Old 01-10-2004, 07:20 PM   #1
noline's Avatar
Default Reamer
Does anyone know where I can get a 1/8th reamer I want to ream out my bushings in my stock motor.
noline is offline   Reply With Quote
Old 01-10-2004, 07:31 PM   #2
JusBox's Avatar
JusBox is offline   Reply With Quote
Old 01-10-2004, 07:39 PM   #3
what exactly are you reaming? why not get a drill bit?
stumper is offline   Reply With Quote
Old 01-10-2004, 07:39 PM   #4
EddieO's Avatar
R/C Tech Charter Subscriber
Don't ream them.....way to easy to grind them down too much or not get the hole straight.
The best way is the qtip trick Brandon from team paridm came up with. Take a qtip, pull a LITTLE of the swab off.....then put it in your dremel, dip it in some mother's billet polish(available at any schucks), and then polish the bushing at medium speed until dark black. Use one qtip per bushing. Then polish the shafts of the armature using the polish and a rag, just put the arm in your dremel. I do the pinion shaft side first. Works great and you will have SMOOTH bushings.
Later EddieO
EddieO is offline   Reply With Quote
wtb Hudy 4mm arm reamer dgraham225 R/C Items: Wanted to Buy 0 02-02-2008 05:11 AM
Reamer Xmod_Racer R/C Items: Wanted to Buy 0 07-19-2007 01:54 PM
1/8th inch reamer FrankW R/C Items: Wanted to Buy 3 01-16-2006 03:32 PM
2mm reamer noline Electric On-Road 1 04-23-2004 08:03 PM
reamer??? lonestar1127 Singapore R/C Racers 7 03-27-2002 04:06 PM
SEO by vBSEO 3.5.0
