Old 01-08-2004, 01:35 PM   #46
J.Filipow's Avatar
Trader Rating: 15 (100%+)
James- The bearings are just pressed.
P1 Brand - "Victory is Black and White" ◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤◢◤
RC America / XRayUSA / Hudy / Motiv / Avid / Vannen Watches
J.Filipow is offline   Reply With Quote
Old 01-08-2004, 01:39 PM   #47
That's cool, I wonder if it can be done with regular bearings at home?
James Nguyen is offline   Reply With Quote
Old 01-08-2004, 01:54 PM   #48
J.Filipow's Avatar
James- It can be done. Dirt told me that he made a jig for cutting/enlarging the outdrives, which is the hard part if you wanna try this mod at home. But getting the bearing to fit properly isn't easy either, actually. (Once the bearings are pressed on, it won't be possible get them off the pin without damaging it). The depth bearing is a little too deep and a small portion of the shoulder of the CVD needs to be relieved so that the outside of the bearing is flush with the outside of the CVD pin...regardless, the photo that Gary posted is good for reference.
Old 01-08-2004, 02:32 PM   #49
Thanks for the info. You wouldn't happen to know the size of the bearing by chance would you? I would like to try this mod out.
Old 01-08-2004, 05:19 PM   #50
pro3racer's Avatar
is there going to be a event thing in the event section, or are all the results going to posted here first? Good luck, to everyone, and take it easy, don't go for the whole race in the first turn, my experienced two cents... it rarely works, lol
pro3racer is offline   Reply With Quote
Old 01-08-2004, 08:08 PM   #51
Trader Rating: 37 (100%+)
i was at the controlled practice all day today...
when i left at the end of the day the fastest car on the track was Chris Tosolini's Yokomo touring car...not sure what motors he runs. but he ran the fastest lap of the day in mod practice... 11secs flat. cyrul, baker, blackstock, jucha and few others were able to come close but from what i remember tosolini had the most 11s flat.
i have about 50 pics i will post soon.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 01-08-2004, 08:38 PM   #52
RCTech Member #2
TSR6's Avatar
Send a message via ICQ to TSR6
I wouldn't be able to tell you on the 19-turn motors for which is the choice. I'll try to walk around and see what the good-word is.
For stock, It seems split on monsters and the new binary motors. There are probably more Binary motors out there, but I've seen quite a few monsters around.
I will post a picture of the outdrive bearings here in a minute or two. As J. said a couple posts back, it just removes the slight binding between the pin and the outdrive. If you've ever looked at a car run for a while with any type of plastic or composite, the pin wears into the outdrive. I would think that the bearings would remove that wear, and remove that binding.
They are also trying things with the belts. I don't know exactly what is different within the drivetrain ( in anything ), but the belt they are testing is longer than the stock belt. I don't know anything past this - Todd was pretty vague on his description of the drivetrain.
Traction came up in a major way today -- we have more traction than I've ever seen in the past two Novak races I have attended. Cars are starting to traction roll. It's not a big issue, but if you drive into the corner to hard, you'll know it.
Troy
RCTech Member #2
The postings and views expressed on this site are my own and do not necessarily reflect the positions, strategies, or opinions of any company I may be employed by.
TSR6 is offline   Reply With Quote
Old 01-08-2004, 08:44 PM   #53
RCTech Member #2
TSR6's Avatar
Here is Brian Kinwald's car. He and Todd are running the new drivetrain parts.
As usual, His chassis is pretty trick.
Troy
RCTech Member #2
Old 01-08-2004, 08:48 PM   #54
RCTech Member #2
TSR6's Avatar
Hodge's car, showing the outdrives -- or BK bones as they've been called earlier in this thread.
Troy
RCTech Member #2
Old 01-08-2004, 08:53 PM   #55
RCTech Member #2
TSR6's Avatar
Another shot of Todd Hodge's car.
This is the last picture I have for right now. I'll have more tomorrow night, and if there is anything you guys need to see, or know -- post away. I'll check back here before I head to bed, and Futureal's net is working, so I'm sure between the two of us, we can do our best answer your requests.
Troy
RCTech Member #2
Old 01-08-2004, 09:24 PM   #56
JitsuGuy's Avatar
Send a message via AIM to JitsuGuy
Cool pics! Thanks!
J
JitsuGuy is offline   Reply With Quote
Old 01-08-2004, 09:38 PM   #57
RCTech Member #2
TSR6's Avatar
Originally posted by JitsuGuy
Cool pics! Thanks!
J
No prob!
I've been running in practice with the OK guys a little bit. I know I was running with Derek and Bob in practice.
Troy
RCTech Member #2
Old 01-08-2004, 10:00 PM   #58
EddieO's Avatar
R/C Tech Charter Subscriber
Some more in depth pics of the losi cars would be sweet, especially checking out any little mods they have. Looks like kinwald has a 5th body post. Would be nice to get some close ups and ask him what it took to make it.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 01-08-2004, 10:10 PM   #59
R/C Tech Founder
I just got my net up and running, yea.
Not much time to post pictures yet tonight as I'm painting up a few bodies and truing some tires. I did get some close ups of Hodge's Losi car, of Paul Wynn's MI2 prototype, and of Tosolini's Yokomo car. Going to get Kinwald's and Cyrul's cars tomorrow, and maybe others.
Hodge is running the bones that Troy posted above, as well as a longer belt tensioner that they are testing, if you are familiar with the Losi car I think the idea is to eliminate the sharp "kink" in the belt as it goes around the spur/idler combination. No pics of that, though. Kinwald has the pretty standard stuff and is testing a new body, Pugeot I think. Most of the team drivers are going back to the Losi Alfa, a few still running the Skoda.
There is some super cool stuff on the MI2 cars, too much to even list. Haven't taken a closer look at any other yet.
As posted, Tosolini was ultra fast, so were Cyrul and Blackstock. Lap times are posted, but not in "heat" format, just individual laps. The RC Scoring Pro software is being used to do the laps, it's pretty slick, plus there is a Betabrite tote board that lists lap times as the drivers cross the line.
I'm off to work now, any more questions I'll try to answer.
Visit my store: www.ampdraw.com
futureal is offline   Reply With Quote
Old 01-08-2004, 10:33 PM   #60
RCTech Member #2
TSR6's Avatar
Originally posted by futureal
I Kinwald has the pretty standard stuff and is testing a new body, Pugeot I think. .
Brian is also testing the new belt and drivetrain.
EddieO - Yes, although I'm pretty sure it's just a body support for the body to rest on.
Troy
RCTech Member #2
R/C Tech Live @ the 2005 Novak US Touring Car Championships futureal Electric On-Road 1079 01-28-2005 02:20 PM
R/C Tech Live @ the 2004 Reedy Race of Champions futureal Electric On-Road 576 06-23-2004 08:05 AM
R/C Tech LIVE from the 2004 ROAR Carpet Nationals futureal Electric On-Road 704 04-08-2004 10:47 PM
R/C Tech Live @ the 2004 Winterfest U.S. Triple Crown Race in Milwaukee, WI futureal Electric On-Road 52 03-02-2004 07:30 PM
R/C Tech Live @ the 2004 Trinity/Car Action Snowbird Nationals futureal Electric On-Road 901 02-25-2004 02:05 PM
