Many discounts and deals on RC products and parts can be found on UltimateCoupons.com.
Consider visiting BensBargains.net for great discounts on remote control products.
Old 07-07-2009, 07:51 AM   #16
swimbikerun's Avatar
Trader Rating: 21 (100%+)
The Tamiya shocks from a few years back which were gold colored. If you look at the Evo 4, it had gold Tamiya shocks.
-XRay T3 (Order Pending)
-AE RC12R5
-Pinarello F4:13
swimbikerun is offline   Reply With Quote
Old 07-07-2009, 08:06 AM   #17
jhwnissan's Avatar
I have heard that you can mod the belt to improve the acceleration a bit but cutting every other tooth and things of that nature. Unfortunately on stock belts, you can chew a belt if you aren't careful. Anyone else tried this?
Drawing RC madness in a Bunker.... Tons of Fun!
3 Losi Street Weapons, 1 Tamiya TT-01,
1 Bandit, 1 old skool Traxxas, 1 RC10 Graphite,
2 1/6 New Bright Crawlers, 1 1/10 New Bright Crawler
jhwnissan is offline   Reply With Quote
Old 07-07-2009, 08:20 AM   #18
Trader Rating: 14 (100%+)
I actually found the inner holes (the holes the bearings go into) of the cams to be too small on my TC5 when I had it. I shaved some material in there and it freed up for me. The bearings at the diffs definately get pinched and bound up and slow things down.
or8ital is offline   Reply With Quote
Old 07-07-2009, 09:14 AM   #19
Trader Rating: 32 (100%+)
Another thing to do is keep an eye on your diff pulleys. Over time stuff can get lodged in between the teeth and are impossible to get out. This causes your belt to tighten and loosen during movement. Check your diffs by taking the pinion off and freely moving the tires and look at the belt to see if it is rising off the pulley or if it is smooth. Another way to see this is by taking the top deck completely off and spin the wheels slowly. Look and see if the chassis bends. It should not.
This is something often overlooked.
Team Tekin www.teamtekin.com
JConcepts www.jconcepts.net
Team Epic www.teamepiconline.com
Kingsbury is offline   Reply With Quote
Forum Jump
Team Associated TC5 RCknight Electric On-Road 11416 Today 01:12 PM
Team Magic E4 Thread gansei Electric On-Road 2685 11-18-2009 04:01 PM
Associated Factory Team TC5, Brushless, LiPo, Li-ion Nanophosphate, Tips and Tricks John Stranahan Electric On-Road 807 10-28-2009 07:19 PM
Looking for 1/10 Electric Racers on the New Asphalt at Mikes, Houston John Stranahan Texas Racing 374 08-01-2009 02:28 PM
Best car to use for TA class??? csweatt Electric On-Road 18 06-05-2009 07:07 AM
AE TC5 Dominic C Electric On-Road 9 03-03-2009 07:36 AM
Powered By: vBulletin v3.7.4
Content © 2001-2008 RCTech.net | Privacy Policy | Terms of Use Privacy Policy | Terms of Use
SEO by vBSEO 3.2.0
