Old 07-17-2009, 06:42 PM   #1
drive2survive's Avatar
Trader Rating: 23 (100%+)
Default 1/10 car sliding??
this is re a trinity 1/10 car or maybe size doesnt matter? anyway Ill gun it F/T and the back end wants to slide around, like it wont track striaght, any reason for that? the present tires are treaded and its on asphalt
drive2survive is offline   Reply With Quote
Old 07-17-2009, 08:23 PM   #2
Danny-b23's Avatar
If it's shaft drive, it's most likely torque steer.
If it's belt, I have no clue.
RC America|EA Motorsports|ORCA
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 07-17-2009, 11:11 PM   #3
If it has two diff's in it, then the front diff should be alittle tighter then the rear. Otherwise its just like have a rear wheel drive car.
Also, make sure you have a good rear wing on it. RC Cars require them for stability, and to keep the nose pointing forward.
Shawn68z is offline   Reply With Quote
Old 07-18-2009, 12:59 AM   #4
lochness42's Avatar
That can cause for example - dead ballbearing, unequal shocks, little rear toe in, etc.
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 07-18-2009, 08:06 AM   #5
This is a little simplistic but check your rear toe. You should have 0.5 to maybe 2 degrees of toe in. Without it it can cause the car to feel very loose in the back.
Tiger72 is offline   Reply With Quote
Old 07-18-2009, 10:15 PM   #6
Geezatec's Avatar
Starting point, Toe-in frt & rear at 1 degree. Then Ball Diffs frt & Rear, Tighten till, by hand, turn rt rr wheel forward direction, left rear turns the same forward direction. Same thing on your frt diff. Then adjust each frt and rear diff till your satisfied.
Which ever side it's sliding more torque is supplied on that side. Tightening the diffs should put equal torque on you rear wheels.
Good Luck!!
Geezatec is offline   Reply With Quote
Mini/Micro RC S-T-R-l-K-E-R Manila Racers 7363 07-28-2016 11:21 PM
CRC Battle Axe, GenXPro 10, 1/10th pan, Brushless, Lipo,4c, Road, Oval,TipsandTricks John Stranahan Electric On-Road 1776 03-01-2016 12:18 PM
B-Fast RC Performance Diff Parts for LOSI AND ASSOCIATED scott54 Electric Off-Road 1710 08-26-2015 04:39 PM
1/10 Formula 1 Car Forums kuanseng1981 Singapore R/C Racers 4449 07-24-2015 11:28 PM
2006 IFMAR 1/10th 200mm On Road World Championship quozl Nitro On-Road 1120 02-28-2007 09:17 AM
1/12th, Formula 1 and Pro 10 pan cars Jimmyd Singapore R/C Racers 2114 10-30-2006 02:42 AM
Wheelspin at the starting line JL Electric On-Road 26 05-11-2006 02:04 PM
SEO by vBSEO 3.5.0
