KO PROPO EX-10 Helios q's
#1607
Battery charge jack
If I want to use the transmitter charging jack on the Ex-10, what type of plug will I need? Can I use the Futaba one? Thanks!
#1608
KO, Futaba and Sanwa (Airtronics) are all the same plug. JR has the polarity reversed.
#1609
Hi, I have a question about my Helios.
I tried to read the whole manual, but I couldn't find the solution.
At the moment, I use CH1 and 2 for steering and throttle.
And I want to use CH3 for rear steering as my TLT-1 is 4WS.
But what I got the result is when I put CH3 to ET4 or 5. however I pust left and right, the servo only turn from extremely left to right or reverse.
Is that normal? Or if I can do something like attach the CH3 to CH1. When I turn left. one servo go left another one go right??
Thanks in advance!
Thanks in advance!
#1610
amazon- There is no channel mixing feature in the Helios, sorry. The 3CH can only be used as an on/off switch, mainly for putting gas trucks into reverse.
-Robert
-Robert
#1611
What is the cheapest way to connect the Helios to your computer? Is the $60 kit the only option?
#1612
If you don't have that, then you'll need the Value set #61001. This includes the PC interface and Helios adpater.
#1613
I'm looking for aftermarket alum bag for Helios (fit with drop down installed) anyone have info? Sanwa always has it, Futaba has it why KO never produce it?
#1614
You may see something later this year.
#1615
Edit: Thiers is soft, sorry, didnt see you were looking for aluminium specifically
#1616
Originally Posted by KO PROPO Staff
Actually, we did have one in the past. It was not an aluminum case but a hard ABS plastic case. Very light and very limited in production. This item was still being offered when the Helios was released (2 years ago). After the release of the Helios they sold very quickly, out-of-stock and discontiued.
Later this year you mean new radio?
#1617
Originally Posted by v0rtex
Speedmind have one, works with Spektrum module in the back also
#1618
I have the Speedmind bag and I put a JR Z-1 with an extension in there and it fits no problem. Maybe you have a different angle on the extension.
FYI, Japanese market sells Hara's Device case separately.
Go here and click products:
http://www13.ocn.ne.jp/~mirage-j/
#1619
#1620
Yes, it's a bit overpriced!
