Old 06-28-2009, 12:56 PM   #1
Nuno Gancho's Avatar
Default When temperature getīs to hot, what to change
Hi, i need some help, my set up is perfect when temperature is low, during the day, when it getīs more hot, i satrt to lose stability and rear traction.
Do you change set, i have to use the same tyre during all event, thanks.
Nuno Gancho is offline   Reply With Quote
Old 06-28-2009, 01:13 PM   #2
wingracer's Avatar
Trader Rating: 23 (100%+)
What class are you running? Is this TC or pan car? Carpet or asphalt? Rubber or foam? I'm guessing rubber tire tc on asphalt.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-28-2009, 02:40 PM   #3
TryHard's Avatar
A few things to try.
Lower your warmer temps,
Thicker shock oils,
Softer springs.
the warmer temp is a pretty obvious one...
The shock oil, will slow the cars reaction down a bit, and also shock oil drops in viscosity a bit when temp comes up.
Softer spring might sound counter intuitive, however, they also work the tyres less, so don't heat them up as much.
HiH
Ed
Old 06-28-2009, 04:32 PM   #4
Foxxrocket's Avatar
If you'er running rudder tires. Then, temperature is going to effect your handling, through the tires.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 06-29-2009, 08:23 AM   #5
Hi, thanks for the help, i am runing modified touring car with ruber tyre.
If i am runing sorex 36 or muchmore 32 wich is the max temperature aceptable for the correct running of the tyre? When i start lossing rear traction normaly my tyres came out near 50-55š.
Thanks.
I have test thicker oil but it did not resolve my problem.
Old 06-29-2009, 09:55 AM   #6
asw7576's Avatar
most probably is setup / diff problem.
if you think is not setup / diff problem .... you should consider these :
1. paragon for rear tires ? .... if it doesn't help
2. have you use new set of tires ? 1 set for qualifying + 1 set for final ?? ..... if new set of tires still won't cut it ...
3. use new tires only for the rear, and use older*** tires for the front.
I also use sorex 36, with tip #3.
*** = rear tires from previous race.
Old 06-30-2009, 02:37 AM   #7
Yes i have used new set of tyre, it did only 1 good round, in the second round it start to lose rear traction.
Do you normaly change set up of the car because the temperatur goes high?
Thansk for the help.
Old 06-30-2009, 03:30 AM   #8
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
solution :
1: drill 3mmx 4 hole in your rim before you mount the tyres
2. Use thicker Insert
3. use 40R tyre
Give the best while u can !
kschu is offline   Reply With Quote
Old 06-30-2009, 03:33 AM   #9
asw7576's Avatar
No.
My friends and I are racing in hot weather tropical climates. No problem with Sorex 40. We don't change setup as temperatures rise.
You should check your setup / diff again. Perhaps you should copy an asphalt setup from your car's manufacturer, or from your car's factory team driver.
Probably your home track is not treated well ? not smooth surface ?
Btw, what car, what body and what tires do you use ?
Old 06-30-2009, 04:12 AM   #10
TRF415boy's Avatar
Am going to say the exact opposite to Ed here....
Put stiffer springs on
TRF415boy is offline   Reply With Quote
Old 06-30-2009, 05:11 PM   #11
Should i use higher roll center or lower if i am lossing rear traction when it starts the track to get hot
Yes the surface is not smooth
Xray 2009.
Set up for cool temperature is excelent, only get worse when temperature goes higher.
Old 07-01-2009, 02:44 AM   #12
Tpg racer's Avatar
I do notice this too with my TC... morning and evening session the car runs pretty well... During the noon session, things starts to get kinda slide-ish...
I felt lesser traction on the rear end (tends to oversteer a lil)...
Havent found any solution so far but the only way for me to avoid this is to drive a lil more conservatively and avoid crashing or spinning out... I have a feeling spinning out really heats up the tires badly...
Just so you know, we have pretty hot tropical weather here in Malaysia
Tpg racer is offline   Reply With Quote
Old 07-01-2009, 03:34 AM   #13
vr01's Avatar
Part of it is probably related to the track surface itself. As the temperature comes up, the track gets greasier as whatever is in the track material is drawn to the surface.
Have you tried anything so far? Also do other drivers experience the same problem?
vr01 is offline   Reply With Quote
"the tuning bible" houston Onroad Nitro Engine Zone 311 04-24-2017 11:18 PM
Off Road Thread (ALL SCALES UNITE) suntok2 Manila Racers 18645 01-07-2016 01:13 AM
Novak Mongoose frogger Micro and Mini Scales 601 08-05-2015 08:08 AM
RC News in Sarawak jfc_tech Malaysian R/C Racers 678 12-08-2008 08:26 AM
Newbie here...HELP olkuy Monster Trucks 10 10-19-2005 06:57 PM
