KO PROPO EX-10 Helios q's
#1728
Try this: http://www.jrradios.com/ProdInfo/Files/Z1_manual.pdf
This is the JR Z-1 manual but they say it is the same stuff rebadged except this has synthesized module and receiver (I don't know for sure I'm just planning to buy one)
#1729
Originally Posted by RED-LINE M03
Why is the Throttle acceleration red light flashing on and off? This is located towards the top of the Helios.
Thanks again.............
#1732
Has any one got there Lap timer able to work? Ive set it to a certain key button what ever you may call it but it seems not to work. I would like to try and get this working for practise with the AMB isnt turned on.
Thanks,
Will
Thanks,
Will
#1733
Receiver Compatibility
Can anyone confirm if this receiver will work with a KO Mars Ex-1?
http://www.hitecrcd.com/Receivers/HFS03MM.htm
#1735
Not sure FK. I just got my Helios and tried something similar however. I am replacing an XR3 pro and the following worked.
I left my 310 receivers in the cars and set thier pots to channel 72. Then I placed a 72 crystal in the Helios 75 mhz module. I got perfect reception in the "place the car on the p-dub stand and walk as far away as possible and see if you get a glitch test."
I saw someone ask if this would work a few pages back and wasn't sure if anyone answered it. Just an FYI.
A question however. I have a 12L4 and an RDX. I have 1 302 receiver. Which car would y'all preferr to have the faster reponse time in? Does it really matter? THX
#1736
#1737
is the transfer rate in the helios faster than my old precious ex-1? Reason i'm asking is because i put a spektrum system in my precious, and am planning to buy a helios and put a spektrum in that. is the transfer rate determined in the modules or in the actual transmitter? I hope this question is clear to you guys.
#1738
I got this of the KO web site. Does any-one know what speed to set the Helios to so it can talk to the KR-297FZ receiver and were is it in programming?
Q. Will my new EX-10 Helios work with my older receivers?
A. Yes, but you will have to set the radio to the correct speed setting for the receiver being used.
Thanks,
E
Thanks,
E
#1739
Thanks,
E
Thanks,
E
#1740
Red-
Advanced HSR - 2 CH High Response (Swithc behind module up)
Super HSR - 3 CH High Response
Normal - Either channel setting Normal response (Switch behind module Down)
Advance HSR - KR-302F Only
Super HSR - KR-302F & KR-301F
Normal - KR-302F, KR-301F & KR-297FZ
