Old 08-06-2009, 10:55 AM   #1
Send a message via Yahoo to noelcleofe17
Default Shims for TB02 Diffjoints??!! What size!??
Does anybody knows what is the right size of shim that should be put into the Tb02 diffs outdrive before I put the ball bearings?
Im putting this to aquire good meshing of bevel gears. Thanks!
noelcleofe17 is offline   Reply With Quote
Old 08-06-2009, 07:46 PM   #2
From the TB02R manual it says to put ONE 10x0.1mm shim on each side.
Herman Chauw
hermanchauw is offline   Reply With Quote
SEO by vBSEO 3.5.0
