Reamer
Old 01-10-2004, 07:20 PM
noline's Avatar
Default Reamer
Does anyone know where I can get a 1/8th reamer I want to ream out my bushings in my stock motor.
noline is offline
Old 01-10-2004, 07:31 PM
JusBox's Avatar
sears?
JusBox is offline
Old 01-10-2004, 07:39 PM
what exactly are you reaming? why not get a drill bit?
stumper is offline
EddieO's Avatar
Don't ream them.....way to easy to grind them down too much or not get the hole straight.
The best way is the qtip trick Brandon from team paridm came up with. Take a qtip, pull a LITTLE of the swab off.....then put it in your dremel, dip it in some mother's billet polish(available at any schucks), and then polish the bushing at medium speed until dark black. Use one qtip per bushing. Then polish the shafts of the armature using the polish and a rag, just put the arm in your dremel. I do the pinion shaft side first. Works great and you will have SMOOTH bushings.
Later EddieO
EddieO is offline
