I have always been a huge 1/12th scale fan and want to see this class come to the top again. So, I did not want to release our standard 1S lipo version until we had a product that would not only be a top performer but also have longevity and some other nice features without compromise to performance.
Available end of July.
Pack Specifications
mAh: 5000
C Rating: 40c
max charge rate: 5c
Speedzone Cells & Brushless Motors - It's all About Performance!
Speedzone R/C - Radio Control Car Products and Accessories
Pack Specifications
mAh: 5000
C Rating: 40c
max charge rate: 5c
This will not fit t-bar cars you need to make a lipos that
Is the same size as two sub -c cells and then it will work in both
link cars and t-bar cars
Max charge rate = 5c!!! Does that mean you can charge it at 25amps?!?!?!
Was waiting for someone to catch that... To answer the question, it's a yes. We are most likley going to recommend a 1c/2c charge rate but max will indeed be 5c.
So will this pack fit the cut out on the new BMI LiPo spec chassis? Essentially meaning that this pack is the same size square as the existing SMC 1S pack? Now that ROAR standarized a spec for the class, and chassis are being made for this spec, I would think that your pack will fit these chassis, but just want to make sure.
Is it going to be low enough not to hit the center shock on most chassis, looks pretty tall in the pic.
Attached is a pic of the BMI chassis. It fits the SMC pack either upside down with the bumps on top, or with the bumps fitting in to the chassis flush.
-Joe
For Racing: BMI DB12RR-LiPo, For Fun: HPI Blitz
RCP 1/12th Scale 2009/2010 spec - Updated Often: http://www.rctech.net/forum/5734711-post1754.html
R/C Racing is: 10% skill, 10% equipment, 20% luck, 50% bullshit and drama.
nice pack gavin. i hope we get a 1/12 track soon. in the meantime the speedzone 5400 lipo has been performing great in touring car keep up the good work buddy
CRAIG SANTRY / TEAM ASSOCIATED / BMI RACING / SPEEDZONE USA / 360 RC SPEEDWAY / LONG ISLAND RACEWAY / BROWNIES PRO AND SPORT HOBBIES / STATEN ISLAND SPEED TEAM / TEAM ORION / TEAM UPGRADE / FUTABA / LRP / TEKIN / PROLINE RACING / JACKSON RC / HORSHAM RC
Length will be 92mm, width will be 46mm. The height at lowest level will be 18.5mm. All within the Roar rules. I designed it so that the bullet connectors would be on either side of the center shock. I'll post some more details tomorrow.
Thanks Craig. Yes, would be nice to have a track again!
Do the holes for the bullet connectors face the middle or the outside of the battery? Or perhaps will they will connect from either side?
AWD-Car Whisperer
www.readytorunrc.com
www.mikeshobbyshop.com
They will face the outside of the battery. Picture the humps on either side of the front part of the shock near the mount. It should allow for a neat setup.
