What to Get?
What to Get?
I've finaly got enough money to buy a good ESC for my TC3.
Don't know what to get, should I get the Novak Dually or LRP F1 Pro
Which one is should I get?
Originally posted by AWOLsoldier
What's your budget? I'd go with a GT7 or a LRP competition.
those are to much looking for No motor limit Dually or Fl Pro
I'm not sure what you excatly want; The F1 Pro is a reverse ESC. As such, it's a good ESC. So if it's for bashing, this would probably be the best choise. The reverse can be disabled, if you want to go to some races.
But if it's for racing, I would definately choose the Dually; Much lower internal resistance, meaning more speed and acceleration. It has also a very good BEC (6 volt), while the F1 is only 5 volt. So with the Dually, there's 25% faster steering servo, so it'll react much quicker to your input. And then there's two profiles to choose from.
About quality, you cant go wrong with any of them.
Thanks alot, think I'm going to buy the Dually. Also Does the dually come with a heat sink?
Any more comments?
Any more comments?
