Old 10-21-2011, 11:40 AM   #1666
spring71's Avatar
Smile
Pre-Order available for new 3Racing Sakura FGX kit with Free Shipping. (Limited Quantities)
If you order today, it will be shipped on Oct. 26th.
Click Here to see the detail.
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
http://www.tqrcracing.com
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 10-21-2011, 01:20 PM   #1667
rickthejetman's Avatar
just ordered one, thanks for the heads up
rickthejetman is offline   Reply With Quote
Old 10-21-2011, 01:35 PM   #1668
spring71's Avatar
Smile
Thank you.
We will ship your order on next Wednesday, and you will get by next week.
TQ RC RACING
Online Shop
tq@tqrcracing.com
Old 10-23-2011, 08:59 AM   #1669
Send a message via ICQ to Cartman
Default crc spring mod
To Convert the F109 to CRC rear side spring I did the following
You will need
2 x m3 12mm grub screws
2 x 3x3 m3 grub screws
2 x
1 x CAL-1287 Calandra CRC Metal Spring Holders
1 x CAL-1280 Rear Side Spring Set
(If you do not use the below items you will need longer m3 grub screws of about 16/18mm long)
1 x CAL-1256 Chrome Pivot Balls (2)
2 x af cs screws 4-40 x
1st step is remove the rear block with the side springs in, remove the rear top deck mounts and fit shorter pins or cut them down, these can be glued in place or a 2.5mm hole drilled and a 3x3 grub screw threaded in as picture to secure the pin.the pin needs to be mounted so it does not go into the hole where the grub screw was that held the pin in place originally
Next take the CRC spring mount and wind in the long m3 grub screw, this will be tight as the threads are wrong, I tightened mine as tight as possible and fit the springs.
Now screw the spring mount in from the bottom side so the spring goes into the recess.
I fitted the CRC ball as it allows the spring to move freely instead of twisting the spring on the chassis plate, the af screw fits perfectly in the chassis countersink.
Reassemble and adjust tweak from top near body rear posts.
Cartman is offline   Reply With Quote
Old 10-23-2011, 10:30 PM   #1670
tudor_47's Avatar
Excellent description,
I will add:
put some threadlock onto the 4-40 screws holding the balls to the chassis.
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 10-26-2011, 01:26 PM   #1671
spring71's Avatar
Smile
The estimated shipping date is Nov 2nd.
FYI, Thanks.
TQ RC RACING
Online Shop
tq@tqrcracing.com
Old 10-27-2011, 10:41 PM   #1672
Cool gearing
Hey guys Im new to F1. I plan on racing my F109 Saturday. What pinion and spur should be a good starting point for 21.5 and 2s. The tires will not be cut at all. Thanks.
leelee is offline   Reply With Quote
Old 10-27-2011, 11:57 PM   #1673
texastc's Avatar
I'm either running a 33 or a 36 on mine with the stock spur. not 100% sure. I run on carpet
Exotek F1 Ultra Tamiya TRF101 Tamiya TT02r SpeedPassion LM1 and SP1 C main mainstay. Unless there is a D
TCdoesRC
texastc is offline   Reply With Quote
Old 10-28-2011, 12:09 AM   #1674
Cool
Thank you texastc. I also run on carpet. That will get me started then I will fine tune to the track and power band of motor.
Old 10-30-2011, 10:47 AM   #1675
mxrich's Avatar
Ok, I got my f109. It works great with foams on carpet or asphalt but is a total pig on asphalt with rubber. I did not get a manual with it. At every turn it spins around to see all the cars coming at it. It came with the bridgstone rubber tires on it and I am assuming it was built as per the instructions so what is the quick setup for outdoor racing with rubber?
I park faster than most people drive.
mxrich is offline   Reply With Quote
Old 10-30-2011, 11:01 AM   #1676
texastc's Avatar
3racing F109
InZane did a set up on a set up sheet he used for the Swedish Cup (he won it) theres a bunch of good info in this thread, specifically around pages 60 on for set ups and mods.
TCdoesRC
Old 11-02-2011, 04:30 AM   #1677
djnsayne's Avatar
Send a message via Yahoo to djnsayne
Anyone have the adj castor part that they'd be willing to get rid of asap?....... I have a race next sat and everyplace stateside is sold out.
Yes.... That WAS my EVADER that just passed you!!!
Evader BX PRO/Xray T206/ 3Racing F109
DJ Nsayne/Hitt Breaka Dj's/Sexy B Racing
djnsayne is offline   Reply With Quote
Old 11-08-2011, 08:53 AM   #1678
texastc's Avatar
just wanted to post a new pic of my F109K4 Mutant. 180mm
TCdoesRC
Old 11-10-2011, 03:27 PM   #1679
lightfoot's Avatar
Default UF1 Series
First race of the UF1 Winter series starts this Saturday at TQ in Chino California... doors open at 10AM, racing starts around noon...
F1 class and LM class...
for more info:
http://uf1series.com/index.html
Love and Peace...
lightfoot is offline   Reply With Quote
Old 11-25-2011, 09:52 AM   #1680
nameless's Avatar
i was wondering what tamiya rubber tire rim would fit the f109 without mod?
nameless is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13184 05-26-2017 10:50 PM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
