Thunder Power 5000mAh 1S Lipo
Thunder Power 5000mAh batteries just became available we have them in stock and I figured I would post a little info about them.
mAh: 5000 (18.5Wh)
Volts: 3.7v
Discharge: 40C Cont. 80C Burst
Part # TP5000-1SPRD
Height: 18.5mm
Width: 46.5mm
Length: 92mm
mAh: 5000 (18.5Wh)
Volts: 3.7v
Part # TP5000-1SPRD
Height: 18.5mm
Width: 46.5mm
Length: 92mm
They are in stock at Aero-Model/Hacker Brushless USA
I also forgot to post the weight of the pack.
Weight: 147.5 Grams
Weight: 147.5 Grams
Whats the price Kyle?
The MAP price of these packs is $64.99 we have a phone special going right now if you purcahse a second pack you can get a good ammount off. Call for the special if you would like (480) 726-7519
Here are a couple more photos of the TP5000-1SPR in Josh Cyruls 12th scale.
Got mine in this morning looking forward to running them tonight
