XERUN V2.0 Brushless ESC discussion thread. >
Old 05-21-2010, 07:11 AM
  #826
razzor's Avatar
Originally Posted by maxg123456
Well I tried this xerun 60A for the first time yesterday and my goodness. I used an old speedpassion V1 13.5 and was very impressive. I took someone elses settings left on here, but I ended up blowing the motor up. Strange, I only got the motor upto 145 degree F.
Anyway, put back in my Novak 10.5 and turned it down to stock timing with the same settings that I used on my 13.5 and it was as fast as anything else out there. Well done Hobbywing for this new firmware.
If I were to have a gripe, it would be the brakes. With the Novak (which is a weak on the brake front anyway) theres a delay in the brakes when you pull back on the stick. I recalibrated the transmitter before anyone asks. I have 100% brakes and 40% initial brakes. I hope theres a better brake in the future and it would be 100% perfect.
also put the reverse strength to 100%.
razzor is offline
Old 05-21-2010, 08:14 AM
  #827
wouldnt that mean id have to run forward/rev only? - I find that a bit dodgy going straight into reverse.
maxg123456 is offline
Old 05-21-2010, 08:29 AM
  #828
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Originally Posted by cherry2blost
YAY !!!! Finally unbanned lol Bloody SP Mods are killing me.
Oh and thanks for all the nice words on the forum supporting me at times like that you know who your friends are.
Now what's the betting SP will 'miraculously' come up with the 510 as 'their' latest software I don't actually think it is SP per se but the anal bloody americans running the operation in the States who are the problem here.
Hobbywing all the way, am gonna ebay my GT2.0 Pro coz am pissed off with SpeedPassion with a vengeance, Rip off merchants !!!!!!!
i hope you can behave
Marcos.J is offline
Old 05-21-2010, 10:28 AM
  #829
razzor's Avatar
no you still run fwd/brake with no reverse.
A few guys just found that the brakes felt stronger when the reverse strength was at 100%.
Thats what i have mine set to and i have plenty brekes and can practically lock up the wheels.
Note though some motors do have stronger or weaker brakes than others.
razzor is offline
Old 05-21-2010, 01:24 PM
  #830
cherry2blost's Avatar
AS IF !!!!!
No but seriously Charlie needs to lighten up a bit he is making it kind of personal a little lol
Went to Phoenix AZ for 4 weeks was UBER hot and got sunburnt but the kids in school were awesome.
cherry2blost is offline
Old 05-21-2010, 02:21 PM
  #831
mlight13's Avatar
Trader Rating: 40 (100%+)
Does anyone know why the XERUN 13.5 motor is a lower kv than all other brands? On one document, Hobbywing states it XERUN 13.5 is 2,500kv and another Hobbywing document says its 2,700kv. What's the true kv? I only got the 13.5 because the 17.5 motors from all other companies are between 2,200kv and 2,500kv. Seems odd to me
mlight13 is offline
Old 05-21-2010, 03:59 PM
  #832
xrayal's Avatar
tried 518 didnt notice any difference to 422. but 1 run ddrs at max anyway.......
xrayal is offline
Old 05-21-2010, 09:03 PM
  #833
Trader Rating: 8 (90%+)
Default which speedo
Im interested in trying these speedos. I am running a WGT 13.5 onroad car currently a tekin rs which speedo would be best for me? thanks and sorry if this is a newb question
bigdanes is offline
Old 05-21-2010, 09:21 PM
  #834
unsp0ken's Avatar
Trader Rating: 25 (100%+)
Xerun 60A is good down to a 5.5T for on-road (8.5T for off-road).
unsp0ken is offline
Old 05-21-2010, 10:23 PM
  #835
I don't know if this is normal with my Xerun 120A and 5.5T motor, please advise.
When I use it under sensored mode, the motor stutters/trembles when I press the throttle very very lightly. If I press a little harder, there is no stuttering.
If I disconnect the sensor cable so it will run in sensorless mode, there is no stuttering but it does require the throttle pressed a little bit more until the motor starts to turn.
garycoleman is offline
Old 05-21-2010, 11:32 PM
  #836
steliosh's Avatar
I also had it happen to me. Check the leds: If the green is blinking, you re sensorless, even with sensor cable attached. I changed the sensor cable and it worked flawlessly...
steliosh is offline
Old 05-22-2010, 01:56 AM
  #837
+1 I'd like to know also.
Sydewynder is offline
Old 05-22-2010, 04:04 AM
  #838
Mark Flores's Avatar
Trader Rating: 28 (100%+)
This stuttering at light throttle also happens to my XERUN 60A V2.0 on a 13.5 Team Powers motor. I tried changing the cable, at first it worked okay but now the stuttering is back.
Mark Flores is offline
Old 05-22-2010, 04:26 AM
  #839
AGNO's Avatar
Use wire sensors Novak and problems disappear, with cables LRP and Speedpassion I had similar problems.
AGNO is offline
Old 05-22-2010, 10:35 AM
  #840
Default latest software
I just received my xerun 120 a today, and am running 13.5. does it come with the latest software profiles installed, or do I have to upload it into my esc
Lohan is offline
