Old 11-25-2011, 09:54 AM   #1681
texastc's Avatar
Originally Posted by nameless View Post
i was wondering what tamiya rubber tire rim would fit the f109 without mod?
any of them that fit the F103. Same size and everything. Also the Ride wheels for the F103 fit as well.
Exotek F1 Ultra Tamiya TRF101 Tamiya TT02r SpeedPassion LM1 and SP1 C main mainstay. Unless there is a D
TCdoesRC
texastc is offline   Reply With Quote
Old 11-25-2011, 10:04 AM   #1682
nameless's Avatar
oh ok. thanks but how about the f104 rim for rubber tire?
nameless is offline   Reply With Quote
Old 11-25-2011, 10:17 AM   #1683
texastc's Avatar
it will fit, BUT, for the front you will have to get the F104 bearings, and the wheels will have a different offset front/back. Front will be wider than rear. You can put the F104 front arms on there to fix that. I have done that on one of my F109s. Arms are cheap.
TCdoesRC
Old 11-25-2011, 10:19 AM   #1684
nameless's Avatar
cool thanks for the fast reply i'm geting my soon
Old 11-25-2011, 10:22 AM   #1685
texastc's Avatar
no problem. You will love it.
TCdoesRC
Old 11-25-2011, 11:12 AM   #1686
I just got my F109 and am about to start the build process. Any things I should look out for during the build? Any tips or common mistakes I may be able to avoid? I'm going to be running 21.5 with rubber tires on carpet.
Thanks!
Delawareguy is offline   Reply With Quote
Old 11-25-2011, 05:15 PM   #1687
texastc's Avatar
Thanks!
I don't remember any issues. Just build it like it says, get your links right, all the fluids and stuff like instructed. Make sure your rear links don't bind. It will be good right off the bat. Most of us modified the side springs to the CRC set up, I believe there's a how to a page or two back. I run 21.5 rubber tires on carpet as well. To get mine running very well, I put some Associated .022" front springs on it and stiffened up the rear shock a bit. That helped to get the rear end to stop wanting to swing around. It is very good now. I'm running Pit Shimizu F/R3 soft compounds and Paragon.
TCdoesRC
Old 11-25-2011, 10:55 PM   #1688
Thanks. Just to clarify something that you posted earlier. The LHS sold me F104 wheels in order to run rubber tires. You said they won't fit without adding some other 104 parts as well? I suppose it would be easier to just get F103 wheels?
Old 11-25-2011, 11:18 PM   #1689
texastc's Avatar
yeah it would be easier in the long run. I'm actually converting my narrow F109 back into a standard width. You would need the F104 front end, which is cheap, under $10. And the F104 servo mount. And the F104 size bearings for the front.
I use Pit Shimizu tires on Ride wheels. Those tires also fit on Tamiya foam rims.
TCdoesRC
Old 11-26-2011, 04:35 PM   #1690
So can I assume that F104 tires won't fit on F103 rims? Where do you get the Shimizu tires and Ride wheels? I'm trying to get this done before next weekend so I can race it but none of the LHS's carry F103 parts. Thanks again.
Old 11-26-2011, 05:11 PM   #1691
texastc's Avatar
TQ RC Raceway
there you go. Also check the parts on the F103 parts page, there are some more things. They fit too. This is THE go to place for 3racing stuff. And I believe the only place you can get the Pit Shimizu tires.
Sean, how about a commision check?
TCdoesRC
Old 11-26-2011, 05:35 PM   #1692
TQ RC Raceway
Thanks again. Will Shimizu tires fit the F103 rims? Any reason to get the Ride rims instead?
Old 11-26-2011, 07:36 PM   #1693
texastc's Avatar
As long as you got F103 tires with F103 rims, they work. 103 and 104s don't play well. Pits fit the Tamiya FOAM rims, they don't fit the Tamiya rubber rims. They work with the Rides well. I got them for looks honestly. A lot of guys say that the Ride wheels are too brittle, but I haven't had a problem. I believe the Pits are actually designed for the foam rims.
TCdoesRC
Old 11-27-2011, 02:00 AM   #1694
Dan the Man's Avatar
Trader Rating: 40 (100%+)
You can get the Shimizu tyres from RCMart as well, if you don't live in the States.
|-●-|Hot Bodies Pro 5 |-●-|Hot Bodies D8 GT-E|-●-|The "F109X"|-●-|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 11-29-2011, 05:42 AM   #1695
scootr117's Avatar
I'm changing over to 21.5 brushless from a silvercan....what is a roll out range to start at for a medium indoor carpet track. I'm just looking to get in the ball park for the gearing for the Rev-tech 21.5.
Thanks.....Scooter
Scooter EXperimental
RK Designs
CD SuperPro Motors
Mike Pulfer is my HERO....
scootr117 is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13184 05-26-2017 10:50 PM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
