Old 04-29-2005, 01:41 PM   #1036
Thanks everyone !
So if i understand correctly i need to change the pins location on my pack connector, using the "old" KO Propo housing (see http://www.kopropo.com/faq.htm)
It would mean that KO did change the connector on the receiver to the standard one, but not on the TX.
I'm going to try it asap.
Edit : Wahooo it works!
BTW can is use the same wall charger i had for my old hitec system ?
I believe that only JR use the reverse type. Can someone confirm?
charlymbx5 is offline   Reply With Quote
Old 04-29-2005, 01:50 PM   #1037
forty6's Avatar
Default Helios and nitro
Robert or anyone using a Helios w/ nitro, how do you set it up so the lag between brakes and throttle is minimized? I mean, I want the servo to accelerate from the point of full brake back to neutral as fast as possible. Can this be done?
forty6 is offline   Reply With Quote
Old 04-29-2005, 02:31 PM   #1038
axel's Avatar
anyonone have a link for a battery charger for the helios?
axel is offline   Reply With Quote
Old 04-29-2005, 05:47 PM   #1039
TFR
TFR's Avatar
Default Re: steering wheels
Originally posted by axel
whats a good place that has a variety of selections of steering wheels for the helios.
Alloy DISH!!!
Muchmore l AHRP l Xenon l Futaba
TFR is offline   Reply With Quote
Old 04-29-2005, 06:10 PM   #1040
axel's Avatar
WOW! Thats f*cking awesome! I saw hara use a purple one. Where do you get those and how much.
Old 05-01-2005, 03:20 PM   #1041
Mark G's Avatar
Send a message via AIM to Mark G
i have a question i gust bought the raido and i pluged every thing in but when i trun on the raido noting goes ive tryed looking at all the settings and stuff plz help me
mark
Mark G is offline   Reply With Quote
Old 05-01-2005, 03:41 PM   #1042
onebeatuptc3's Avatar
Send a message via AIM to onebeatuptc3
make sure the plugs are put in the right way on the receiver. If you have them backward, nothing will work.
onebeatuptc3 is offline   Reply With Quote
Old 05-01-2005, 03:48 PM   #1043
Mark G's Avatar
ok so if i get them in the right way should it work?
Old 05-01-2005, 03:49 PM   #1044
axel's Avatar
yeah just check if each plug is in the right channel plug. Servo-ch1,and esc-ch2. If it doesn't work contact ko propo ASAP.
Old 05-01-2005, 03:55 PM   #1045
axel's Avatar
Default charger help please
Hey i found a charger i think. It plugs in my helios here is the specs:
Sino-Amercan
model:6-10
Class 2 Transformer
Input 120v
60Hz
15w
output:6v
DC 1a
(fsp-45)
To be used with fast charge stick driver only
And i have radioshack 2000mah batteries
Old 05-01-2005, 04:09 PM   #1046
Mark G's Avatar
does it like madder if like a brown wire on the servo is faceing out or any thing ?
Old 05-01-2005, 05:28 PM   #1047
Mark G's Avatar
i fixed it yea
Old 05-01-2005, 06:10 PM   #1048
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Re: Re: steering wheels
Originally posted by TFR
Alloy DISH!!!
That looks mad, any links where to get those coloured dish rims.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-01-2005, 06:17 PM   #1049
axel's Avatar
Hey so i tried this charger, i tried plugged it for about 1 second to make sure nothing bad happens, and when i did my helios would trun off then when i took it out it turned back on.
Old 05-01-2005, 06:26 PM   #1050
HarshGuy's Avatar
Originally posted by theisgroup
FYI,
I ram my helios with the spektrum system yesterday in ahrs mode and had no problems. no glitches and no delay problems. it seams that with the helios you can use the ahrs just not the futaba system.
S0 I'm assuming you had esc's and servos to take advantage of the AHRS? ...did you notice any response difference at all with the spektrum vs. the 302f?
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
ko propo helios alexisonfire Australia For Sale/Trade 7 03-06-2008 03:19 AM
KO PROPO EX-10 Helios 40 Mhz jca2000au Australia For Sale/Trade 0 12-06-2007 08:03 PM
**EX-10 HELIOS KO PROPO*** nsupra R/C Items: For Sale/Trade 8 08-14-2006 08:11 PM
Ko Propo Ex-10 Helios hurley081182 R/C Items: Wanted to Buy 1 04-03-2005 06:58 PM
F.S.> KO Propo Helios... plus Bwadd2002 R/C Items: For Sale/Trade 7 05-19-2004 08:40 PM
