Old 07-27-2011, 09:13 AM   #1606
texastc's Avatar
apologies for the bad paint. But heres my F109 with a low nose F103 body.
Exotek F1 Ultra Tamiya TRF101 Tamiya TT02r SpeedPassion LM1 and SP1 C main mainstay. Unless there is a D
TCdoesRC
texastc is offline   Reply With Quote
Old 07-28-2011, 02:05 AM   #1607
Post caster blocks
the adjustable Alu castor blocks from 3racing are in stock at rcmart.com.
Get in quick before they are all gone again.
McLarenFan is offline   Reply With Quote
Old 07-28-2011, 04:17 PM   #1608
spring71's Avatar
Smile
We also have them in stock.
http://www.tqrcracing.com/shop/produ....asp?p_id=1974
FYI, Thanks.
TQ RC RACING
Indoor RC Race Track & Hobby Shop in Chino, CA
Online Shop
tq@tqrcracing.com
spring71 is offline   Reply With Quote
Old 07-28-2011, 09:59 PM   #1609
Thanks for all the info! I decided to get f109.
LOWDOG HOBBY is offline   Reply With Quote
Old 07-29-2011, 06:17 AM   #1610
Jamesalex's Avatar
Hi,
I am looking at getting a f1 car and have had a a scan through this forum.
I was wondering two things,
What parts are required for this car hopup wise for it to run competitive and
what body shells fit this car?
I also beieve I read somewhere that the F104 front end can be fitted along with F104 wheels to get it down to the narrow 180mm is this correct?
Many Thanks in advance.
www.cmcc.org.uk
www.mmrflux.co.uk
www.hpiracing.co.uk
www.hotbodiesonline.com
Jamesalex is offline   Reply With Quote
Old 07-29-2011, 12:17 PM   #1611
If you run the 104 front end, you should do the rear end too, otherwise it may handle funny. By the time you get all those parts, you might as well just get a 104!
The ONLY things you need to do, at all are:
1. Side-spring mod (threads everywhere about it)
2. Front ali caster block
3. Get the right tire combo for your track
4. Drive smooth
Do that and you'll have a winner
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 07-29-2011, 12:26 PM   #1612
texastc's Avatar
F103 bodies fit with some trimming on the nose. I'm not sure about f104 bodies. Hopefully someone chimes in on that. Really don't NEED any hop ups to be competitive, its that good out of box. I have got the alloy castor block, and will do side spring mod, but I'm running just as well or better than the f103s and 104s at my track.
I also opted for longer titanium links on rear.
TCdoesRC
Old 07-29-2011, 01:11 PM   #1613
Does anyone run their 109 with the non-adjustable 103 front end? I run on a large-ish parking lot track w/ silvercan. Seems like the extra adjustability is just more complexity (and more to break) than necessary.
My plastic castor block is broken, and I find myself debating over whether to get the aluminum upgrade, or switch over to the simpler 103 front end. The guys running 103's seems to be doing pretty great with it.
Stregone is offline   Reply With Quote
Old 07-29-2011, 01:43 PM   #1614
The 104 axle rear width is the same as the 103/109 axle rear width. All the width difference in the cars at the back is in the rim.
Old 07-29-2011, 03:23 PM   #1615
tudor_47's Avatar
Well, actually the F104 axle is a little shorter, giving a little narrower rear. I know as i switched between the two in my F109, changing the diff to a F104 diff with adjustability inside the spur, not in centre of wheel.
F104 axle is 110 mm long.
F103 is in the car now so I can not measure it...but I am sure someone knows...
Xray T4-14 (BLS551,4.5T/8.5T, Spectrum), Xray X10-15 (Lajf Racing widened 235 4T, IRS)
Lajf Racing P28(LiPo, spectrum), Lajf Racing P28GT (LiPo, spectrum )
Xray X1(21,5T, spectrum) Tamiya M05(tamiya ESC, silver can, spectrum)
Go 235mm with X10 widening parts from www.lajf.se Get your P28 at www.lajf.se/pshop
tudor_47 is offline   Reply With Quote
Old 07-29-2011, 03:40 PM   #1616
The axle is shorter only because of the new way the diff adjusts. From where the wheels bolt on end to end the overall axle length is still the same. The F103/109 diff will still work with the F104 wheels and still give you the same width as a F104 but the thrust bearing assembly and diff adjustment nut will be inside the wheel instead of inside of the diff assembly. It looks a little funny if you look really close but works just fine. All of the width difference between the rear of the cars is in the wheel off-set.
Old 07-30-2011, 02:31 AM   #1617
Jamesalex's Avatar
Many thanks on the info, time I think to go chat to the local modelshop lol
www.cmcc.org.uk
www.mmrflux.co.uk
www.hpiracing.co.uk
Old 07-30-2011, 07:39 PM   #1618
LHD
Hi im going to HK next week. Where in HK can i buy the 3racing f109 kit? Thanks
LHD is offline   Reply With Quote
Old 07-30-2011, 07:47 PM   #1619
go across the boarder into Shenzhen!
they even sell RC gear at the station at Lo Wu
other then that just go to Dundas St .... thats were all the RC shops are.
not sure how successful you will be finding 3Racing items tho .... check the website and ask them. there is odd RC shops all around the Kowloon Pen.
RC Biot is offline   Reply With Quote
Old 07-31-2011, 10:09 AM   #1620
guys, what do you mean by 'side spring mod'?
today, I went to our local track to test the car - it is awesome! I can't wait to the winter season starts!
Z-Car Z10-XB PRO | SH PT-2010XB | Hitec servos | Spektrum DX3R | Merlin Fuel | AKA & Pro-Line
wiktor0410 is offline   Reply With Quote
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13160 Yesterday 11:58 AM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
