Old 07-09-2011, 01:11 PM   #1576
Flying Monkey's Avatar
Trader Rating: 54 (100%+)
What gearing are you guys using with silver can motors? I just got a F109 2nd hand and it came with a 78 48p spur that doesnt fit with the only axle spacers that came with it. I only have the #2 spacers and axle down the spur hits the chassis, axle up and it drags the chassis. Trying to figure out how to gear this darn car.
MONKEY BUSINESS RACING
Flinging poo at a track near you! Winning hearts and minds everywhere!
www.graphicmonkeydesigns.com
Brooksphotodesign.net
Flying Monkey is offline   Reply With Quote
Old 07-09-2011, 08:07 PM   #1577
Post Gearing
Gearing can be a bit of an issue witht he silvercan, ive been trying to find what goes best for me too. This is what i have found.
It depends on the diamater of your tires as to what kind of gearing you go with. Ive been aiming for a starting point of about a 55mm rollout. I have been using TRG tires (55mm Diamater) so i fitted a 74t 48p Spur and put on a 24t pinion for a rough start point. (there isnt much room left with this combo)
If you choose to try gear up from there you may want to look at additional cooling ( fan/s ) to keep the silvercan cool.
Try using a gearchart from gearchart.com to help you a little more. I have found a 74t 48p Spur about the biggest you really want to put on the 109.
Play around and see how you go, thats about the best way to find what works for you.
McLarenFan is offline   Reply With Quote
Old 07-11-2011, 03:04 PM   #1578
hello guys...
i've just finish to assembly my F1 09 but i've a problem!!!
i can't adjust the front ride height!!!
how do you do????
before i use to ride with a F104...
do i must mount other front axes???
thank's a lot for your help...
Redbull from France
Redbull is offline   Reply With Quote
Old 07-11-2011, 03:26 PM   #1579
texastc's Avatar
Originally Posted by Redbull View Post
hello guys...
how do you do????
Redbull from France
There is no built in ride height adjustment for the frontend. But I have read on here that you can use longer kingpins and shims.
Exotek F1 Ultra Tamiya TRF101 Tamiya TT02r SpeedPassion LM1 and SP1 C main mainstay. Unless there is a D
TCdoesRC
texastc is offline   Reply With Quote
Old 07-12-2011, 12:54 AM   #1580
ok...anyone know what can i use as kingpins and shims???
Old 07-12-2011, 01:00 AM   #1581
Tamiya has plenty of shim kits...dont have the part numbers handy but i got mine from RC Mart.
RC Biot is offline   Reply With Quote
Old 07-12-2011, 01:26 AM   #1582
thank's....if you can have a look for the parts numbers...
Old 07-12-2011, 01:32 AM   #1583
its either OP-585 or OP-586....not sure if the kingpin is 3mm or 4mm diameter.
trying to find time to fit mine
Old 07-12-2011, 01:49 AM   #1584
Thumbs up
thank's a lot
Old 07-12-2011, 09:40 AM   #1585
lightfoot's Avatar
So it's official... There will be F1 racing at this years IIC race in Las Vegas
http://www.intchamps.com/
Love and Peace...
lightfoot is offline   Reply With Quote
Old 07-12-2011, 10:42 AM   #1586
texastc's Avatar
That's awesome. Wish I was goin to be there.
TCdoesRC
Old 07-13-2011, 09:25 PM   #1587
Trader Rating: 33 (100%+)
Anyone have a used one for sale?
Chris Lockhart
**TEAM RCAMERICA**XRAY**HUDY**PROLEVEL RC**
chensleyrc1 is offline   Reply With Quote
Old 07-13-2011, 09:34 PM   #1588
Trader Rating: 77 (100%+)
for gearing do 100 spur and 28 tooth pinion its the money spot for fresh foams.....
artoftatt2 is offline   Reply With Quote
Old 07-13-2011, 11:05 PM   #1589
texastc's Avatar
someone is supposed to buy my 2nd one this weekend, if he backs out, I will have one for sale. Its not used though, frshly built. never run.
TCdoesRC
Old 07-14-2011, 12:53 AM   #1590
texastc's Avatar
have some spring questions. I want a harder spring up front, and I bought the tamiya front spring kit. Stock spring seems to be stiffer than any of the Tamiya springs. Is this true, or what. Also, what is the rate of the rear shock spring?
TCdoesRC
1/10 R/C F1's...Pics, Discussions, Whatever... Vyger Electric On-Road 13183 Today 06:00 AM
Tamiya F104 Pro! NT Electric On-Road 9356 05-21-2017 02:08 PM
Tamiya F103 Forum TFR Electric On-Road 2215 03-31-2017 03:58 PM
F1 series new rides for '09 mxrich Georgia Racing 12 07-06-2009 03:37 PM
