Old 08-04-2009, 05:17 PM   #1
R1wurks's Avatar
Default Rotor magnet test I-Gauss or others
Anyone have Gauss meter numbers on any brushless Rotors ?
Please post numbers & indicate if you tested it new or used.
Thanks in advance.
R1wurks is offline   Reply With Quote
Old 08-04-2009, 07:31 PM   #2
MOTHER FOCAR's Avatar
novak rotor numbers are worthless if not metered after they have had a couple runs on them...
any novak rotor over 1300 is good
team epic rotors will all meter out very close to the same 1280 range
get any of them over 200 and they fade
speedpassion,schumacher usa,smc,moffre racing,prs ,orc and team epic!
MOTHER FOCAR is offline   Reply With Quote
Old 08-04-2009, 11:52 PM   #3
R1wurks's Avatar
thanks for the info.
im hoping others can share their readings too.
Old 08-12-2009, 01:39 PM   #4
Gravity RC
The I Gauss definately does what it says. you will tell a defference between a weak and strong magnet on the track. I think that it is a good idea to check magnets especially after you get a motor hot, 175 and over. I just got my I gauss and it does a really good job. others also work but arent as user friendly in my opinion.
Paul L is offline   Reply With Quote
Old 08-19-2009, 02:09 AM   #5
rosko's Avatar
i have a trinity duo 10.5 that reads 1330 and a novak 10.5 that reads close to 1400
rosko is offline   Reply With Quote
Old 08-19-2009, 07:43 AM   #6
dameetz's Avatar
Pardon me, what is a Gauss meter?
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 08-19-2009, 08:59 PM   #7
rosko's Avatar
gives you a reading of the stength of the rotors magnet
Old 10-07-2009, 03:49 PM   #8
nitrobeast's Avatar
Trader Rating: 40 (100%+)
Is the magnet stronger for lower or higher turn motors? Does it matter?
Rui Goncalves
Reds Racing USA|Hot Race Tyres USA|Team CRC|Team Trinity|
Jackson RC|Horsham RC|Floyd Bennett|Blue Diamond
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 10-07-2009, 07:25 PM   #9
Trader Rating: 91 (100%+)
no such thing as 1400 gauss novak rotor ,sorry..
T.M. Tires BOCA Bearings Pemberton Race Works EAM ORCA GFRP/HD Trinity Muddslide Motorsports Independent Racing Products Fantom Gravity
koz47 is offline   Reply With Quote
Old 10-07-2009, 11:46 PM   #10
Its prolly just a different reading using a different checker. As long as you use the same checker to compare all your rotors the info is worth something.
Also... Low turn motors have much stronger magnets. On my checker Spec motors are around the 1300 area where as modifieds are almost 1700. And just to make you aware, a strong magnet in a spec motor is not always faster. There is a reason those magnets are weaker.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 10-08-2009, 04:40 AM   #11
PartTime's Avatar
And what would that reason be ?
DK
PartTime is offline   Reply With Quote
Old 10-08-2009, 05:11 AM   #12
DK
Total guess on my part but would it be that a weaker magnet allows them to spool up faster and maybe produce a little more umph...
adam lancia is offline   Reply With Quote
Old 10-08-2009, 09:25 AM   #13
HarryN's Avatar
Send a message via AIM to HarryN
I think the UMPH is from stronger magnets. Stronger magnets will yield better low end. A more weaker magnet will yield more top end.
I think this is correct.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 10-08-2009, 09:56 AM   #14
syndr0me's Avatar
Trader Rating: 32 (100%+)
You generally can't compare numbers between brands because of where the magnet is on the rotor, and how it's positioned in relation to the piece in the unit that measures its magnetic field. Use it to compare your rotors of the same brand, though, to see which ones are the best, and which are fading.
In my experience, a strong rotor will run cool, have good power down low, and good top speed. You'll need to gear it appropriately, a stronger rotor will need more gear than a weak one.
A weak rotor generally won't have as much punch, will still be pretty fast on top, won't need as much gear, and will be prone to running hot.
I think these meters are a good tool to have an idea of where your rotors are at, and to weed out the bad ones, but I wouldn't bother using them to try and get a magical rotor. Leave that to the slow oval guys grasping at anything they can to get faster.
syndr0me is offline   Reply With Quote
Old 05-31-2010, 07:58 AM   #15
pakk's Avatar
Trader Rating: 79 (100%+)
anyone try using one of these on novak ballistic rotors? I'm not sure if the ballistic rotors are the same as older novak motors, but the ballistic ones are too long. You can't set them all the way down on the meter.
*Photon* *SC10 4x4*
RCRD
pakk is offline   Reply With Quote
ROAR STOCK motors.... rule changes regarding BRUSHLESS Joel Lagace Electric On-Road 164 08-28-2007 09:07 PM
SEO by vBSEO 3.5.0
