KO PROPO EX-10 Helios q's
#2042
What about the size of it? Will it be comparable with the Spektrum 3500?
#2043
Hi everyone,
-Im about to build a new EP car with all new ESC/servo and receiver etc.., I figure I need to reset all the settings on my helios before I do, is this correct?
-Once the car is built and all electronics are in should I recalibrate the helios using the VR setting?
What are the steps required.
any help would be appreciated.
thankyou.
thankyou.
#2044
how can you tell the difference between helios ex-10 and helios ex-10c2,i know price , carry case ,drop wheel ,but what else anything visable just by looking at them side by side,can you convert standard ex -10 to c2?any model or serial or production #'s,i am going to buy one the guy says its c2 don't won't 2 get screwed,thanks
#2045
EX-10 Helios C2 (Competition 2)
The EX-10 Helios C2 is a limited edition (900 unit production, USA 200 units will be available 27MHz only) that will include the RF-502FH super module, KR-302FS receiver, wheel extension unit, light weight aluminum screws, solid aluminum steering wheel with decrease angle spacer to limit the amount of wheel movement and aluminum carrying case. Available in 27MHz only.
The fastest response with the CPU built-in super module is our pride of the super stable efficiency.
Attaching the multi angle wheel extension with the limited color silver aluminum light weight screws and aluminum hard carrying case are included.
EX-10 Helios C2 Tx/Rx (KR-302FS) 27MHz # 80231
Its not anything more different other than looks. They had a gold one like this too, but this one is even more special.
#2046
really the base helios transmiter is the same. the c2 comes with a cpu module (502) the carbon fiber rx, light screws, external EPA adjust steering wheel. I think the wheel and screws are not available as spares. so it would have come from a c2.
#2047
also if you check there web site the LCD is a little bigger and backlight control you can turn on and off
#2050
so nothing really visable on the radio,but module,screws,and wheel.can you tell by serial #'S? what is the carbon rx?is that the 302f.
#2052
what does c2 well look like,
#2054
k_king you seem very informative i thank you.but can you answer my question on the serial #'s?
