Battery choices for stock class
Hi there
I know there's many battery threads, and I've tried different searches for finding the best batteries for stock class. But the results were overhelming.
So please help me, either by direct answer or by providing a link for the proper thread.
I need to choose which pack to buy.
I'm racing in stock class. I like the performance from Sanyo 3000 and want at least the same voltage, IR and durability as Sanyo 3000 HV.
I'm an budget guy, and considering the following, which I've found at nice prices:
Team Orion GP 3300 batteri-pack, V-Max Plus-RDS
Gold Peak NimH 3300 mAh - volt: 1.160-1.164
Sanyo 3300 V-Max plus nimh rds
All three packs cost the same. I tend to get the Gold Peak NimH 3300 mAh - volt: 1.160-1.164. But what do you guys suggest?
Are your choices limited to those three packs?
I bought a zxracing(www.zxracing.com) pack and am very happy with it. Their 1.160-1.164v packs are $35us. I doubt there is a hugh difference between matchers. Other then that I'd say stick with gp3300's, forget the sanyo's, from what I've heard they arn't as good as the gp cells.
Limited and limited, well, I live in a small country and the RC market in itself is quite limited.
The above was what I found on the net, that fit in my pricerange. But I can see if I buy overseas, ZX-prices are the half of wahts avaible around here. I prefer supporting the LHS, but 50% discount or better batteries are temptating....
Anyway, the choise between Sanyo and GP matters, so it's nice to hear a vote for one of them.
Cole, hands down the GP's. Alot of battery matchers here in the USA have quit matching Sanyo's and Panasonics.
Cole I would give my vote to Fukuyama packs. I have a few different packs in my box and the Fukuyamas are by far the best. Runtime is sick with them. At the end of a 5 min race your final laps will be as fast if not faster than your first. And there is a large difference between machers. Each one has thier own process that they zap and cycle the cells at to give you the product they think is the best.There is one matcher s pack I have that I think was a waste of money and the others are good but the Fukuyamas are juat a step above. Right now anyhow, until someone else comes up with the new hot setup.
Fukuyama Racing
IM not sure about a supplier over there but you can get em right from them easily and the price and service is second to none.
Fukuyama Racing
Re: Battery choices for stock class
Originally posted by Cole Trickle
Hi thereI know there's many battery threads, and I've tried different searches for finding the best batteries for stock class. But the results were overhelming.
best batts ..
I'D say FUKUYAMA .. I've ran all the others and find that these paks are the best and most responsive on punch and durability and run time .. the IR,s and numbers are excellant the service and attention to detail cant be beat....so look them up ......I would..thanks..
The "Orion GP3300" and the Gold Peak 3300 are the same cells. Get either one of those packs. Whichever you think has better numbers.
Orion uses lavco matchers, and they are pretty reliable. Same type of machines used by Reedy. The GP cells are FAR SuPERIOR to any sanyo that has come before it.
I say use ZX packs I have several of them and they are awsome.
Thanks for all the helpfull replies.
It's easy, since all of you say GP.
I researched a little more and found out, that the "Gold Peak NimH 3300 mAh - volt: 1.160-1.164" comes from Team-1.
I'm waiting for an answer about the Orion numbers.
I'll also contact Fukuyama.
Check out hurricane motorsports. They had drivers in all the A-mains at the novak race and are great packs for a relatively low price.
Get some ZX racing packs. ZX is created on getting racers with good cheap batterys. With a stock motor you would even be fine with some 1.15-1.159. They run at 30 bucks
The extra money you spend on Fuku cells over zx cells is paying for the fuku team drivers. As far as I know, zx racing has no team drivers so they give the saving to the racers. IMO the fuku cells arn't superioir in performance to the zx cells. I've seen fuku, zx and promatched cells on the track and there all very close performance wise. Whatever you buy I'm sure you'll be happy with them(including orion, team-1).
