Old 11-29-2011, 10:39 AM   #1696
Trader Rating: 32 (97%+)
Originally Posted by scootr117 View Post
I'm changing over to 21.5 brushless from a silvercan....what is a roll out range to start at for a medium indoor carpet track. I'm just looking to get in the ball park for the gearing for the Rev-tech 21.5.
Thanks.....Scooter
Im running currently 19/75 and it comes off ice cold. Was running 23/75 and it was a bit warm, maybe in the 120's. Im going to try a 21/75 as the 19 didnt have the top end punch of the 23 and the 23 didnt have the acceleration of the 19.
Hotshot Rc Raceway
kikcaffine is offline   Reply With Quote
Old 11-30-2011, 05:16 PM   #1697
I was at my LHS today and they have some upgrade parts for the F109. Are there any upgrades that are really beneficial?
Delawareguy is offline   Reply With Quote
Old 11-30-2011, 05:31 PM   #1698
texastc's Avatar
Thanks.....Scooter
I run the same gearing in the 21.5 as the silver can
aluminum castor block. and titanium turnbuckles.
The stock plastic castor block cracks pretty easily. So the aluminum is the way to go there. I changed to a fixed F103 front end after a while. No adjustments on it, but its done well. And the carbon reinforced version is almost bullet proof. And cheap.
Also CRC side springs. Pretty much it, none of it is a must have, but they are nice, and do improve the car.
Here is list of what I've added
F103 fixed arms- composite
Titanium links front and sides
CRC side spring mod
steel rear axle
Clamp on Left wheel hub
3racing aluminum steering blocks
Associated 1/12 front springs .020-.024
To show you how tough the front end is here is a video where I crash a lot. (normal)
I stripped a spur at the 5 minute mark. But front end was OK. I'm the red and white car that crashes a lot. Had a bad day man.
http://youtu.be/CZuvB9Vdh9A
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
texastc is offline   Reply With Quote
Old 12-01-2011, 07:58 PM   #1699
I'm almost finished building my 109 but I think I have a problem. I'm using a standard servo so I followed the appropriate directions regarding how to mount it. The ball ends that attach to the servo saver are rubbing the servo mount. Is this a common problem and how do I get rid of it?
I also received my wheels and tires from TQ Racing today. Talk about fast shipping. I haven't looked that closely so this may be a dumb question but how do you glue rubber tires to foam rims? Do I use the foam inserts?
Old 12-01-2011, 10:02 PM   #1700
texastc's Avatar
Either move the servo farther forward, or lean it back at an angle a bit. I got my tires from TQ today as well. They always impress. Use the foam inserts, yes. As for gluing the tires on to foam rims, I'm not the one that can help there. Only done it once, and didn't do it very well. Some where in this post Some one explains it pretty well.
Also when you run that thing the first time, might ought to dial down your steering rate a bunch. I run with 55-70% steering.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 12-02-2011, 06:31 AM   #1701
lightfoot's Avatar
Default UF1 Series
UF1 Winter Series
2nd Race will be this Saturday...
Doors open at 10AM....
Qualifying at 12...
http://uf1series.com/
Love and Peace...
lightfoot is offline   Reply With Quote
Old 12-02-2011, 10:17 AM   #1702
Last question... I hope. How do you attach the nose cone to the body? CA glue?
Old 12-02-2011, 10:31 AM   #1703
texastc's Avatar
Double sided tap or Shoe Goo.
Exotek F1 Ultra
Exotek F1R
CRC Gen-X 10 LE
Kyosho Plazma F1
TC does RC
Old 12-08-2011, 07:31 PM   #1704
namewasdallas's Avatar
So I just bought one of these that used and prebuilt but never ran, I'm totally new to F1 cars. I am not racing this was just going to have some fun with it on some smooth surfaces. Im going to pull some parts from my other cars to make it run. My plan is to have a quick little car
I got a few questions tho.
I'm going to run a brushless setup I have a 4 pole 4600kv castle motor out of my hpi stadium truck. its a 540 size motor, will the diff be able to hold up ? Plans are to do some speed runs nothing to crazy just 3s lipo
How many teeth is the Spur gear 75 I think i read somewhere?
How large of a pinion can I run with the stock mount? 36?
Last question is it 48p or 66p?
namewasdallas is offline   Reply With Quote
Old 12-09-2011, 02:12 AM   #1705
MarkBurgess's Avatar
I use double sided carpet tape...nice and thin. It can get a bit of a bashing, and taping it means it will just fall off rather than rip in a shunt.
If you are using the F109 fonr wing then it can help to cut the nose cone shorter. That way the wing will hit the barrier first, rather than the nose cone.
Hope that helps,
Mark
MarkBurgess is offline   Reply With Quote
Old 12-09-2011, 02:21 AM   #1706
Repeating some of the previous replies...
The alloy caster adjuster is the key upgrade for the F109. The stock plastic part can break in the thinner sections if you have a heavy shunt.
The CRC side spring mod doesn't use F109 upgrade parts, but is a big help with side to side movement. I've used Associated side springs but used the same basic approach. Details are covered earlier in this thread, and seen lots of references to how to do it.
I'd also recommend running 1/12th front springs rather than the F109 kit. And as the F109 centre shock is the same dimensions as a 1/10th Touring Car kit, then Touring car springs fit it fine. I've been running 14lbs and 16lbs springs on it.
I have a wide range of 64dp spur and pinion gears. To run that spur you'd need the white plastic F109 spur gear adapter.
I'm still running kit tyres. I have got the stronger side links but these reallt aren't essential in my view.
Hope that helps
Mark
Old 12-10-2011, 11:07 AM   #1707
rickthejetman's Avatar
if you run with that motor you will hate your car and give up on it quickly. if your just going fun running with it i recomend a 21.5 or a 17.5 and some rubber tires for asphalt. the gears are 64p you'll have to mess around with the gearing depending on where you run.
have fun, i bash mine at work in the smooth parking lot all the time/ be aware they handle very poorly on un preped surfaces.
rickthejetman is offline   Reply With Quote
Old 12-16-2011, 12:16 AM   #1708
lightfoot's Avatar
Default UF1 Series
3rd round of the UF1 Winter Series this Saturday in Chino California...
Qualifying begins at 12 noon...
Hideo Kitazawa is flying over from Japan to join us... Hard core baby !
http://uf1series.com/index.html
http://uf1series.com/_gallery/UF1Girls1.html
Love and Peace...
Old 12-16-2011, 01:08 AM   #1709
tudor_47's Avatar
I think it is time for uf1serie to have their own thread hera at rctech.
Maybe you could shoot som e video of the finals?
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 12-16-2011, 07:57 AM   #1710
lightfoot's Avatar
We kinda use this thread ( F1 is alive and well in So. Cal! )
But I do spam all the F1 related threads before each race sorry for the junk mail...
Love and Peace...
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 12860 Today 02:54 PM
Tamiya F103 Forum TFR Electric On-Road 2205 03-20-2017 02:30 AM
Tamiya F104 Pro! NT Electric On-Road 9345 03-16-2017 12:15 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
