%+)
So my F109 came in today and I ordered all the parts needed to narrow the car. Was wondering if anyone has done the upper arm adjustable conversion? Also did you feel it was worth it or is the stock non adjustable upper arms just fine?
Thanks,
Rob
Robudda723 is offline   Reply With Quote
Old 03-22-2012, 09:34 AM   #1785
texastc's Avatar
Just get the Tamiya composite F103 front end. Its not adjustable but its almost bullet proof. You wont miss the 3racing front end at all.
Thanks,
Rob
Stock arms are fine. Less to mess with.
TCdoesRC
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13160 Yesterday 11:58 AM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
