Ask Todd Hodge..aka "Hodgimoto"
#241
If you can't find your droop screws,go to your local locksmith,they got all kinds of cool hardware.(I'm gonna get chrome ones!)
Rico,I'm going to do my droop this way.
Probably going to the gate every Sunday before the Nats with RayRay.
Your tires are with Sam.
#242
webspinner-Thats cool you posted those pics on here. Thanks!
proracer-i would definitely tape the are out before threaded the set screw in. By taping it, this will create less stress on the part.
#243
Todd,
Call me re: next weekend.
#244
Originally posted by webspinner
Not really jkerr, if the screw was not in there then yes it would be weak but with the screw in there it is as strong as it was without the droop screw.
Why not put the set screw in the chassis right under where you have the screws in the arms. I did that in the rear but I still use the bumper loacation in the front.
#245
Ted, If you go under the chassis onto the arm won't the droop screw hit the track when the suspension compresses? That's not good for carpet and it you run on asphalt well it might grind off head of the screw unabling you to use a hex driver not to mention changing the way the car handles when it bottoms out on them in the turns.
#246
I don't have the car in front of me, I don't know if there is enough room in front, the rear works for sure though.
Ted
#247
Todd, need help... Or any one help...
Son's car JR radio FM channel 87, and Z590 servo with a
IntellSpeed 8T Pro racing forward ESC. The servo always seems to glitch a little like it wants to turn almost like a short but when driving it doesn't seem to be a problem...
This is a Tamiya F201 car....
#248
MDawwson-Will do.
TedFlack-Is Bobby racing the Nats....his name is not on the signup list on the website???
NovaRacer-Does that ESC require a power capacitor? I know whenever my Novak stuff does that it is because I do not have a power cap hooked up.
#249
Todd- When running the xxx on carpet would you say it is neccesary to run the .90 limiter/spacers on the shock shaft. I was wondering if the car setup being soft causes this.
Rafael
Rafael
#250
Todd: Yes he is. Wouldn't miss a chance to race with you guys!!!!
EDIT: just checked, we are listed now.
#252
#253
Originally posted by TCR
odd but that speed control does not require a power capacitor, have you tried trouble shooting it by useing another servo or speed control to see if it reacts the same way?
Thanks again for the info....
#254
todd
any chance to get ray d's set ups from the birds and trackside???
thanks
matt
thanks
matt
#255
Batt chart is in your email.
Let me know what you think.
